Creepage and Clearance for CR2032 powered fob for a Medical Device
CaliforniaMike
I am working on a small CR2032 powered fob for a medical device and my interpretation of the necessary creepage and clearance seems silly.
Basically, the lowest values that I see are 3.4mm / 1.6mm. My interpretation is that this means that I need a fuse with 3.4mm of clearance between terminals and 3.4mm all the way around the coin cell holder. This is a large portion of my available board space.
The nominal internal resistance of a CR2032 is 10 ohms so the most power that I am going to dissipate in a full short is 0.9W which is well below the 15W where this would be considered a fire hazard. Also, the entire device is enclosed in a small polycarbonate enclosure so I dont see a real hazard here.
Is there some consideration that I am missing to get me back some of the 3.4mm or am I stuck with this? Can I ask my test house to short out a few batteries from a few manfacturers and show that the enclosure does not lose integrity or become too hot and consider this a pass by testing?
Thanks,
Mike
Peter Selvey
Re: Creepage and clearance for CR2032 powered fob
You are right, the creepage limits for <50V region are silly. During a training session on the 3rd edition a few years ago I quizzed the trainer who is on the standards commitee why these large limits remained (in Table 12), but he could not answer.
It is reasonable to have creepage distance around parts to prevent failure in normal condition, however, at 3V an appropriate limit on a printed circuit board based is just 0.04mm (based on IEC 60664-1), not the whopping 3.4mm.
But, under the 3rd edition the situation is still greatly improved. First, limits for spacing (creepage distance, air clearance) are only applied for protection against electric shock. So, for fire, battery explosion and other hazards spacings do not need to be measured. Even if was applicable, the limit for a battery operated circuit has been effectively reduced to 0.4mm.
In any case, most test labs ignore creepage distance measurements in secondary circuits (regardless of 2nd or 3rd edition).
However, if you are working under the 2nd edition, I would be careful about asking a test lab for an opinion. In that case there is a risk they might follow the standard and ask for 3.4mm!
fob = small pocket for watch etc. formerly made in waistband of breeches. (OED).
Except here it pertains to the sort of lump on your key chain that you might then put in such a pocket.
CaliforniaMike
Peter,
Thank you for the detailed help on this. Knowing that I can go to 0.4mm is an immense help. Can you tell me where in the standard to find the battery operated exclusion. I just started parsing the 3rd edition and none of my old notes apply to the new organization.
For reference, I just ran a shorted (0.15 ohm load resistor) CR2032 to empty and though there was a brief (10 seconds or so) period of current on the range of 400ma, after that it quickly dropped to 100ma and tapered off from there. The cell was at its worst lukewarm to the touch. Pretty tame. I will document this more carefully for our file and post if I see anything that deviates from this.
For the record, fob = small keychain remote control.
Thanks all. Greatly appreciated,
Mike
Peter Selvey
I'm not sure if it is intentional by the committee, but the exclusion of creepage and clearance in your case is based on the widespread use of the phrase "means of protection" (MOP) throughout Clause 8, and a MOP is defined as something that protects against electric shock.
I'm sure some will disagree, and since shorting a component is still considered a fault condition, it is a moot point anyway. If your battery connects to an IC, it is allowable to short the IC and you end up with the same result.
Shorting a CR2032 is probably safe not because it does not have much energy but because it is so dangerous that manufacturers have to fit up to three types of protection systems inside the cell to prevent explosion. Without this protection, under short circuit Li-ion converts to Li which then explodes in a spectacular fashion.
But this protection is not always reliable thus it is a good idea to avoid shorting cells through good design. Normally this would include:
- if possible a series resistor which limits fault current, value selected to be the highest that does not impact normal operation or significantly reduce battery life. Reliable low value fuses are difficult to find and often resistive anyway, so may as well go with a known resistor.
- good mechanical restraint, don't use cheap battery holders
- reasonable spacing of metal parts around the battery, accounting for possible movement
- vibration/normal use testing, check for movement of the battery
- if replaceable by the user, make sure it is difficult to short (usability testing)
etc
CaliforniaMike
Peter,
Thanks again for the feedback. It is greatly appreciated. I am the lone electron guy at this company and it helps a lot to get some input from outside of the bubble.
I tend to tryto find the worst case scenario and then work back from there. The short test was performed under controlled conditions (inside a 1/4” thick aluminum chamber.) to get an idea of this worst case scenario. We use Li ion packs for other products and have integrated all of the over current/ overvoltage / over temperature protections for these. Coin cells are a new one for us. After looking at the information on the web, these do not seem to have any of these.
I suspect (dangerous word) that the worst case in these cells is limited by internal resistance. At the stated initial 10 ohms, perhaps intrinsic or perhaps put there as a protection, the maximum current available is 300 mA. (I saw ~380 mA for about 100 ms and then it dropped to 100 mA at 7 seconds.) At this current, the maximum power being dissipated is <1 watt which in something as large as a 20mm disk is not going to get that hot in a few seconds. After the test, the internal resistance was up to close to 30 ohms.
I suspect (there is that word again) that the short duration of 300 mA at the start and the gradual increase in impedance over discharge points to the current limiting being a reaction rate or surface area based phenomena and hence an intrinsic limit for the CR chemistry.
Our peak current draw, for a few ms, is about 30 ma. I have a 100ma fuse in line resulting in a peak power of 0.3 watts. (Though I acknowledge the issue with lower current fuse accuracies, I cannot afford to throw away any more battery drop when I need 2.0 V ot operate and already have 300 - 900 mV going into internal resistance over the life of the cell. Also, if the fuse is as far off as 200ma, we are still limited to 600 mW for a few seconds. I also have ~ 1/2 mm clearance to all parts prior to the fuse as well, a polarity protection FET. I have based clearances to the battery on worst case clip placements and battery insertion geometries.
All of our board designs go through HASS so they will get the heck shaken out of them and any mechanical weakness should show up quickly.
I think we are pretty safe.
This said, with a standard PCB coin cell clip, with the positive cage extending around the top and down the sides of the cell to the PCB, if the cell is placed in upside down, it is likely to short through the battery clip to the side of the cell and create a current path back to the top of the cell. In fact, most designs virtually guarantee a short if you put the battery in firmly. I do not see any way to protect against this with any of the PCB clips. (Check the BK 912 from memory protection devices for a reference.)
If there was a problem, there should have been a number of documented failures and that this would not be the standard PCB clip design for nearly all of the battery clip companies.
I have searched the web and in the tech journals and while I find numerous warnings about small coin cells, I cannot find a single report of them loosing integrity under shorted discharge conditions or from being inserted upside down in a clip, or carried in a pocket with change or the like. (I have seen some videos of them exploding, but these were the result of running 240 VAC through them. Somewhat fun, but not very helpful.)
So…
I currently plan to move ahead with the standard protections (fuse, spacing, polarity protection , mechanical /vibration testing) , performing and documenting short tests on the commercially available CR2032s, and at this point trusting that the industry would have done something by now if shorting a cell out by placing it into a PCB clip upside down was really a risk.
Am I missing anything here? Anyone have a documented case of a serious failure caused by a shorted coin cell?
Thanks again,
Mike
Peter Selvey
Maybe the same here, most of my research is based on larger packs which are of course more of a concern.
From previous research on larger Li-ion cells (2400mA types), I got the impression that the failure rate of internal cell protection when shorted is around 0.001; i.e. one in a thousand will still explode when shorted.
I found at least one reference showing that CR2032 do have some safety features, and a PTC device could be the cause of the increase in impedance (drop in current) when shorted.
But, no references of any failure of CR2032 protection. So I guess the failure rate of the protection for coin cells is much lower, maybe 0.0001 or less. Combine this with good design practice and the probability of serious harm is likely to be well below the proverbial one in a million.
CaliforniaMike
All,
Just a quick followup and thanks. We finally made it through our year of patient testing, compliance, and have been out on the market long enough to see that we did not miss anything.
Thanks to the help here, we sailed through 60601 without a need for any revisions. Thanks. Nice to have a bit of backup when things get odd.
Mike
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Some confusion about the creepage and clearance distance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Question on creepage/clearance requirements for HF Active Accessories for 2nd edition 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T Clearance and Creepage according to Subclause 8.9.1 for MOPP IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R Components in parallel to creepage\clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H Defib Protected Applied Parts: 4mm clearance/creepage? IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
A IEC 60601 Creepage and Clearance Requirements on PCB IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
A Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F MOP (Means Of Protection) - Creepage and Clearance questions IEC 60601 - Medical Electrical Equipment Safety Standards Series 19
R Creepage and air clearance under vacuum conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N PCB Creepage and Air Clearance on 8 Layer Boards IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Creepage and Clearance for high voltage low energy circuits IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Creepage and Clearance Distance for MOOP on Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T IEC 60601-1 Conformal Coating not an acceptable mitigation for creepage and clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Interpolation of creepage distance IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
S Creepage distance IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Electrosurgical generator with switchable sockets - creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
E Creepage distance accross insulation of step up transformer EU Medical Device Regulations 2
F IEC 61010 Creepage and Clearence Requirements Other ISO and International Standards and European Regulations 2
Steve McQuality Creepage Distance - Definition and Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
H SOP Template for seeking regulatory clearance - MDSAP Document Control Systems, Procedures, Forms and Templates 6
6 MSA for Calculated Clearance Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
M Regulatory clearance pathways for surgical masks/N95 respirators Other US Medical Device Regulations 3
K Completing Design Controls after 510(k) Clearance Other US Medical Device Regulations 11
O Hospital-Developed, In-House Device - FDA Clearance? Other US Medical Device Regulations 19
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
J China NMPA medical device submission timelines and clearance rates China Medical Device Regulations 2
B 510(k) clearance claim on medical device product packaging Other US Medical Device Regulations 6
M Informational US FDA final guidance – Marketing Clearance of Diagnostic Ultrasound Systems and Transducers Medical Device and FDA Regulations and Standards News 0
C Shipping Medical Devices to US before pre market clearance US Food and Drug Administration (FDA) 1
F Importer and US agent needed after FDA clearance? Other US Medical Device Regulations 2
K ISO/IEC 27000, ISO 15408 and the DSS security clearance (FCL) -- Oh, My IEC 27001 - Information Security Management Systems (ISMS) 0
Ron Rompen Question on 'Class of Fit' - Gage Pin Clearance Manufacturing and Related Processes 2
A 61010-1 Accessible Parts - Limit Values and Crepage and Air Clearance Distances Other Medical Device Related Standards 1
A Infusion Pump - Pre-Clearance Inspections Learnings US Food and Drug Administration (FDA) 4
E Internal clearance distance according to 60601 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Floor Marking Colors - Clearance Area in front of Electrical Panels Occupational Health & Safety Management Standards 6
M FDA Wall Clearance Requirements For Warehouse 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
V Should the Line Clearance include Machine Setup for current Operation? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R Distribution of a Device by another company - Questions about 510 (K) Clearance US Food and Drug Administration (FDA) 6
M Employee Transfer, Separation and Clearance Procedure and Forms ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Line Clearance Failures and Issues ISO 13485:2016 - Medical Device Quality Management Systems 2
P Batch to Batch Change Over Line Clearance Checklist Manufacturing and Related Processes 26
B 510K Clearance Application 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Procedure for Security Clearance to a security clearance access area Document Control Systems, Procedures, Forms and Templates 5
W Can a CSA-US certificate substitute a FDA 510(k) clearance? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
