Re: CPK 1.99 But Out of Specs Detected in Control Chart
let's restart the thread questions:
we really need the raw data and the spec limits to give you an answer that isnt' a guess.
the other question that I would ask you to ask your supplier is: what FORMULA was used to calculate Cpk? the traditional original formula uses the within sample standard deviation isntead fo the total standard deviation. So the original formula will give you an overestimation of the Cpk value vs what you really want to see. given the PDf you attached - the software is really old (or probably nased on older software) and I woudl suspect the formula first - but again without the raw data it's jsut a guess like any one else's guess.
That said I agree with Steve P - the Cpk thing is a waste. plot your data and look at your data.....that is the best way but it takes work.
Kidding aside, something is either out of control or it isn't. You can't just separate the point(s) beyond the limits (unless you know an anomalous outlier exists) and act like nothing happened.
