CQI-12 - Applicability to Raw Materials
Hello all.
I am more or less pasively monitoring some interesting discussions, but now I bumped into a problem, where our customer requires us to get CQI-12 self assessment from our suppliers of lamination steel for electromotors and rotor/stator stacks which we produce. Because this steel is coated with thin layer (one to several microns) of insulation in order to reduce losses in the electromotor. We forwarded the request to our suppliers and from one got the following answer: "According to our experts the CQI-12 is only applicable for „customer specified parts“. We however do not supply parts but instead raw material.", which is true. The insulating of the lamination steel is a regular 100% part of the process for the final coil that is then sold and processed by companies similar to ours. This coating is not purchased service nor it has any appearance issue. There is nothing special in suppliers process. I believe that our supplier has a point here so I would like to hear from you also. Thank you for eventual opinions. Regards. Miro Šmid, Domel. d.o.o., Slovenia
Coury Ferguson
Moderator here to help
Hello all.
...experts? Who have they identified as their experts ("According to our experts the CQI-12 is only applicable for „customer specified parts“. We however do not supply parts but instead raw material.") ?
Reference ISO9001:2015, para. 8.2.2 Determining the requirements for products and services which states in part:
"the requirements for the products and services are defined, including: 1) any applicable statutory and regulatory requirements; 2) those considered necessary by the organization;"
ISO9000:2015: 3.7.6 product
output (3.7.5) of an organization (3.2.1) that can be produced without any transaction taking place between the organization and the customer (3.2.4)
Who is the customer?...I would guess it is your organization. The way I read this, and I could be wrong in my interpretation, their experts are not correct in my opinion. If you have flowed down CQI-12 or your customer has, they would be required also to comply. Just my opinion.
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
H CQI-15 2nd Edition - Date of initial assessment? IATF 16949 - Automotive Quality Systems Standard 3
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 3
E Does CQI-23 (Molding Sys. Asses.) apply to RUBBER molding? IATF 16949 - Automotive Quality Systems Standard 2
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
Sidney Vianna Informational The role of the quality professional - an interesting video by CQI Quality Manager and Management Related Issues 1
L CQI & IRCA not accepting new applications for ATPs (Approved Training Partner) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
B CQI-15 Welding System Assessment - Required for all of the welding processes we have? IATF 16949 - Automotive Quality Systems Standard 2
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
R ASQ, CQI,............where else ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B Where do CQI Assessment requirements come into play? IATF 16949 - Automotive Quality Systems Standard 2
K CQI-23 Molding System Assessment Scope IATF 16949 - Automotive Quality Systems Standard 3
M CQI-9 monitoring of temperature in die Various Other Specifications, Standards, and related Requirements 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
J CQI-9 - Can OEM do Oven Studies? Reliability Analysis - Predictions, Testing and Standards 1
C IATF Cl. 9.2.2.2 Quality Management System Audit - CQI-23 Molding System Assessment IATF 16949 - Automotive Quality Systems Standard 1
W IATF 16949 Annex B: CQI Requirements IATF 16949 - Automotive Quality Systems Standard 1
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G AIAG CQI-Audits and Auditor Training ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
L CQI-12 2nd Edition - Table D, question 2.1 - Powder Coat Painting IATF 16949 - Automotive Quality Systems Standard 2
A CQI-9 and DI Water vs. Distilled Water IATF 16949 - Automotive Quality Systems Standard 2
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
xfngrs CQI-19 Sub-Tier Supplier Management IATF 16949 - Automotive Quality Systems Standard 1
V Concerning CQI-15 Welding System Assessment Form Document Control Systems, Procedures, Forms and Templates 1
xfngrs New AIAG Special Molding Assessment CQI-23 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 17
Stijloor AIAG Layered Process Audit 2nd Ed. (CQI-8) is now available. IATF 16949 - Automotive Quality Systems Standard 1
E CQI-7T Form - AIAG Process Identification Tool 95-2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Am I qualified to take the CQI Exam? Professional Certifications and Degrees 2
T The 'CQI' as a Professional Qualification - advantages? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
K ASQ CQI Exam Questions Professional Certifications and Degrees 16
P Level 5 CQI Diploma in Quality (Assurance and Management) Covegratulations 7
I New AIAG CQI guidelines published - Are they worth buying? Misc. Quality Assurance and Business Systems Related Topics 2
J Do any of you send the whole CQI-9 System Assessment to your Customers? IATF 16949 - Automotive Quality Systems Standard 4
K ASQ Certified Quality Inspector (CQI) Training Help Training - Internal, External, Online and Distance Learning 6
O CQI-9 V3 - Ammonia Residue Test in Furnace Atmosphere General Measurement Device and Calibration Topics 3
C New Ford CQI 15 Rollout Requirement and reference to ESBC24-5005-AB IATF 16949 - Automotive Quality Systems Standard 3
R CQI-9 Heat Treat Assessment Services recommendations wanted IATF 16949 - Automotive Quality Systems Standard 3
V Is the CQI-9 Heat Treat Assessment performed by a 3rd Party Auditor APQP and PPAP 1
J CQI-9 Table E, 4.1 - Heat Treating Process Requirements Other ISO and International Standards and European Regulations 2
R CQI-15 As Related to UltraSonic Plastics Assembly Customer and Company Specific Requirements 1
P Metal Tape Plating Process - CQI-11 Required? IATF 16949 - Automotive Quality Systems Standard 2
M CQI-11 & CQI-12 Version 2 - Changes from the previous version IATF 16949 - Automotive Quality Systems Standard 3
T CQI-9 3rd Edition - The CD does not match the book from the AIAG IATF 16949 - Automotive Quality Systems Standard 3
V CQI-9 Heat Treat System Assessment Other ISO and International Standards and European Regulations 11
A CQI-11 and 12 assessor's Evidence in 2. IATF 16949 - Automotive Quality Systems Standard 5
