Creepage - Does a surface mount isolator body negate a PCB slot?
Nick_EMC
I am trying to replace a bulky potted isolator with a surface mount digital isolator. For a standard FR4 PCB we have been working to a creepage of 16mm.
There is a high creepage isolator from TI with a 14.5mm creepage distance and a body CTI of >600.
This part should be very suitable for the stress so I am hoping to use it with a PCB slot to achieve the 16mm. However the body of the isolator may sit just 0.1mm above the PCB, so it effectively bridges the PCB slot (<1mm distance).
I was wondering if there was a way around this? A wide slot would be bridged by the high CTI isolator body, maybe this can be taken into account?
Hoping someone has some experience with this.
Nick
If your starting point is 14.5mm -
a 2mm wide slot would count as would the 1.6mm (x2) thickness of the PCB.
That would give a total of 19.7mm.
Nick_EMC
What I mean is the creapage distance is along the top of the PCB, as is is surface mount, then the gap to the body of the isolator can be as low as 0.1mm, so this will be ignored. So the component body will bridge the PCB gap. There is no easy way to stand a surface mount part away from the PCB to eliminate this.
I was hoping that the component body, being of a higher tracking index could be taken into account in determining the requirement.
Nick
Hi Nick,
OK - I see what you are saying.
One 'trick' I have seen using high speed digital isolators is to use 2, one after the other. Each provides 1 MOPP, so the Cr and Cl requirements are halved.
Nick_EMC
Unfortunately for this you need a power supply in the centre.
It may be that the creepage can be looked at again and does not need to be quite so large.
Peter Selvey
16mm seems very large, what is the Vp, Vrms used as the working voltage? Also it 2MOOP or 2MOPP?
You might be able to justify a lower limit by referencing IEC 60664-1 which is the "bible" for creepage/clearance. Sometimes the values in IEC 60601-1 start to get away from the fundamentals especially for unusual voltages.
Nick_EMC
Hi Peter,
Thanks for your interest. I agree with you about 16mm being very large - it seems to be a historical thing and very conservative.
It is actually a 1 MOPP barrier between an intermediate and a patient (applied part). There is another MOPP in the power supply. The intermediate is approx. 180V DC and the applied part 340V RMS. Looking at previous test house reports this is assessed at more like 6mm.
I have just decided that 8mm is a more realistic figure for this barrier, and it gives a much easier design and saves a lot of space.
I think the high figure came from taking the mains input to patient output voltages and adding these together, disregarding the fact that the output was floating, and applying 2 x MOPP to this figure, and dividing the resultant creepage between the barriers, giving most of the creepage to the intermediate/patient one.
To me it seems more sensible to consider the barriers separately.
Best regards
D Interpolation of creepage distance IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B IEC 60601 - Creepage Distance - Relay that acts as a means of physical mechanical protection Process Maps, Process Mapping and Turtle Diagrams 0
S Some confusion about the creepage and clearance distance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N Question on creepage/clearance requirements for HF Active Accessories for 2nd edition 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
T Clearance and Creepage according to Subclause 8.9.1 for MOPP IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S Creepage distance IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
N Electrosurgical generator with switchable sockets - creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Components in parallel to creepage\clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
H Defib Protected Applied Parts: 4mm clearance/creepage? IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
E Creepage distance accross insulation of step up transformer EU Medical Device Regulations 2
A IEC 60601 Creepage and Clearance Requirements on PCB IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
F IEC 61010 Creepage and Clearence Requirements Other ISO and International Standards and European Regulations 2
A Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F MOP (Means Of Protection) - Creepage and Clearance questions IEC 60601 - Medical Electrical Equipment Safety Standards Series 19
R Creepage and air clearance under vacuum conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
N PCB Creepage and Air Clearance on 8 Layer Boards IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Creepage and Clearance for high voltage low energy circuits IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Creepage and Clearance Distance for MOOP on Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
C Creepage and Clearance for CR2032 powered fob for a Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
Steve McQuality Creepage Distance - Definition and Interpretation IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
T IEC 60601-1 Conformal Coating not an acceptable mitigation for creepage and clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
