Crack Testing of Raw Materials - Steel
Andrews
What is the most relaible and cost effective method of crack testing in Raw materials (Steel)? Our Raw material supplier is using Magnaflux testing for Raw material but he is not able to assure us 100% crack free material. What is the best type of control that will assure us 100% crack free material?
SteelMaiden
Re: crack testing
Buy turned, ground and polished stock? :rolleyes:
Andrews, what shapes are you purchasing? Are you buying rod or bar stock, or beams, plates or what? There is no such thing as "perfect" surface on steel, unless it has been "surfaced" by some sort of grinding process. The standards allow for a certain depth of crack dependent upon the diameter/thickness of the material. That being said, depending on what shapes you are talking, there is eddy-current, dye-penetrant, ultrasonic and others to assess for cracks. I have found, that nothing is 100% fail-safe 100% of the time, even dye-penetrant will miss some cracks, if they have welded shut during hot-rolling.
I'm sure this wasn't the answer you were hoping for, but without a little more information, it is difficult to recommend anything specific. Good luck!
Andrews
Thanks everybody for the response.
The raw material used by us is bright bars of sizes from 6mm to 40 mm HEX / Diameter.
Is X-Ray testing a cost effective method of testing raw material for crack?
Can Crack be avoided at the source itself? If so, what method should be used?
You would have to perform your own cost analysis to determine if the X-ray method is cost effective to you.
If you want to limit the possibility of cracks at the source discuss it with your supplier. He may have alternative methods of providing what you want.
As Steelmaiden said, nothing is 100%fail safe, 100% of the time.
atibha
Re: crack testing
sir i am also trubling with this situation so plz suggest me how to find out deep crack in raw material bar .
because i have got one complain from customer side he told that deep crack observed and its is raw material crack.
so plz suggest how to find out deep crack in Raw Material
atibha
Re: crack testing
sir can u tell how to distinguished crack of forging ,raw material and heat treatment by eyes.how to look like crak of forging ,raw material .and heat treatment
Jen Kirley
Quality and Auditing Expert
Re: crack testing
Good day atibha and welcome to the Cove.
In my experience we located deep, under-surface cracks with magnetic particle testing for ferrous materials, and ultrasonic testing for ferrous or non-ferrous metals. We used an oscillisope display, but more modern equipment may provide easier methods for "reading" the discontinuities.
For ultrasonic testing the surface should be smooth as the transducer should be able to travel without interference that might invalidate the signal.
I hope this helps!
N
ndtqc
Ultrasonic inspection is by far and away the best and most cost efficient method for detection. UT inspection is capable of setting up on reference flaws (EDM notches for both circumferential and axial scanning for surface flaws) and (flat bottom holes or side drilled holes for sub-surface flaws). Often times depending on who you are getting your steel from they will have performed some type of NDT. Magnaflux testing (actually MT) as Magnaflux is a manufacturer of MT supplies and equipment, is only good for surface flaws open to the surface or slightly subsurface. Depending on the volume of material you need to inspect I would suggest using a third-party NDT service provider for this inspection. You would need to access what you were looking for specifically (surface flaws/subsurface flaws/both) and they should be able to give you guidance on a specification. I don't recall off hand but possible AMS2154 or ASTM A388. A general inspection parameter (AMS2154 Class A w /shearwave) for bar stock would be UT inspection using a 3/64 in FBH and a 0.010 notch for surface defects. Just my opinion.
Ron Rompen Crack testing of powdered metal parts General Measurement Device and Calibration Topics 4
C Gage R&R not passing for Check Valves Crack Pressure - No Reproducibility Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Jim Wynne NASA's competence in question again - Crack found in external fuel tank foam Coffee Break and Water Cooler Discussions 6
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Bacteriostasis/Fungistasis Testing Other Medical Device and Orthopedic Related Topics 6
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Cochlear Implant Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 0
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
P Testing cloud-based backups IT (Information Technology) Service Management 7
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Flammability testing Reliability Analysis - Predictions, Testing and Standards 0
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 2
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Flammability Testing of Aircraft Interior Materials Federal Aviation Administration (FAA) Standards and Requirements 0
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
J Conflict of Interest Registrar/Notified Body/Testing House Quality Manager and Management Related Issues 4
