Cpk for Hardness - PPAP rejected due to no Cpk value being given for a hardness
W
WKHANNA
I just had another PPAP rejected due to no Cpk value being given for a hardness requirement that was designated as a Special Characteristic on the customers drawing. What I did supply was a certification & test results from the approved supplier we use for heat treating, along with our own test results.
They also said we have no documented control for this Special Characteristic. Our Control Plan specifies certification from the supplier along with recorded receiving inspection on each lot.
I am no expert on these matters by any means, but just how does one go about calculating Cpk for material hardness? :frust:
TIA
Bill
howste
Thaumaturge
Re: Cpk for Hardness? PPAP rejected due to no Cpk value being given for a hardness
I'm not an expert either, but I don't see why it can't be done. The distribution may or may not be normal, but I'm sure that there's variation in the hardness values. I'm sure that multiple readings can be taken, analyzed, and compared against the specification.
W
WKHANNA
Agreed, and our test measurements include the mean distribution and stdev.
But for Cpk, wouldn't the heat treater need to conduct the analysis on his process?
AdamP
We used to have this with an abradable ceramic seal coating and with one major customer, we had a requirement of stating and meeting a Cpk of 1.3. We ran the hardness and abrasion tests in-house but with each run we recorded the result, plotted it on an in-house control chart and included the test results with each shipment. The capability was established not via a single sample, but through a small sample of test coupons to prove initial capability.
I expect you can have your heat treater pull up a pile of previous results to get enough data to baseline your (their) capability with respect to the hardness testing. Assuming the control limits of your/their process fit within the spec limits of your customer, you should be able to show and control via SPC and periodic capability checks.
Cheers,
Adam
Cheers,
Adam
Doing SPC retroactively is almost never a good idea in terms of statistical rigor, but something along these lines might be enough to placate the customer. Based on the OP's description of what was submitted, I can understand the customer's dissatisfaction; the process control and reporting requirements should have been passed down to the heat treater and if there were misgivings anywhere they should have been discussed and settled in advance.
The presence of special characteristics on a customer drawing--especially in automotive work--is a big red flag that's warning you that you had better understand the customer requirements and not wait until a PPAP crashes and burns before you complain that something doesn't make sense.
bobdoering
Stop X-bar/R Madness!!
I would expect the variation to be normal -within a batch, since the variation comes from natural conditions. But, over many batches - and more importantly, lots of raw materials - it may become very multi-modal, which will confound standard capability calculations that assume normality. Now, if they wanted Cp or Pp, then it becomes a lot easier because the expectation that the mean is perfectly midway between the spec (which it will not be on skewed distributions) is not an issue.
The rubber stamped Cpk and Ppk requirement, and its subsequent assumption that the mean is perfectly midway between the spec for every characteristic of every process in control and capable, is key evidence of abject lack of understanding of process capability and distributions. But yet.....it is carved in stone. It is rampant normalcentricity syndrome.
Kales Veggie
People: The Vital Few
Be careful with "within a batch". Depending on batch size and available material from the same heat, material variation has to be taken into account.
Kales Veggie
TIA
Bill
To calculate Cp or Cpk the distribution has to be normal. Unlikely that the distribution will be normal.
This requirement should have been flowed to the Spec. Char. requirement to the sub-supplier, so they should have SPC in place and you can review their data to determine normality and attempt to calculate a Cpk.
The hardness is probably just a minimum requirement.
Also the question: Is it through hardened or case hardened? Then is case depth a Special Char.?
W
WKHANNA
I agree totally, however our customer has recently adopted new standards of acceptance relative to PPAP review, and simply began rejecting submissions that previously would have been accepted.
Additionally, the parts in question are for a new product that were designed with GE&T and Hardness specs being listed as Special’s for the first time.
I understand that I am responsible for insuring our processes are capable, but instead of giving advice on what their acceptance standards are, I just get emails with demands for Cpk values on things like surface profile & ‘no burrs’.
bobdoering
That's correct, when you get to long term between batches, it can become multimodal. If the material variation over time is also normal you may ultimately have a net normal distribution - perhaps over 3 to 5 years time - depending on how many batches of raw material are processed over time.
None of which is what an SQE wants to see - or ponder. They want a number to meet the ethereal specification.
C Hardness Testing - Low Cpk's using Minitab Misc. Quality Assurance and Business Systems Related Topics 10
W MSA on a Hardness Tester to satisfy a Customer who is requiring Hardness Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Convincing Management Cpk without Stability is Meaningless Capability, Accuracy and Stability - Processes, Machines, etc. 7
L Cpk after Data Transformation - How to Transform LCL /UCL to get Capability Report Capability, Accuracy and Stability - Processes, Machines, etc. 8
