Cp, Cpk, Dpm, or other? Diameter of a Hole - Non-Normal Distribution
mattia.oliosi
I have data about a process. this data are about a diameter for a hole. The process doesn't have a normal distribution. I have to fix goal for a project. What metric can I use for goal? Cp and Cpk? Dpm? Yield? And how can I calculat this metric?
TAL
Mattia
Darius
Re: Cp, Cpk, Dpm, or other?
if the % of defective is high enough, you can use Dpm or Yield.
IMHO, If is small, you can try Cpm or Cpmk (altho they take in account as Cp or Cpk a gaussian distribution, they are robust for non gaussian distributions), or use a non parametrical capability index or transform using box-cox transformations.
mattia.oliosi
What do you mean for Cpm or Cpmk?
My data set is not trasformable. I try with mintab software.
Mattia
Darius
Try search on the forum or on the net Cpm +"capability index":read:
you can see a discusion here
Need help / feedback on Xbar/R charts and Cpk/Ppk applicability - Assemblies
but for short Cpm or Cpmk uses the difference of the mean to the target value to punish the value as you go farther from the target. Some people name this capability index as Tagushi Capability index as the formula is based on the Tagushi's loss function.
:2cents:I my self found cases where a period of time because of low variation the Cpk looks better against another with bigger variation but on the target. As Tagushi said more or less "To the target with low variation", but first "TO THE TARGET".
mattia.oliosi
I find a index. Cnpk is a index for no-parameter. It's the minimun between (USL-median)/(percentile(0,99865)-median) and (median-LSL)/(median-percentile(0,00135)-median).
I think It's the wright one for my situation.
TAL
Darius
:agree1:Agree; as I told you non parametrics is a good option for non gaussian distributions (maybe the best).
Tagushi's index can be a middle point between traditional capability index like cpk/cp and their non parametrics conterparts. And I have seen articles where comparisson between capability indexes show a better behabiur on box-cox transformations (but as you said, it does not apply in your case).
Good luck.:yes:
jospe.at.liu
TAL
Mattia
My spontaneous reaction is that your data should logically resemble a normal distribution. Hole diameters usually fit normal distributions quite well. What is your basis for saying that your data is non-normal? Have you checked the data for special causes of variation? I would make three plots to determine this:
1. A time series plot for average or individuals (depending on the process)
2. A time series plot for variability (range or standard deviation), alternatively moving range if individual values are used.
3. A normal probability plot
When you have made these plots, you should be able to find some clues as to why you have a non-normal appearance in your dataset.
mattia.oliosi
My distribution is non normal. I use minitab 15 to check the time series and the X-R chart. Than I check that p-value for a normal distribution (using AD-test) is loss than 0,05.
I use the equation for non normal distribution that uses dpm to give a Cp value.
TAL
Mattia
jospe.at.liu
I think you will learn more about the behavior of the process through looking at a normal plot as well. Special causes of variation can make the process seem non-normal. You could also check for autocorrelation in the data set. That will also distort the distribution.
G
Geoff Withnell
Hole diameters usually fit normal distributions quite well?! I have not found this to be the case. There is usually a hard lower limit of the drill, punch or whatever tool size to the the distribution, with a tail to the right that can be either long or short depending on the process. Hole size is usually the LEAST normally distributed of mechanical size dimensions.
Geoff Withnell
O Estimating the dpm and ppm of the process from Cp and Cpk Statistical Analysis Tools, Techniques and SPC 5
A Cpk Vs DPM (Defects Per Million {aka PPM}) Capability, Accuracy and Stability - Processes, Machines, etc. 3
L Cpk in relation to individual process parameters. Reliability Analysis - Predictions, Testing and Standards 1
D Ford CSR Cpk/Ppk Requirements Statistical Analysis Tools, Techniques and SPC 10
PQ Systems Cpk: Indispensible Index or Misleading Measure Using SQCpack Software 0
R Cpk demands from automotive customer Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Can I use Cpk to compare if one part is usable in another part? Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 21
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 15
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
TarKEpa Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
