Cpk Help needed - Explain to me where I made a mistake
silvestri
Hi all,
I taught to be a SPC expert but my vanity has been punished by the Gods.
When you find, in a capability sample, even one measurement outside the tolerance range, at least the Cpk must be < 1 ?!? Right???
It's incredible, I have found a sample where one item is smaller than the lower tolerance limit and Cpk 1,79 !!
It's the 3rd time I rewrite all the formulas and result is always the same.
Could someone take a look to the attached worksheet and explane me where I mistake?
Thanks.
E
Eric York - 2010
You calculations are correct. Why do you say Cpk must be less than 1 if one measurement is outside your spec limits? In your example the process is well centered and has extremely low variability with the exception of the one outlier.
Remember, from an intuitive perspective Cpk is a measure of 'centering' and 'spread' of your overall process with respect to your spec limits. Look at the calculation of Cpk. What goes into it? xbar, s, and your spec limits. Nowhere do you see mention of individual measurements. Sure, one outlier can have a big effect on the mean. But in this case you have 49 measurements almost exactly in the middle of your spec range, and only one outlier.
Here's an exercise: look at the difference in mean, std dev, and Cpk if you eliminate that outlier!
Eric
G
gszekely
Re: Bloody Cpk! Help needed
Hello Silvestri !
I'm not an SPC guru, but where from you got the info, that if 1 point is out of tolerance, your capability index should be less than 1 ?
I put your data in my excell sheet, got the same results as you got.
I put nominal dimension 1,8 and subgroups of 5.
I think that there will be some more inputs.
BR
Gy
E
Eric York - 2010
Of course you are correct! The difference between Ppk and Cpk is that in Ppk one uses the sample standard deviation instead of the overall process sigma, and that Ppk can be misleading if s is not truly representaive of sigma. I've become complacent ...
silvestri
Thank you very much to all.
I must surrender to the evidence that one point outside specs limits doesn't cause capability indexes to be < 1. (I am so glad my formulas still work):eek:
But, if you are interested in this thread, what would you do if you were in this situation: would you validate the starting of production of this process or not?
Thank you again for your help
dendy
Based on the data gathered, there was probably a measurement error or a deviation in raw material. The process is valid but I would have a second look at the nc part. Let me guess: this is probably a stamping operation?
Y
Yew Jin
Hi guys,
Below is my 20cents.
It is very important to ensure our data is in the normal distribution before we conduct the process capability study.
By using the Anderson Darling normality test on the data, the data is not in normal distribution.
We are based on the assumption that the data represent a sample from a normally distributed population to study the Capability indexes. Thus, it is necessary to correct for nonnormality in the data when using the normal capability analysis procedures. If the observations come from a skewed distribution, the capability indexes such as ppk and cpk may look "good", yet many units will still be "out of spec".
silvestri
Thanks Yew for this suggestion. Following your suggestion, I have just downloaded an excel sheet for a normality test. I think I will implement in our Cp-Cpk figures sheet.
Yes Dendy, it's a process very near to stamping. This variable and the sample are referred to crimping of terminals on electric wires.
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
M Can I get a Cpk out of my data? Minitab help Using Minitab Software 1
J Six Sigma homework help - Cp and Cpk with USL Six Sigma 7
J Methods used to calculate Cpk value - Need help for Cpk Calculation Statistical Analysis Tools, Techniques and SPC 8
C I need help verifying formula's in a database for LCL UCL Cp Cpk PPk Statistical Analysis Tools, Techniques and SPC 14
B Cpk for 3D data - Capability study from CMM data- Need Help Capability, Accuracy and Stability - Processes, Machines, etc. 1
X Need help / feedback on Xbar/R charts and Cpk/Ppk applicability - Assemblies Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
