Cpk and Ppk Differences and Questions
sushant_kulkarni
Dear all,
Cpk used for Short term capability with Std. deviation with in sud-group variation.
Ppk used for Long term capabi;ity of system with Std. deviation from long time and actual process variation and sample size.
Though we are calculating Cpk or Ppk with system only stat. control then standard deviation for both the capability would be same?
How can Ppk will be less or standard deviation will be higher for Ppk.
Will it affect by common causes as well as special cause of variation?
and if it will be how can we say that system is in the stat. control?
If system isnot in the stat. control then to calulate Cpk and Ppk will be wrong.
Sushant:agree:
bobdoering
Stop X-bar/R Madness!!
Re: Cpk and Ppk differance
First - and most important question: is Cpk or Ppk even applicable? What is the process and the characteristic? Is it normal? Should it be? If not, it does not apply.
After that, yes, the process is assumed to be normal and in control (no special causes) before calculating the indices. But, that is rarely the case...it is nearly impossible to remove all special causes - although you can do it mathematically (do not include it in the capability study data). Then the difference in Cpk and Ppk depends on the source of variation.
Darius
Re: Cpk and Ppk Differences
The mathematical difference between Cpk and Ppk is the standard deviation estimate, the stdev estimate for Ppk could be greater or equal to Cpk stdev estimate (equal is there are no special causes and no trend). SPC control Chart uses the same estimate as Cpk.
The special causes affect more Ppk stdev estimate that Cpk and Control Chart stdev estimate. But all stdev estimates are affected by special causes (bigger).
The ausence of patterns, but as bob said, it could happen even with simulated data.
Cpk could be wrong (many could say this) and as Wheeler said Ppk could be also wrong because is useless obtain a value that could change too much.
I will say, as I readed somewhere: "To manage, You must measure"
Statistical Steven
Statistician
Unless of course you have a negative variance component. Remember Cpk is based on the within lot variability. PpK is based on total variation which is the sum of lot to lot and within lot variability. If the lot to lot variance is negative (a statistical anomoly), it is possible to have a Ppk that is larger than Cpk.
Hmmm....why do we use Cpk and PpK?
oooh a great question: because someone mistakenly thought that within subgroup variation (which in standard charts is piece to piece variation) represents the true common cause variation and again mistakenly mis-interpreted this to mean that Cpk was the potential capability (besides centering) of your process and that it woudl be difficult to impossible to improve upon that performance without changing the technology. Nice try but wrong on so many levels. Unfortuantely it got written into articles, then company manuals then books and now since it's published, well by golly it must be true! Statistical Sillyness...
the Ppk > Cpk (negative variance component) can happen when we use the Range method and we have 'chunky' data. This overestimates the within standard deviation making it larger than the total standard deviation. I don't see it frequently, but it's not uncommon.
Statistical Steven
Statistician
What really irks me is that it continues to gain traction. I have a client who uses Cpk and Ppk values as an acceptance criteria for a lot. When I explained that those same values can be distilled to a CV specification, they thought I pulled some statistical vodoo out of my hat. The funny part is that they tend to fail the Ppk criteria (their run to run variability is awful) but have stellar Cpk (their within run is actually very tight).
Anyway, excellent observation Bev!
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
U Cpk and Ppk for different Countries/Standards Capability, Accuracy and Stability - Processes, Machines, etc. 7
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
A How to interpret Minitab Results? What is difference in Cpk and Ppk values? Using Minitab Software 2
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
A Deciding on when to go for Cp & Cpk or Pp & Ppk Study? Statistical Analysis Tools, Techniques and SPC 3
C Understanding the relationship of Pp, Ppk, Cp, Cpk Six Sigma 4
E Cpk and Ppk template wanted Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q ASQ CSSBB Question on Cpk and PPk , can you solve it ? Capability, Accuracy and Stability - Processes, Machines, etc. 15
M Calculation of Cpk and Ppk for an unstable process Statistical Analysis Tools, Techniques and SPC 7
Q PPK, CPK of >= 1.67 Automotive Requirement and Auditing IATF 16949 - Automotive Quality Systems Standard 1
P Individual & MR chart - Ppk or Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 9
K Normality of distribution prior to Cpk and PpK Statistical Analysis Tools, Techniques and SPC 4
R Can Ppk value be greater than Cpk and if yes, under what conditions? Statistical Analysis Tools, Techniques and SPC 10
C Is it possible to get Pp,Ppk more than the within subgroup (Cp,Cpk's) indices? Statistical Analysis Tools, Techniques and SPC 7
S Are Pp and Ppk more useful than Cp and Cpk as a benchmark for further studies? Statistical Analysis Tools, Techniques and SPC 1
J Using Pin Gages as a Measurement Tool for Ppk/Cpk studies Capability, Accuracy and Stability - Processes, Machines, etc. 11
B Difference between Ppk (Preliminary), Cpk, Performance Capability Statistical Analysis Tools, Techniques and SPC 2
D Real life example of the difference between Cpk and Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 0
N Cpk vs Ppk - Which should you use and How to Calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 25
V Quality Control Index - We thought that Cpk or Ppk would be good choices Capability, Accuracy and Stability - Processes, Machines, etc. 6
Tim Folkerts Interpreting the common capability indices: Cp, Cpk, Pk, and Ppk. The Reading Room 5
J Machine issue in Cpk/Ppk and Control Plan - PPAP Submissions APQP and PPAP 5
D Use of an outlier in calculating Cpk/Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 8
N Analysis of non-normal stratified data for cpk/ppk? Rupture test Capability, Accuracy and Stability - Processes, Machines, etc. 6
F Ppk/Cpk value with 1-sided specification - Only given a lower specification Statistical Analysis Tools, Techniques and SPC 1
S Ppk/Cpk for geometrical true position of hole with MMC Capability, Accuracy and Stability - Processes, Machines, etc. 17
Howard Atkins Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values Statistical Analysis Tools, Techniques and SPC 4
S What is the meaning of "k" in Cpk and Ppk? And Cpk vs. Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 15
A Capability Indexes for ISO/TS16949 - Cpk & Ppk after PPAP Statistical Analysis Tools, Techniques and SPC 6
C I need help verifying formula's in a database for LCL UCL Cp Cpk PPk Statistical Analysis Tools, Techniques and SPC 14
