CQI-9 HTSA from Ford: Definition of "Normalization"
P
pog451
Hi Guys and Dolls,
I have just more or less stumbled across CQI-9 HTSA from Ford. Initially I assumed it wouldnt apply to us, as we do not run any of the processes listed in the document, but in the Ford roll-out letter it adds "brazing, annealing, sintering, and normalizing".
Its the definition of this last one that causes me to think. We have heat treatment processes for the stress-relief of bent wire parts. The process does not change the structure or composition of the material in any other way. All the other CQI-9 processes have fairly radical material changing objectives.
According to http://www.engineershandbook.com/MfgMethods/stressrelieving.htm:
"stress relieving does not change the material properties as does annealing and normalizing" which would seem to support my initial assumption but I would like to be sure.
Does CQI-9 apply?
TIA
Andrew
Brizilla
I thought I'd answer this in order to post a related question. According to Ford stress relief on bent wire forms IS a form of Heat treat and CQI-9 applies. To say
"The process does not change the structure or composition of the material in any other way. All the other CQI-9 processes have fairly radical material changing objectives."
is a misnomer. The normalizing or stress relief changes the the stress in the component. In the case of a spring and certain wire forms this will have a drastic effect on the part, especially related to torque. It may not effect the chemical composition of the part but it does effect certain properties.
Now for my question: Does section E1.2 of Process Table E of the CQI-9 Standard apply to standard continuous flow electric ovens?
We are having a debate at work on whether this applies only to gas furnaces or any type furnace or oven used for stress relief.
paccnc
Brizilla,
Did you ever get an answer to your question regarding the continuous flow ovens? We are having the same debate here at our company? Any help would be greatly appreciated. I also sent you a PM.
B New Release of CQI-12 Coatings Process (Revision 3- Release date- 7/2020) Customer and Company Specific Requirements 2
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
H CQI-15 2nd Edition - Date of initial assessment? IATF 16949 - Automotive Quality Systems Standard 3
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
B CQI-11 (Plating Audit) - New revision updates IATF 16949 - Automotive Quality Systems Standard 0
S AIAG CQI Auditor Qualification and 3rd Party Certification Requirements General Auditing Discussions 2
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 3
E Does CQI-23 (Molding Sys. Asses.) apply to RUBBER molding? IATF 16949 - Automotive Quality Systems Standard 2
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
Sidney Vianna Informational The role of the quality professional - an interesting video by CQI Quality Manager and Management Related Issues 1
L CQI & IRCA not accepting new applications for ATPs (Approved Training Partner) ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 6
B CQI-15 Welding System Assessment - Required for all of the welding processes we have? IATF 16949 - Automotive Quality Systems Standard 2
S CQI-12 - Applicability to Raw Materials Customer and Company Specific Requirements 1
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
R ASQ, CQI,............where else ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B Where do CQI Assessment requirements come into play? IATF 16949 - Automotive Quality Systems Standard 2
K CQI-23 Molding System Assessment Scope IATF 16949 - Automotive Quality Systems Standard 3
M CQI-9 monitoring of temperature in die Various Other Specifications, Standards, and related Requirements 2
C IATF 16949:2016 New CSR (CQI´s) - Share your experience IATF 16949 - Automotive Quality Systems Standard 1
J CQI-9 - Can OEM do Oven Studies? Reliability Analysis - Predictions, Testing and Standards 1
C IATF Cl. 9.2.2.2 Quality Management System Audit - CQI-23 Molding System Assessment IATF 16949 - Automotive Quality Systems Standard 1
W IATF 16949 Annex B: CQI Requirements IATF 16949 - Automotive Quality Systems Standard 1
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G AIAG CQI-Audits and Auditor Training ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
L CQI-12 2nd Edition - Table D, question 2.1 - Powder Coat Painting IATF 16949 - Automotive Quality Systems Standard 2
A CQI-9 and DI Water vs. Distilled Water IATF 16949 - Automotive Quality Systems Standard 2
E CQI 9 (Heat Treatment) Assessment Requirements - Company and Customer Requirements Customer and Company Specific Requirements 1
xfngrs CQI-19 Sub-Tier Supplier Management IATF 16949 - Automotive Quality Systems Standard 1
V Concerning CQI-15 Welding System Assessment Form Document Control Systems, Procedures, Forms and Templates 1
xfngrs New AIAG Special Molding Assessment CQI-23 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 17
Stijloor AIAG Layered Process Audit 2nd Ed. (CQI-8) is now available. IATF 16949 - Automotive Quality Systems Standard 1
E CQI-7T Form - AIAG Process Identification Tool 95-2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Am I qualified to take the CQI Exam? Professional Certifications and Degrees 2
T The 'CQI' as a Professional Qualification - advantages? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
K ASQ CQI Exam Questions Professional Certifications and Degrees 16
P Level 5 CQI Diploma in Quality (Assurance and Management) Covegratulations 7
I New AIAG CQI guidelines published - Are they worth buying? Misc. Quality Assurance and Business Systems Related Topics 2
J Do any of you send the whole CQI-9 System Assessment to your Customers? IATF 16949 - Automotive Quality Systems Standard 4
K ASQ Certified Quality Inspector (CQI) Training Help Training - Internal, External, Online and Distance Learning 6
O CQI-9 V3 - Ammonia Residue Test in Furnace Atmosphere General Measurement Device and Calibration Topics 3
C New Ford CQI 15 Rollout Requirement and reference to ESBC24-5005-AB IATF 16949 - Automotive Quality Systems Standard 3
R CQI-9 Heat Treat Assessment Services recommendations wanted IATF 16949 - Automotive Quality Systems Standard 3
V Is the CQI-9 Heat Treat Assessment performed by a 3rd Party Auditor APQP and PPAP 1
J CQI-9 Table E, 4.1 - Heat Treating Process Requirements Other ISO and International Standards and European Regulations 2
R CQI-15 As Related to UltraSonic Plastics Assembly Customer and Company Specific Requirements 1
P Metal Tape Plating Process - CQI-11 Required? IATF 16949 - Automotive Quality Systems Standard 2
M CQI-11 & CQI-12 Version 2 - Changes from the previous version IATF 16949 - Automotive Quality Systems Standard 3
T CQI-9 3rd Edition - The CD does not match the book from the AIAG IATF 16949 - Automotive Quality Systems Standard 3
V CQI-9 Heat Treat System Assessment Other ISO and International Standards and European Regulations 11
