CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable?
Z
Hello.
During our most recent IATF audit, our auditor found that we were not performing a yearly assessment according to CQI-15. This CQI is required by our customer, where applicable. Only problem is we don't have any traditional welding. We use robotic ultrasonic weld horns to adhere foam onto plastic and definitley don't have anyone in the building that meets the requirements for the assessment auditor unless robot maintenance counts. I'd like to know if this CQI still applies in our case. While there is no mention of materials directly in the CQI, next to "ultrasonic welding" in the attached assessment, specifically states "metals". Our auditor is fairly adamant about this CQI applying to our process but I feel it is not clear enough. Any insight is greatly appreciated. Thank you.
While, I am not an expert in this field, CQI-15, section 1.2 Application, states that "All requirements...are generic and are intended to be applicable...regardless of type, size and product." Furthermore, Process Table D in the same section, specifically calls out ultrasonic welding. Ultrasonic welding is also listed a total of 12 times in the document. The document consistently uses a generic "material" throughout, with few exceptions isolated to types of welding that can only be performed on a metal.
Based on this, your auditor is probably correct in their interpretation. If you still disagree, I recommend that you contact AIAG for their interpretation.
Z
Thank you Miner, for your input. After reading your response I do have to say I agree.
However our auditor got back with us this morning to let us know that since ultrasonic specifies metal in the assessment, he will be voiding that specific non-conformance. He recommended we ask for a waiver for this CQI from our customer, if they approve. Thank you for your help!
B CQI-15 Welding System Assessment - Required for all of the welding processes we have? IATF 16949 - Automotive Quality Systems Standard 2
V Concerning CQI-15 Welding System Assessment Form Document Control Systems, Procedures, Forms and Templates 1
R CQI-15 Welding System Assess. & CQI-17 Special Process: Soldering Various Other Specifications, Standards, and related Requirements 6
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 3
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
H CQI-15 2nd Edition - Date of initial assessment? IATF 16949 - Automotive Quality Systems Standard 3
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
E Does CQI-23 (Molding Sys. Asses.) apply to RUBBER molding? IATF 16949 - Automotive Quality Systems Standard 2
Sidney Vianna Informational The role of the quality professional - an interesting video by CQI Quality Manager and Management Related Issues 1
L CQI & IRCA not accepting new applications for ATPs (Approved Training Partner) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
S CQI-12 - Applicability to Raw Materials Customer and Company Specific Requirements 1
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
R ASQ, CQI,............where else ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B Where do CQI Assessment requirements come into play? IATF 16949 - Automotive Quality Systems Standard 2
K CQI-23 Molding System Assessment Scope IATF 16949 - Automotive Quality Systems Standard 3
M CQI-9 monitoring of temperature in die Various Other Specifications, Standards, and related Requirements 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
J CQI-9 - Can OEM do Oven Studies? Reliability Analysis - Predictions, Testing and Standards 1
C IATF Cl. 9.2.2.2 Quality Management System Audit - CQI-23 Molding System Assessment IATF 16949 - Automotive Quality Systems Standard 1
W IATF 16949 Annex B: CQI Requirements IATF 16949 - Automotive Quality Systems Standard 1
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G AIAG CQI-Audits and Auditor Training ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
L CQI-12 2nd Edition - Table D, question 2.1 - Powder Coat Painting IATF 16949 - Automotive Quality Systems Standard 2
A CQI-9 and DI Water vs. Distilled Water IATF 16949 - Automotive Quality Systems Standard 2
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
xfngrs CQI-19 Sub-Tier Supplier Management IATF 16949 - Automotive Quality Systems Standard 1
xfngrs New AIAG Special Molding Assessment CQI-23 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 17
Stijloor AIAG Layered Process Audit 2nd Ed. (CQI-8) is now available. IATF 16949 - Automotive Quality Systems Standard 1
E CQI-7T Form - AIAG Process Identification Tool 95-2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Am I qualified to take the CQI Exam? Professional Certifications and Degrees 2
T The 'CQI' as a Professional Qualification - advantages? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
K ASQ CQI Exam Questions Professional Certifications and Degrees 16
P Level 5 CQI Diploma in Quality (Assurance and Management) Covegratulations 7
I New AIAG CQI guidelines published - Are they worth buying? Misc. Quality Assurance and Business Systems Related Topics 2
J Do any of you send the whole CQI-9 System Assessment to your Customers? IATF 16949 - Automotive Quality Systems Standard 4
K ASQ Certified Quality Inspector (CQI) Training Help Training - Internal, External, Online and Distance Learning 6
O CQI-9 V3 - Ammonia Residue Test in Furnace Atmosphere General Measurement Device and Calibration Topics 3
C New Ford CQI 15 Rollout Requirement and reference to ESBC24-5005-AB IATF 16949 - Automotive Quality Systems Standard 3
R CQI-9 Heat Treat Assessment Services recommendations wanted IATF 16949 - Automotive Quality Systems Standard 3
V Is the CQI-9 Heat Treat Assessment performed by a 3rd Party Auditor APQP and PPAP 1
J CQI-9 Table E, 4.1 - Heat Treating Process Requirements Other ISO and International Standards and European Regulations 2
R CQI-15 As Related to UltraSonic Plastics Assembly Customer and Company Specific Requirements 1
P Metal Tape Plating Process - CQI-11 Required? IATF 16949 - Automotive Quality Systems Standard 2
M CQI-11 & CQI-12 Version 2 - Changes from the previous version IATF 16949 - Automotive Quality Systems Standard 3
T CQI-9 3rd Edition - The CD does not match the book from the AIAG IATF 16949 - Automotive Quality Systems Standard 3
V CQI-9 Heat Treat System Assessment Other ISO and International Standards and European Regulations 11
