CQI-12 Internal Audit required by Chrysler - What if we're late?
L
LoriK
Does anyone know what "penalty" is for not having the audit completed by Jan 7, 2008? The date is a Chrysler requirement. My external auditor told me during his last visit in Nov. he will be expecting it see it completed (on time).
Kales Veggie
People: The Vital Few
Re: CQI-12 internal audit
What can the external auditor do? Probably will write a minor non-conformance. If there are customer requirements not followed, he can elevate to a major. You do not want to go there.
You can start the audit before his arrival, show some of the interim resutls. This might help convince him not to write an N/C.
What prevented you to do an CQI-12 audit before the next surveillance visit?
D.Scott
The CQI-12 as well as the CQI-9 and CQI-11 are customer specific requirements and would be audited as such. Not meeting this customer requirement would be the same as not meeting any other customer specific requirement. The auditor would issue you an N/C. You will have to provide a corrective action which should include doing the audit.
It will be in your interest to have the audit completed on time if at all possible. First, your customer relations could be compromised if you don't and second, you open yourself up for extra work if you get an N/C. You won't get away with just doing the audit. You will be expected to provide a corrective action for the systemic root cause. This can sometimes be harder than just doing the audit.
One additional comment about the CQI's - these may be discussed as simple audits but they are also a confirmation that the underlying requirements of control are actually in place and documented. For example if you do Dip/Spin, viscosity cups must be verified every 2 months minimum; paint temperature, viscosity and volume must be monitored (and documented) 3 times per shift minimum. Once the system is in place and running smoothly the audits are easy. It is the "getting ready" part that presents the challenge.
Good luck.
Dave
LoriK
For the benefit of other readers, can you let us know what the Chrsler requirement fromCQI-12 is? There are many interpretations of this 'audit' so it would help you to get some more informed advice.
Thanks!
L
LoriK
It wasn't done on time for any good reason. Lack of help, time, resources, interest. Nothing I would be able to put into a corrective action. It's a pretty specific process and not any internal auditor can complete without a subject expert available. We will have it ready for our May audit, but there will be several actions that will be identified but not be corrected.
Kales Veggie
The audit is broken into two sections. A system section, which an internal system auditor could do. One section would be completed. The job audit would need involvement of an expert (process engineer?).
Remember it is a self-assessment.
Chrysler requirement:
4.2.9.2.3 Coating Processes
Clause 8.2.2.2 of ISO/TS 16949:2002 requires that the organization shall audit each
manufacturing process to determine its effectiveness. Applicability and effectiveness of coating
processes shall be determined utilizing CQI-12 Special Process: Coating System Assessment
published by the AIAG. The effectiveness evaluation shall include the organization’s selfassessment,
actions taken, and that records are maintained.
This requirement shall also apply to coating suppliers to the organization pursuant to Clause
7.4.1.2 (supplier development clause). For Chrysler, all suppliers coating components shall
comply with CQI-12. Required implementation of CQI-12 Special Process: Coating System
Assessment is 7 January 2008.
Note 1: 2nd Party assessment by a competent auditor and meeting the above requirements will
satisfy the self-assessment requirement.
Note 2: Implementation effectiveness should be based on evidence that the organization has a
process in place that includes elements such as auditors identified, schedule for self-assessment
in place including schedule adherence, supplier development process identified for applicable
suppliers, monitoring of progress, defined corrective action process and record-keeping.
L
LoriK
LoriK
For the benefit of other readers, can you let us know what the Chrsler requirement from CQI-12 is? There are many interpretations of this 'audit' so it would help you to get some more informed advice.
Thanks!
I'm not sure if this is what you were asking for...This is straight from the Chrysler Specific Requirements:
Clause 8.2.2.2 of ISO/TS 16949:2002 requires that the organization shall audit each manufacturing process to determine its effectiveness. Applicability and effectiveness of coating processes shall be determined utilizing CQI-12 Special Process: Coating System Assessment published by the AIAG. The effectiveness evaluation shall include the organization’s selfassessment,
actions taken, and that records are maintained. This requirement shall also apply to coating suppliers to the organization pursuant to Clause 7.4.1.2 (supplier development clause). For Chrysler, all suppliers coating components shall comply with CQI-12. Required implementation of CQI-12 Special Process: Coating System Assessment is 7 January 2008.
Note 1: 2nd Party assessment by a competent auditor and meeting the above requirements will satisfy the self-assessment requirement.
Note 2: Implementation effectiveness should be based on evidence that the organization has a process in place that includes elements such as auditors identified, schedule for self-assessment in place including schedule adherence, supplier development process identified for applicable
swarbur4
I have 1 question, how far down the supply train does the requirements go for CQI audits.
Example - 1st tier supplier provides finished transmission. Does CQI on the parts they manufacture. They also purchase finished parts so 2nd tier supplier does plating, heat treatment etc so do they need to do CQI audits, some of the 2nd tier suppliers buy components that have heat treatment, so does the 3rd tier supplier need to conduct CQI audits, and if the 3rd tier supplier contracts out to a 4th tier supplier for thye heat treatment do they need to do the CQI audit. It is not that clear in the TS16949 customer specific requirements and could be read as only 1st tier suppliers and 1st tier suppliers contracted out parts for special treatment.
Simon
W CQI-9 Testing Fluids Manufacturing and Related Processes 0
R CQI 9 site specific IATF 16949 - Automotive Quality Systems Standard 3
B CQI-15 Welding Health Chart Frequency IATF 16949 - Automotive Quality Systems Standard 1
I CQI-15 Welding System Assessment 2nd edition - Does not require Ultrasonic Welding anymore? Customer and Company Specific Requirements 0
W CQI-15 for new welding process IATF 16949 - Automotive Quality Systems Standard 3
J CQI-9v4 Alternative TUS Testing Methods Various Other Specifications, Standards, and related Requirements 1
Q CQI-26 SPC Short Run Supplement Capability, Accuracy and Stability - Processes, Machines, etc. 1
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
H CQI-15 2nd Edition - Date of initial assessment? IATF 16949 - Automotive Quality Systems Standard 3
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 3
E Does CQI-23 (Molding Sys. Asses.) apply to RUBBER molding? IATF 16949 - Automotive Quality Systems Standard 2
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
Sidney Vianna Informational The role of the quality professional - an interesting video by CQI Quality Manager and Management Related Issues 1
L CQI & IRCA not accepting new applications for ATPs (Approved Training Partner) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
B CQI-15 Welding System Assessment - Required for all of the welding processes we have? IATF 16949 - Automotive Quality Systems Standard 2
S CQI-12 - Applicability to Raw Materials Customer and Company Specific Requirements 1
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
R ASQ, CQI,............where else ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B Where do CQI Assessment requirements come into play? IATF 16949 - Automotive Quality Systems Standard 2
K CQI-23 Molding System Assessment Scope IATF 16949 - Automotive Quality Systems Standard 3
M CQI-9 monitoring of temperature in die Various Other Specifications, Standards, and related Requirements 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
J CQI-9 - Can OEM do Oven Studies? Reliability Analysis - Predictions, Testing and Standards 1
C IATF Cl. 9.2.2.2 Quality Management System Audit - CQI-23 Molding System Assessment IATF 16949 - Automotive Quality Systems Standard 1
W IATF 16949 Annex B: CQI Requirements IATF 16949 - Automotive Quality Systems Standard 2
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G AIAG CQI-Audits and Auditor Training ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
L CQI-12 2nd Edition - Table D, question 2.1 - Powder Coat Painting IATF 16949 - Automotive Quality Systems Standard 4
A CQI-9 and DI Water vs. Distilled Water IATF 16949 - Automotive Quality Systems Standard 2
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
xfngrs CQI-19 Sub-Tier Supplier Management IATF 16949 - Automotive Quality Systems Standard 1
V Concerning CQI-15 Welding System Assessment Form Document Control Systems, Procedures, Forms and Templates 1
xfngrs New AIAG Special Molding Assessment CQI-23 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 17
Stijloor AIAG Layered Process Audit 2nd Ed. (CQI-8) is now available. IATF 16949 - Automotive Quality Systems Standard 1
eldercare CQI-7T Form - AIAG Process Identification Tool 95-2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Am I qualified to take the CQI Exam? Professional Certifications and Degrees 2
T The 'CQI' as a Professional Qualification - advantages? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
K ASQ CQI Exam Questions Professional Certifications and Degrees 16
P Level 5 CQI Diploma in Quality (Assurance and Management) Covegratulations 7
I New AIAG CQI guidelines published - Are they worth buying? Misc. Quality Assurance and Business Systems Related Topics 2
J Do any of you send the whole CQI-9 System Assessment to your Customers? IATF 16949 - Automotive Quality Systems Standard 4
K ASQ Certified Quality Inspector (CQI) Training Help Training - Internal, External, Online and Distance Learning 6
O CQI-9 V3 - Ammonia Residue Test in Furnace Atmosphere General Measurement Device and Calibration Topics 3
C New Ford CQI 15 Rollout Requirement and reference to ESBC24-5005-AB IATF 16949 - Automotive Quality Systems Standard 3
R CQI-9 Heat Treat Assessment Services recommendations wanted IATF 16949 - Automotive Quality Systems Standard 3
