Cpk 1.99 But Out of Specification Measurement Detected in Control Chart
#11
Re: CPK 1.99 But Out of Specs Detected in Control Chart
The control charts, UCL, LCL, CP and CPK are automatically calculated by the system. They are 60 subgroups, and 8 of them are way off UCL measuring 0.099. CP is 3.08. My thought for this is, when a small portion of a good data is out of control, it will still give you good cpk. A very important rule often overlooked by the operator is that they must first look at the control charts before looking at the cpk.
An even better rule for the operator is to stop charting when out-of-spec conditions are encountered. Operators also need to watch for trends (excursions away from the mean in particular). The whole point is to use statistical data as a guide in centering the process variation as far away from the spec limits as is reasonably possible. Having crazy, unintelligible charts after the fact isn't helpful.
David DeLong
#12
See Steve Prevette's comment in this thread; the most likely prospect is that the mean and control limits need to be recalculated. The first question to ask is why out-of-spec conditions were charted in the first place. If the process is producing material that doesn't meet specifications, we know that the process is grossly incapable, regardless of statistical capability. At the point where the out-of-spec measurements took place, someone should have stopped and done something about it.
I think that we should reflect all the sample information even if the reading is out of specification but the reaction to this out of control situation is a bit different. We certainly should correct the process and also place the parts that were made from the last good check in quarantine. The suspect parts should then be 100% sorted.
Cp & Cpk should only be calculated if the process is in control and I cannot think of how a process could be in statistical control achieving a Cpk of 1.99.
#13
While I agree that in a continuous situation the charts should show everything that happens, I suspect that given a 300-piece population perhaps a PPAP submission is involved. I could be wrong about this, but if I'm right, the PPAP SPC report should show a stable, capable process, and not a lot of wacky stuff.
I still don't understand your reasoning here. Why shouldn't a process that's in control yield a Cpk value of 1.99? (Note that my question has nothing to do with this particular case.)
David DeLong
#14
I am referring to a situation where one has a Cpk of 1.99 and parts out of specification in my previous answer.
Of course a process that is in statistical control can have a Cpk of 1.99.
F
fEArmE
#15
Chart is plotted automatically. Operators shall be trained adequately to analyze control charts:tg:
I've attached the control chart to clarify some confusions. Actual CPK is 1.87, not 1.99 because I received the chart from our supplier only after I posted this message, but they are close.
#16
Thanks for the clarification, but you made no mention of out-of-spec parts being a condition of your statements. Here is what you said:
If one has 60 sub-groups of 5 samples on an X bar and R chart and somehow arrives at a Cpk of 1.99, something is wrong.
It's helpful if you quote at least part of the post you're responding to so that people don't read comments like those above and not understand the underlying context.
#17
It appears that whomever sent you the chart just plugged a bunch of numbers into the software, hit "Print" and didn't bother to analyze the results. It's not really even worth reviewing in detail. I've seen a lot of this--people who think that (A) no one is going to parse the data, and (B) all you're looking for is a Cpk number above some defined limit. I also note that the spec limits aren't mentioned or charted. If you have already explicitly defined what you expect to see wrt SPC reports, and this report meets those requirements, you need to revisit them. On the other hand, if you haven't provided an explicit definition, you need to reject this report and tell the sender what you expect to see.
David DeLong
#18
I reviewed the chart and it is sooooooo out of control in the averages that the Cpk is not valid.
Here are some of the conditions that could give you such a chart:
1
Your gauge uses too much of the tolerance. One must perform an R & R study and then achieve no more than 10% of the total variation (or state of the art).
2
Your sample size is not homogeneous. If one has a 12 station machine (each station affects the dimension) and you are using a 5 piece sub group, the averages would be reflect as shown in your sample. A 6 station machine should have a sample size of 6 while the 12 station machine uses 12.
3
David DeLong
#19
3 The samples were taken in different locations.
Sorry but I hit the wrong button previously.
By the way, one does not have a LCL on the ranges chart unless your sample size is very large, say 15.
Hope these thoughts help out.
#20
The chart shows zero as the lower bound, which is correct. While you're correct in stating that for this case there is no LCL, the software apparently adds the label anyway, which makes no difference one way or the other because the range can't be a negative number.
G Target Specification based on Cpk Requirements Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Cp, Cpk for One Sided Specification Statistical Analysis Tools, Techniques and SPC 2
R Transfering Cpk specification to 100% inspection specifications Capability, Accuracy and Stability - Processes, Machines, etc. 24
M Cpk with LSL (Lower Specification Limit) at zero? Statistical Analysis Tools, Techniques and SPC 3
F Ppk/Cpk value with 1-sided specification - Only given a lower specification Statistical Analysis Tools, Techniques and SPC 1
D Can Minitab Return specification limits required to achieve a given Cpk? Using Minitab Software 11
B Cp, Cpk, Sp, Spk for a one-sided minimum specification Capability, Accuracy and Stability - Processes, Machines, etc. 2
C Calculating Cp and Cpk for Product with only LSL (Lower Specification Limit) Capability, Accuracy and Stability - Processes, Machines, etc. 28
C Capability index for one-sided specification? Cpk(max) = (USL-Xbar)/3*s ?? Capability, Accuracy and Stability - Processes, Machines, etc. 13
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
