Cpk's, specifications and tiny sd's - Resolution of measurement equipment
Statistical Steven
Statistician
#21
If the gage only reads to the 0.01, then the raw data should only be to that level of significance. You can have as many decimal places as you like in calculated values. But when you report the mean or sd, you need to round to 0.01. I trust the JMP output, as long as the raw data was correctly rounded.
D Use of Customer Specifications to calculate Cpk IATF 16949 - Automotive Quality Systems Standard 13
R Transfering Cpk specification to 100% inspection specifications Capability, Accuracy and Stability - Processes, Machines, etc. 24
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Cpk relation to Reliability Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Convincing Management Cpk without Stability is Meaningless Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Hardness Testing - Low Cpk's using Minitab Misc. Quality Assurance and Business Systems Related Topics 10
