Cpk Measurement for Knee Implants on CMM Machine
V
validationeng
Hope you can help here in guys...
I need to do a cpk analysis in relation to knee implants we are making...a few details.
1. We have made 36 seperate parts (knee implants) on a CNC as part of
validation
2. One of the CTQ's is tray thickness. This is measured across 8 different
points along each of the 36 parts.
My question is should I average out all the 8 tray thickness values the CMM gives along each of the 8 points for one part and then do the same for the other 35 parts. ...than do the cpk on these 36 values.....or
Do I need to seperate the 8 points i.e Tray thickness 1..tray thickness 2.....right up to tray thickness 8 and treat them as 8 seperate CTQ's....effectively geting 8 seperate CTQ values...i.e for tray thickness 1 I would take the value for it on all 36 parts and run cpk analysis.....then do same for tray thickness 2,3,4,5,6,7 &8 in the same way and thus eventually ending up with 8 cpk analysis values
All vey complicated but any advice is appreciated !!
JAltmann
If it was me looking at the data i would probably output 8 points individually. I might then teat them as a sub-group of 8 in the statistically calculations.
I am assuming these ribs are machined features?
P
Pat McGhie
Based on the data you presented and the fact that it is labeled a CTQ, I would most likley do a Cpk on each of the 8 points seperate, so yes, I would agree with the 8 individual Cpk analysis values.
It may be just as effective to do an average (and depending on the customer that may be ok) but as you will measure all 8 anyway, I would tend to just report them each as an individual.
Pat in NH
it really depends on the variation between the 8 points and the 36 pieces. If there is a systematic difference the 8 locations the statistical analysis must take into account the 'fixed' effect of the 8 locations. If the variation between the 8 points appears random or is much smaller than the difference between the 36 parts then allof th edata can be essentially be treated as the same and you woudl use all 36*8 points in a single calculation.
If you would post your data we can help you determien the correct analysis to apply. It might also be helpful if you could describe the process by which the 'tray' dimension is created.
bobdoering
Stop X-bar/R Madness!!
First of all, you are looking for process capability. In order to accurately do this, you need to compare the process over time – apples to apples. That means, you need to treat each point separately. Averaging just dilutes the value of the data.
What is the source of variation from part to part? Over those 36 parts, were the tools used changed? Were there any adjustments made? If so, why, and what triggered the change? If not, then the only variation you should see is tool wear. Now, how you handle the capability depends on how you handle the process.
When and how is the process adjusted over time? Are any of these points SPC charted for process control? If so, with what charting?
Sure, you might think what do all of these questions have to do with dumping data into a formula and calculating Cpk?
One answer: everything.
S Cpk is lower because of Measurement Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
W Plotting Cpk as Function of Measurement Event Capability, Accuracy and Stability - Processes, Machines, etc. 8
F Throughput time measurement Cpk summary Capability, Accuracy and Stability - Processes, Machines, etc. 2
F Cpk 1.99 But Out of Specification Measurement Detected in Control Chart Reliability Analysis - Predictions, Testing and Standards 36
J Using Pin Gages as a Measurement Tool for Ppk/Cpk studies Capability, Accuracy and Stability - Processes, Machines, etc. 11
M Cpk for attribute data? Performing SPC on capacitors - Capacitance measurement Statistical Analysis Tools, Techniques and SPC 9
E Cpk's, specifications and tiny sd's - Resolution of measurement equipment Capability, Accuracy and Stability - Processes, Machines, etc. 20
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
