W
I have been struggling with this issue for months.
Can someone please review my methods and tell me if I am doing this correctly?
I have a GD&T for position to within .016" of a supplied powder metal gear that is pressed onto the knurled portion of a shaft that we fabricate in-house. Our process control on the knurl form is excellent & Cpk on knurl diameters at this machine is >2.8 with a tolerance of +/-.002.
I only have 30 measurements since this was the total production run for the customer's order for which I must supply a full PPAP. The customer is a V large US corp who does not care that the sample is far too small to yield meaningful data. They simply insist I supply data that provides a process Cpk of >1.33 for the specified characteristic.
I have entered my data into Minitab using the ‘Normal’ Capability Sixpack.
The entry for the Lower Spec has been left blank.
The entry for the Upper Spec is .016.
The entry for sigma Tolerance is 3.0.
Cpk results to 1.43 for my data.
Aside from the sample being far too small & the fact that this is an assy fit which obviously is a multi modal function, I am close to correct in my use of Minitab?
Regards,
Bill
Regards,
Bill
Stunning.
