Criteria for taking Dimensional Measurements of a Painted Hole in a Part
Aviation Alvin
Here's my dilemma. I was recently issued a Supplier CAR from a Customer because a screw hole diameter was undersized by .003" - and therefore out of drawing tolerances. Our measurements for this particular part were undertaken during an in-process stage of production before primer and paint, and at which time they were well within specified tolerances (screw hole requirement was for .218” - .229”). After primer and paint, the hole closed to .215”.
The obvious solution is to ensure that the hole is oversized to the high end of the range, and then measuring again after prime and paint to ensure that it falls within the allowable range. The only problem that I have is that I’m taking a measurement against a structurally unstable material (prime/paint) versus against the structurally sound material (aluminum). If I were to initially oversize the hole outside the allowable range and then close the hole with primer and paint to bring it within tolerances, theoretically then I’d still be within compliance. For obvious reasons that makes me nervous. :notme:
When I asked our engineering department if the dimensions stated on the drawing are applicable to the finished part (after prime/paint) or to unfinished part (processed raw material only), they stated that all dimensions are to the raw material state (in-process) and that this was an accepted standard. When I asked for a documented industry standard that addressed this, they couldn’t supply one (ASME Y14.5M-1994 doesn’t cover it). The drawing didn’t stipulate if the measurements were for a finished product or not (flag notes or otherwise).
Does anyone know of an aviation industry documented standard that dictates the criteria used to meet dimensional measurements as indicated on a drawing?
Thanks so much for the help, and for a forum where so many professionals are willing to share their expertise and knowledge.
:thanx:
Re: Criteria for taking dimensional measurements of a part
Does the drawing specify finish (paint) requirements? If so, then drawing dimensions apply after finishing--they apply to the part you are supposed to supply. In my experience, dimensions always apply after processing unless otherwise specified. If you control the hole size and the paint process, you should be able to hold a .011" tolerance spread. If you think that the tolerance is too tight, ask the customer for some relief. Note that a .003 miss for a clearance hole is almost certainly nitpicking on the customer's part.
Aviation Alvin
Thanks Jim for your speedy reply. The drawing has a Bill of Materials (BOM) block that references all raw material and processes that are to be used for the production of the part. The chem. conversion, primer, and paint processes are listed here, as well as the paint and primer types.
Since my initial post, we've resigned to the fact that we'll have to build to the upper allowable tolerances and then measure post paint to ensure that we fall within tolerances. We’ll also utilize our Chamfer gage when we have to ensure that painted screw countersinks holes are within the .010” allowance.
I agree with your view of the Customer nitpicking on the over-tolerance measurements, but I have very little recourse - or a valid argument - when it doesn’t meet the drawing requirements. We've sent a lot of previous parts to this customer with no issue, but this shipment seemed to have generated a flow of paperwork (new, junior QC Inspector possibly?).
Thanks again for the help and guidance.
Cheers,
Al
bobdoering
Stop X-bar/R Madness!!
I think there is your opportunity for improvement. As Jim states, if there is no specification, then as supplied makes the most sense. But, I always say: if you have to ask, then stick it in the print and be done with it. Otherwise, you will be back to visit this problem again in the future...
I do hate building up to a final size from plating, painting, coating, heat treating, etc. Need wide specs to live comfortably with that.
bobdoering
This is a chronic situation. More of a reason to get it in writing!
Cheers,
Al
There's always danger in "getting away with" nonconforming conditions, even over long periods of time. As you suggest, all it takes is one newbie to upset the apple cart. Hole sizes--especially clearance holes--are famously problematic when painting or plating is involved. It's often difficult for a supplier to know when size really matters, and designers who mindlessly apply tight tolerances (often defaulting to block tolerances to avoid thinking) are the root of the problem. Nonetheless, if hole sizes are targeted on the nominal and controlled (especially punched holes) it's usually fairly easy to control coating thicknesses within finished hole-size tolerance.
A Industry Standards for Cosmetic Inspection Criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S IATF 16949 Supplier selection criteria 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 2
P Burst Test Acceptability Criteria ISO 13485:2016 - Medical Device Quality Management Systems 2
H Medical Device Label Acceptance Criteria Manufacturing and Related Processes 4
M Testing criteria - where to place Design and Development of Products and Processes 2
D What are the acceptance criteria/requirements for Stability Study? General Measurement Device and Calibration Topics 7
S On-time delivery CRITERIA AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R Clinical accuracy and repeatability of IR(infrared) thermometer, no maximum error criteria is recommended in ISO Other Medical Device Related Standards 11
M ISO 14971:2019: Criteria for overall residual risk ISO 14971 - Medical Device Risk Management 11
O GR&R Acceptance Criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Audit Criteria Training Materials Internal Auditing 1
C ISO/IEC 17021-1 clause 7.1.2 - Determination of competence criteria Document Control Systems, Procedures, Forms and Templates 2
B GM GP-12 Exit Criteria - Additional Safe Launch Inspection - (Also see GM1927-28 ) Customer and Company Specific Requirements 2
B AS9100 8.4.1 Supplier Selection/Evaluation criteria and reevaluations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
J Criteria Matrix To Initiate An A3 or 8D ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ASTM F2924-14 /ASTM F3001 - Room temperature classification criteria Other US Medical Device Regulations 1
M Supplier selection criteria - Medical devices ISO 13485:2016 - Medical Device Quality Management Systems 3
qualprod Criteria to raise a Nonconformance based on KPI values ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 39
M Criteria and when to carry out Setup Approval Manufacturing and Related Processes 5
V What is the criteria to cite an good documentation practices observation as an data integrity related issue US Food and Drug Administration (FDA) 6
S Acceptance criteria for gauges General Measurement Device and Calibration Topics 8
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J AIAG PPAP: 2.2.11.3 Acceptance Criteria for Initial Study (page 9, 4th edition) APQP and PPAP 1
C FDA on changing acceptance criteria re: analytical method validation US Food and Drug Administration (FDA) 1
Z UDI assignment Criteria Software IVDR Other Medical Device Regulations World-Wide 0
Ashok sunder What are the criteria for setting a target KPI value against a quality objective? Benchmarking 7
qualprod Criteria for print shop - How do you consider the cycle time in a print shop? Lean in Manufacturing and Service Industries 21
eule del ayre IATF 16949 / ISO 9001:2015 audit criteria IATF 16949 - Automotive Quality Systems Standard 17
GStough Auditing Against Criteria Unfamiliar to Auditee - Yea or Nay? General Auditing Discussions 11
M Internal Audit Assessment Criteria - ISO 13485:2016 Internal Auditing 21
S Agreement for allowance for visual criteria after submission APQP and PPAP 1
V Process and Internal Audit Criteria matrix wanted Internal Auditing 8
I Writing a Cosmetic Criteria for Switches Document Control Systems, Procedures, Forms and Templates 1
M Example ISO 14971 policy and risk criteria ISO 14971 - Medical Device Risk Management 0
D How to set equipment calibration/verification criteria General Measurement Device and Calibration Topics 1
A Operating criteria for production processes - ISO 14001 Cl. 8.1 ISO 14001:2015 Specific Discussions 3
B The most important criteria of IEC 60601-1 medical devices safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Supplier (Vendor) Evaluation Criteria - IATF 16949 Cl. 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 1
H CER - Equivalent Medical Devices Criteria - MDR/MEDDEV REV 4 CE Marking (Conformité Européene) / CB Scheme 9
K Internal Audit Scope and Criteria Internal Auditing 9
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
