CQI-23 - Molding System Assessment - Control of part weight
sinned
Registered Visitor
Hi all,
We are just audited by a customer and he found that we did done internal audit on CQI-23, but there is no control point on the control plan regarding measurement of the part weight. My question is: Is part weight control a must met requirement under CQI-23 ?
rgds
-dennis
Johnny Quality
Dennis,
I've had a look at my copy of CQI-23 and under item A6.15 in Process Table A - Injection Moulding it states "Part weight (if applicable)". also under item H1.8 in Process Table H - Part Inspection and Testing it states "General - Weight, Resin, Components, Porosity/Voids (if applicable)".
I would say it is not a "must" requirement unless you or your customer says so.
sinned
Registered Visitor
Dennis,
Hi Johnny,
In the injection molding table, yes, A6.15 is "Part weight (if applicable)". But at A7.1, there is no "if applicable" wording and the minimum requirement is "Start-up and once every 4 hours. For safety critical parts, start-up and once every hour". Does it mean it is a must to check weight with the specified freqency or we are violating the CQI-23 requirement ? What is your understanding on A7.1 ?
sinned
Registered Visitor
Also, ...
in Process Table H (Part inspection & test), H1.2 regarding appearance inspection, the minimum requirement is "First off by quality and 100% by operator". How can every molding factory check 100% on each part for appearance defect ?
Johnny Quality
Hi Johnny,
Hello Dennis,
I"m sorry but my copy is at work and I don't have access to the new year but I think A7.1 moves to a new process. Does the title at the top change from Injection Moulding to something else?
Also, ...
I believe that is only applicable if there is an operator on the work station. If your process is automated then surely they cannot expect you to add an operator purely for visual inspection, especially if your process is so stable it's not required.
Johnny Quality
Hi Johnny,
I'm terribly sorry but I was wrong in my answer; it doesn't move to a new process. I've been racking my brain on this and I can only assume for A6.15 they mean part weight (if applicable) may be monitored by the operator or machine? Or maybe it's an error and they mean "shot" weight instead?
As A7.1 is for QC procedures I would work with those requirements as a must for CQI-23. I'm sorry I've been confusing.
K CQI-23 Molding System Assessment Scope IATF 16949 - Automotive Quality Systems Standard 3
C IATF Cl. 9.2.2.2 Quality Management System Audit - CQI-23 Molding System Assessment IATF 16949 - Automotive Quality Systems Standard 1
E Does CQI-23 (Molding Sys. Asses.) apply to RUBBER molding? IATF 16949 - Automotive Quality Systems Standard 2
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
xfngrs New AIAG Special Molding Assessment CQI-23 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 17
Q CQI-26 SPC Short Run Supplement Capability, Accuracy and Stability - Processes, Machines, etc. 1
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
H CQI-15 2nd Edition - Date of initial assessment? IATF 16949 - Automotive Quality Systems Standard 3
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 3
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
Sidney Vianna Informational The role of the quality professional - an interesting video by CQI Quality Manager and Management Related Issues 1
L CQI & IRCA not accepting new applications for ATPs (Approved Training Partner) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
B CQI-15 Welding System Assessment - Required for all of the welding processes we have? IATF 16949 - Automotive Quality Systems Standard 2
S CQI-12 - Applicability to Raw Materials Customer and Company Specific Requirements 1
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
R ASQ, CQI,............where else ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
B Where do CQI Assessment requirements come into play? IATF 16949 - Automotive Quality Systems Standard 2
M CQI-9 monitoring of temperature in die Various Other Specifications, Standards, and related Requirements 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
J CQI-9 - Can OEM do Oven Studies? Reliability Analysis - Predictions, Testing and Standards 1
W IATF 16949 Annex B: CQI Requirements IATF 16949 - Automotive Quality Systems Standard 2
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G AIAG CQI-Audits and Auditor Training ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
L CQI-12 2nd Edition - Table D, question 2.1 - Powder Coat Painting IATF 16949 - Automotive Quality Systems Standard 2
A CQI-9 and DI Water vs. Distilled Water IATF 16949 - Automotive Quality Systems Standard 2
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
xfngrs CQI-19 Sub-Tier Supplier Management IATF 16949 - Automotive Quality Systems Standard 1
V Concerning CQI-15 Welding System Assessment Form Document Control Systems, Procedures, Forms and Templates 1
Stijloor AIAG Layered Process Audit 2nd Ed. (CQI-8) is now available. IATF 16949 - Automotive Quality Systems Standard 1
E CQI-7T Form - AIAG Process Identification Tool 95-2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Am I qualified to take the CQI Exam? Professional Certifications and Degrees 2
T The 'CQI' as a Professional Qualification - advantages? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
K ASQ CQI Exam Questions Professional Certifications and Degrees 16
P Level 5 CQI Diploma in Quality (Assurance and Management) Covegratulations 7
I New AIAG CQI guidelines published - Are they worth buying? Misc. Quality Assurance and Business Systems Related Topics 2
J Do any of you send the whole CQI-9 System Assessment to your Customers? IATF 16949 - Automotive Quality Systems Standard 4
K ASQ Certified Quality Inspector (CQI) Training Help Training - Internal, External, Online and Distance Learning 6
O CQI-9 V3 - Ammonia Residue Test in Furnace Atmosphere General Measurement Device and Calibration Topics 3
C New Ford CQI 15 Rollout Requirement and reference to ESBC24-5005-AB IATF 16949 - Automotive Quality Systems Standard 3
R CQI-9 Heat Treat Assessment Services recommendations wanted IATF 16949 - Automotive Quality Systems Standard 3
V Is the CQI-9 Heat Treat Assessment performed by a 3rd Party Auditor APQP and PPAP 1
J CQI-9 Table E, 4.1 - Heat Treating Process Requirements Other ISO and International Standards and European Regulations 2
R CQI-15 As Related to UltraSonic Plastics Assembly Customer and Company Specific Requirements 1
P Metal Tape Plating Process - CQI-11 Required? IATF 16949 - Automotive Quality Systems Standard 2
M CQI-11 & CQI-12 Version 2 - Changes from the previous version IATF 16949 - Automotive Quality Systems Standard 3
T CQI-9 3rd Edition - The CD does not match the book from the AIAG IATF 16949 - Automotive Quality Systems Standard 3
V CQI-9 Heat Treat System Assessment Other ISO and International Standards and European Regulations 11
