Criteria for operator's readings at setup - Seeking help to explain chosen limits.
P
pagnonig
Dear all,
I'm reading a book regarding the SPC control in the Wire & Cables Industry.
I came face to face to an example that I can't fully understand. Here is the example description:
We carried out a capability evaluation of an extrusion machine.
The elongation measured on 15 samples taken from a standard run (without adjustments) has a Sigma=0.12 .
The defined Product Specification for the elongation is 2.45 +/- 0.45 .
Now, we have to give to the machine operator a tool in order to be able to setup the machine correctly.
The criteria is the following:
If, at initial setup, an operator's first reading falls between nominal and +/- 1.44*Sigma, the operator is 68% confident that the process average is within 1.44*sigma of nominal value. When this criterion is met the decision should be DO NOT ADJUST.
If the average of operator's 1st and 2nd readings falls between nominal and +/- 1.02*Sigma, the operator is 68% confident that the process average is within 1.02*sigma of nominal value.Again, DO NOT ADJUST.
The full rule is...
READING >>> Prescibed LIMIT
1 >>> Nominal +/- 1.44*Sigma
avg of 1 and 2 >>> Nominal +/- 1.02*Sigma
avg of 1-3 >>> Nominal +/- .84*Sigma
avg of 1-4 >>> Nominal +/- .72*Sigma
avg of 1-5 >>> Nominal +/- .65*Sigma
avg of 1-6 >>> Nominal +/- .59*Sigma
avg of 1-7 >>> Nominal +/- .55*Sigma
avg of 1-8 >>> Nominal +/- .51*Sigma
My question is:
Which is the logic behind this criteria? Could anybody explain me how this limits have been chosen?
Thank you a lot for your help.
Of course, if you need any more detail please ask.
Regards.
Giuseppe:thanks:
P
Pudge 72
Re: Criteria for operator's readings at setup - Seeking help to explain chosen limits
You are giving the Operator a Tool to set the machine up based on a statistical study that was performed. That is OK - but, you cannot replace machine set-up with process performance parameters. What if the machine set-up is good but your air pressure or another variable presents you with a problem on that particular day - you cannot say that becuse the machine is producing product that you did not expect it to that your set-up master is bad.
What I am trying to say is that while I love statistics as much as the next guy, I think that you are trying to incorporate a method that may prove to be dangerous as well as frustrating. You are setting a benchmark standard that may be influenced by a condition that was not present during the initial study.
I would set it up as a DOE of sorts, develop your Set-Up master under optimum conditions and prove that under that scenario it is at the desired setting. Your readings at Set Up are not going to be all inclusive throughout the run if there are variables that could not be accounted for or measured while developing the parameters of this master.
During your production process, use the dimensional output of the product to determine what settings if necessary need to be adjusted as a result of variables that would not have influenced the set-up master and base your future decisions on that. Use Pre-Control / X-Bar & R ; utilize the different regions of a Pre-Control chart to dictate adjustment instead of having the operator do cumbersome math calculations.
It will work out great - we do this all of the time. By studying expected variation within the process, when it gets to a certain region in the Pre-Control chart, you can determine what and how much to adjust during the run.
P
pagnonig
Dear Pudge,
thank you for the reply.
In any case I'm not trying set uo such a process. I would like to understand where the limits came from because I can't find any analytical description inside the book I'm reading.
The setup rule given by the book's author is meant to minimize the scrap at the very beginning of a production run in an extrusion process, where usually you take dimensional readings (e.g. cable diameter) at the beginning of each produced cable length (e.g. 1000 or 2000 meters).
However, could you please explain something about PRE control chart. Why PRE? You mean it is used only during machine setup?
Thank you.
Giuseppe
S How to determine sample size to test when the acceptance criteria is x >= Standard value? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
V Process revalidation periodic criteria Manufacturing and Related Processes 5
G NC criteria during internal audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Mixing criteria and sampling Qualification and Validation (including 21 CFR Part 11) 1
C Design output vs acceptance criteria ISO 13485:2016 - Medical Device Quality Management Systems 8
qualprod Criteria % to be useful in establishing Kpis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Medical Device Component Change - Testing, Sampling Criteria ISO 14971 - Medical Device Risk Management 3
D IVD Accuracy and Precision Acceptance Criteria ISO 13485:2016 - Medical Device Quality Management Systems 1
T Intended purpose for devices that might not fit the IP criteria EU Medical Device Regulations 0
B Criteria for evaluating environmental aspects ISO 14001:2015 ISO 14001:2015 Specific Discussions 8
Q KPI risk assessment - Criteria for the given score IATF 16949 - Automotive Quality Systems Standard 3
A Industry Standards for Cosmetic Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 5
P Burst Test Acceptability Criteria ISO 13485:2016 - Medical Device Quality Management Systems 2
H Medical Device Label Acceptance Criteria Manufacturing and Related Processes 10
M Testing criteria - where to place Design and Development of Products and Processes 2
D What are the acceptance criteria/requirements for Stability Study? General Measurement Device and Calibration Topics 7
S On-time delivery CRITERIA AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
M ISO 14971:2019: Criteria for overall residual risk ISO 14971 - Medical Device Risk Management 11
O GR&R Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Audit Criteria Training Materials Internal Auditing 1
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
J Criteria Matrix To Initiate An A3 or 8D ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ASTM F2924-14 /ASTM F3001 - Room temperature classification criteria Other US Medical Device Regulations 1
M Supplier selection criteria - Medical devices ISO 13485:2016 - Medical Device Quality Management Systems 3
qualprod Criteria to raise a Nonconformance based on KPI values ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 39
M Criteria and when to carry out Setup Approval Manufacturing and Related Processes 5
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
S Acceptance criteria for gauges General Measurement Device and Calibration Topics 9
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
Z UDI assignment Criteria Software IVDR Other Medical Device Regulations World-Wide 0
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
qualprod Criteria for print shop - How do you consider the cycle time in a print shop? Lean in Manufacturing and Service Industries 21
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
GStough Auditing Against Criteria Unfamiliar to Auditee - Yea or Nay? General Auditing Discussions 11
M Internal Audit Assessment Criteria - ISO 13485:2016 Internal Auditing 21
