student without holiday
As I read in this forum before the Cpm-index uses every measurement and not only the means of a sample.
But when you take samples of different sizes during measuring the Cpm-index gets more influenced by the values of the larger sample sizes.
For exemple: someone working in a laboratory has to weigh fluids. He takes sample sizes of 4. This person is a bit awkward and now and then drops a bottle with fluid. So the sample size drops to 3. At the end of the measurements he wants to know the Cpm of the weight. If he uses al the measurements the samples of 4 have more effect than the samples of 3. What should he do ??
When he uses an overall sample size of 3 he has made to much measurements and he wants to use them all. (because for example he had used an expensive method for weighing)
greetings
greetings
