CQA EXAM
GStough
Study, study, study! Try to get as much experience (after you've completed qualified training course/s) as you can before you take the exam. This will help more than you might think. Remember, you can bring reference material into the exam with you (it's open book). Also, be sure you stay hydrated and drink water. Purchase the practice exams and go through them. When the time comes to take the exam, go through the whole thing answering the easiest questions first. Save the harder ones for later. Repeat that process until you've completed all of the questions.
Tidge
I don't know how the computer-base exams work, but when I was taking the paper-based ones, here was my strategy:
  • I made a first pass, spending 0.5 to 1 minute on every question, answering it and/or categorizing it per the BoK. I flagged questions that I did not answer that I had to come back to.
  • After the first pass, I went back and revisited the unanswered questions, by BoK area.
  • I have a bad habit of trying to solve "math problems", so I always left them for last, so as to not accidentaly spend too much time on them.
  • The ASQ exams are multiple-choice, so the correct answer can be found by eliminating the distractors (wrong answers). When the question bank is supposed to include plausible distractors, but in my experience (taking exams, writing & reviewing questions for the question bank) there are often many questions that are one correct answer and nothing else but implausible distractors. This is also true of the "math problems", often it is just a question of eliminating the answers that are not mathematically possible. (There is not much in the CQA exam)
The exams are "open book", but the folks I know who have not passed an ASQ exam often spent too much time looking up answers. My advice to divide up questions by BoK area allows the test taker to stay in one section of their preferred reference material for many questions at once.
When I took the CQA exam, I had my study guide (no sample tests are allowed!) and my copy of the ASQ "Z tables" (Z1.4, and Z1.8) in case I needed to answer a specific question about sampling. I think I also kept printed copies of a couple of basic math tables (fractional area under a normal distribution, a table of binomial distribution calculations for hypothesis testing for a handful of one-sided alphas (and 2 different powers).
The CQA exam is IMO, one of the easier ones to take/pass.
Tidge
Now, as for preparation....
Keep the BoK close at hand, as it will very clearly layout the areas to consider and the fractional breakdown (i.e. how many questions to expect in what areas). Many of the ASQ certification BoK rely on common, foundational areas:
  1. General Quality Concepts and History
  2. (Project) Planning and Execution.
I wanted to call these out specifically, because if you borrow resources that others have used for different ASQ exams, material that covers those topics will be useful to CQA certification. That is, those parts of a CQE primer will help just fine. Audit Planning will be something covered in the BoK, and you should study that specifically, but having a general understanding of project planning will be very helpful. If there is any difference between the academic study of audit planning and project planning, it is that generally audits don't "go wrong" (for the auditor!) so project risk management isn't as fundamental for CQA certification.
I also recommend the QCI primers, with one caveat (for ASQ certifications). The caveat is that the questions used in the ASQ question banks derive (or are supposed to) derive from primary resources and not from primers. This means that there will almost certainly be some small amount of terminology used in at least one question (or answer, or distractor) that isn't used in the QCI primer. There is no inoculation against this, you simply have to be widely read enough to have encountered the different terminology. This isn't meant to be a trap, it is more that the primary source used in the question bank may have used terminology that is consistent in its area but not common in others. Question writers have to identify their primary sources for questions and answers, and IIRC they are also supposed to rationalize the plausible distractors. When I took the CQA exam, I specifically remember that for one question there was a term used for a type of sampling I had never encountered before (and was not in my reference material... and it was pretty rare in a post-exam Google search), but I recognized all the other terms as wrong answers. If a single question misleads almost all test takers in the same way, I believe ASQ essentially discards the question from that exam's results and flags it in the question bank.
John Predmore
Read each multiple-choice question carefully. Sometimes the most-correct answer is settled based on a single word in the question. I also like the QCI study guide, which not only gives prior test questions and answers, but explains WHY one answer is the most-correct answer.
Not sure if they still conduct these tests early in the morning, but if so, I have found an energy drink to be a great help before the test. There used to be some good guides in the resources section (or attachments, I don't rightly remember).
H CQA Exam - Do I really have to go five hours without a drink? Professional Certifications and Degrees 4
M What CQA Preparation Material helped you to pass the exam? Career and Occupation Discussions 6
S What Reference Material is allowed in the ASQ CQA Exam ? Professional Certifications and Degrees 1
J Study Materials for the CQA Exam June 2, 2012 Professional Certifications and Degrees 17
M ASQ CQA Exam June 4, 2011 - Best resource for preparation Professional Certifications and Degrees 19
M CQA (Certified Quality Auditor) Certification Exam Materials Professional Certifications and Degrees 3
C Need your guideline for CQA exam Professional Certifications and Degrees 3
W CQA exam qualification Professional Certifications and Degrees 7
P Auditing Process Classics - I am planning to take CQA exam Professional Certifications and Degrees 5
C Bringing a CQA Primer Copy for an exam Professional Certifications and Degrees 14
G I passed the ASQ-CQA (Certified Quality Auditor) exam Professional Certifications and Degrees 12
B ASQ - CQA (Certified Quality Auditor) exam next week !! Professional Certifications and Degrees 18
T What is the best primer to study for the ASQ CQA exam? Professional Certifications and Degrees 2
A Quality Council of Indiana - ASQ's CQE and CQA Certification exam materials Professional Certifications and Degrees 23
Q Passing CQA Exam - Passed on first attempt? Second? A Poll General Auditing Discussions 22
R CQA Primer by the Quality Council of Indiana ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C CQA Test Questions Bank General Auditing Discussions 1
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
M Differences in CQE, CSTE, CSQA, CQA Professional Certifications and Degrees 3
R CQE vs CQA vs CSSGB vs CWI Professional Certifications and Degrees 0
P Differences CSQA vs CQA ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
P What certifications to take CQA? Software Programmer Career and Occupation Discussions 1
H RABQSA ISO 9001:2008 Lead Auditor or ASQ CQA - Which certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
H Choosing between RABQSA Lead Auditor or ASQ CQA Certification Professional Certifications and Degrees 2
T ASQ CQA (Certified Quality Auditor) - Self - study help Professional Certifications and Degrees 3
J ASQ CQA, RABQSA Internal Auditor, or IRCA Internal Auditor Professional Certifications and Degrees 11
G ASQ CQA Certification vs. RABQSA or IRCA Lead Auditor Certification Professional Certifications and Degrees 7
R CQE and CQA Training Books/Materials and related Quality Jobs Professional Certifications and Degrees 6
Q CQA (Certified Quality Auditor)? I need all the help I can get. Professional Certifications and Degrees 3
C RABQSA or IRCA or CQA (Certified Quality Auditor) - Biomedical Professional Certifications and Degrees 3
B Quality Auditor Certification - CQA Professional Certifications and Degrees 12
J Passed ASQ CQA. Next ASQ CQT Professional Certifications and Degrees 3
S ASQ Recertification Units (RUs) for my CQE,CQA Recertification Journal ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 9
B CQA vs. CQE - How tough is CQA test compared to CQE test? Professional Certifications and Degrees 18
kedarg6500 Difference in CQE (Certified Quality Engineer) & CQA (Certified Quality Auditor) Professional Certifications and Degrees 5
A CQE or CQA - Which one is better in terms of career progress Professional Certifications and Degrees 11
ScottK RABQSA Certification for ASQ CQA's - Some Questions Professional Certifications and Degrees 3
A What are the best CQE & CQA preparation books? Book, Video, Blog and Web Site Reviews and Recommendations 7
J ASQ's CQA, CQT and CMI Certifications - NEW Sample exams release Professional Certifications and Degrees 5
L Impressions of the CQA test and new BoK (Body of Knowledge) Professional Certifications and Degrees 10
howste New ASQ CQA (certified quality auditor) body of knowledge (BOK) General Auditing Discussions 7
J How to drive CQA - Customer Quality Assurance Nonconformance and Corrective Action 4
S CQA vs. Six Sigma vs. CRE - Which certification should I persue? Professional Certifications and Degrees 7
L ASQ CQA (Certified Quality Auditor) Test - Any advice for me? Professional Certifications and Degrees 6
J Can an ASQ CQA train internal auditors? Internal Auditing 2
B CQA plus RAB training = QSLA status? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 4
P 9104 _1A Exam AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Online/self-paced ASQ CRE Exam Prep Reliability Analysis - Predictions, Testing and Standards 1
R Does anyone know how ASQ exam requirements are verified? Professional Certifications and Degrees 3
D Regulatory Affairs Certification (RAC) Devices Exam - Autumn 2022 study Professional Certifications and Degrees 3
