Crimper Calibration - How do you Control & Calibrate your crimpers?
Falcon419
How do you control & Calibrate your crimpers? Do you control crimpers that are used for New Build Manufacturing differently than those at are used for repair?
Falcon419
We use a variety of hand crimpers to apply ring terminals, sockets, pins....
We are currently researching all specs and compiling them. We are an ISO certified company and I was just curious how other companies control hand crimpers. Is it a requirement to log and calibrate all crimpers for both new build and repair? Some crimpers do not have specs on file, have companies utilized the UL crimp specs as a base for those we are unable to locate?
Unless these crimpers are also measuring the final crimped dimension, there should be no need for calibration. They may need a preventative maintenance plan. However, the gage used to measure the crimped dimension would need calibration.
You have to define the performance expectations of the crimping process somehow, although calibration as such isn't an issue.
optomist1
A Sea of Statistics
a few suggestions:
1) today more than ever electrical connections are a relatively simple but crucial component in vehicle system(s)
2) Access to "Crimpers" should be controlled as they are a key tool, so access should be controlled via a cabinet and a access limited to a shift supervisor....experience has shown that an unwitting employee may use what "appears to be the correct crimp tool and/or crimp die-set", only to find out later it was the wrong tool + die set. As many different die sets can be used on the same tool
3) In addition to Jim's great counsel above, many applications require a sample of crimps to be sectioned and visually examined to confirm a proper crimp
4) The above items aside, they should be controlled and subjected to periodic preventative maintenance to insure proper operation and long life
somashekar
You validate it periodically, or perhaps daily before use, looking into proper selection of the die slot, the stripping of the wire per standard, and after crimping., the pull force, the crimp height, any conductor damage post crimping, and in some cases the grip over insulation as the case may be.
L What do I do when I can not find a spec from the manufacturer-Panduit ferrule crimper Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
L Citied for not doing a pull test on our crimper - Is there a 'cheap' way to do it? General Measurement Device and Calibration Topics 3
M Calibration of equipment IATF 16949 - Automotive Quality Systems Standard 2
Q Gage calibration / tracking software General Measurement Device and Calibration Topics 2
C Should resolution be included in uncertainty budget for digital caliper or micrometer calibration? Measurement Uncertainty (MU) 4
S Calibration Due date-Critical Connie General Measurement Device and Calibration Topics 16
Q Request Calibration Info Calibration and Metrology Software and Hardware 16
R Calibration Log - Archive Manufacturing and Related Processes 2
U Calculate acceptance of equipment reading after calibration General Measurement Device and Calibration Topics 2
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 2
U Calculate acceptance of calibration reading Measurement Uncertainty (MU) 1
D Air hood calibration ISO 13485:2016 - Medical Device Quality Management Systems 1
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Calibration/Verification Report Durometer ISO 17025 related Discussions 2
S Medical device equipment calibration Qualification and Validation (including 21 CFR Part 11) 1
J Scrap Material Scale Calibration Required? IATF 16949 - Automotive Quality Systems Standard 21
S 7.1.5.2.1 Calibration/Verification Records IATF 16949 - Automotive Quality Systems Standard 6
K Is Calibration Required for Non-Adjustable Commercial Inspection Devices? General Measurement Device and Calibration Topics 11
F Calibration in GPC/SEC General Measurement Device and Calibration Topics 1
Q Changing calibration frequency Calibration and Metrology Software and Hardware 18
M IATF 16949 SI # 10: Integrated self-calibration of measurement equipment- Needs for explanation IATF 16949 - Automotive Quality Systems Standard 2
M Storing Calibration Certificate Document Control Systems, Procedures, Forms and Templates 7
B Risk analysis for defective measuring or measuring equipment out of calibration General Measurement Device and Calibration Topics 2
S Placing a calibration sticker with someone other than your initials Records and Data - Quality, Legal and Other Evidence 8
J IATF 16949 Calibration/Verification records question ISO 26262 - Road vehicles – Functional safety 6
M Approval of Calibration Certificates General Measurement Device and Calibration Topics 1
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 3
N IATF Calibration Lean in Manufacturing and Service Industries 5
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 32
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
