Critical Action Limits (CAL) for All Internal and External Audit Findings
bigup1ca
My company is implementing a new NC/CAPA software solution where ALL NCs will be input into the system, including those from Internal Audits. I am part of a team tasked to come up with a CAL for audit findings that can be utilized in multiple divisions and provide a signal to our corporate office.
Anybody ever here of a CAL being set for audit findings? If so, could you forward an example? Appreciate it.
Stijloor
Any suggestions?
Thank you!
Stijloor.
Ajit Basrur
I use a simple Excel spreadsheet and found it very useful :)
It would be helpful if we had more information on what the OP is asking for.
What do you mean by 'Action"? will you be issuing a Corrective Action?
you can set an action limit based on severity (cost, quality delivery) or number of repeats of the same non-conformity...
Stijloor
Thank you Bev. Yes, I think (but I'm not quite sure :confused:) that the OP is asking about a standardized set of nonconformity evaluation criteria that will be used to decide on the type of action to take.
Stijloor.
Sorin
Did not heard (yet) but it should be pretty simple (you don't want a multi-ramifications nightmare I assume).
Is it critical for process/product/etc?
Short, Medium, Long Term...
Another idea would be to develop a reverse Ishikawa and apply it for every major finding.
Just ideas...
Stijloor.
good points. I'm not sure either. although he is saying something about a "signal to corporate". to *me* that means a signal regarding the state of nonconformances and further action as opposed to action regarding individual 'findings'
to the OP: can you clarify what you're looking for?
Jen Kirley
Quality and Auditing Expert
I've developed an audit tracking tool using Excel that has been getting refinements over time to provide meaningful audit data. I've attached its various iterations in the Cove - here is the latest one. It is meant to incorporate risk analysis of audit findings. Those risk levels may provide the "Critical action limits" you are asking about.
I've also started up a "Risk Based Auditing" thread where corrective action expectations change according to potential impacts of the issue.
The Tracking Log has drop down menus in columns such as "Functional Areas" that are set up in the Database sheet. With this method, your organization can decide on its own root cause types by changing the entries in the peach colored cells in Column AE. They are currently set to record:
  • Not following specs or SOP's
  • Procedures/SOPs were inadequate/ nonexistent
  • Failure to Comply with Regulations
  • Equipment Failure
  • Improper Equipment Installation
  • Improper tools/equipment used for the task
  • Equipment inadequate for needs
  • Other
The Functional Areas cells can be changed to represent the various types of audits: Customer visits, registrar, internal audits, etc. You might even decide to combine safety, environmental and quality audits in this single tool. Find this group of cells is in the Database page, colored yellow in Column Z:
  • Administration
  • Design
  • Human Resources
  • Design & Test Engineering
  • Information Systems
  • Manufacturing
  • Plant Engineering & Maint
  • Process Engineering
  • Procurement
  • Quality Assurance
This particular tracking log is set up to count findings against TS16949 elements - see column AG. You can reset those also.
The Database is set up to automatically update the drop down menus according to what's entered in the database. It will also keep track of and chart everything within the past 12 running months. If you want to change the time frame, the formulas for that are in the Database sheet, column C. The charts may be useful for reporting to management.
I hope this helps!
P.S. Please let me know if there is a problem in the tool, and I will fix it.
Ajit Basrur
Great tool Jennifer. Thanks :agree1:
I was just wondering how this ties in to the Balance Score Card worksheet which is towards the end ?
Jen Kirley
Thanks Ajit... Audit results are just one of the system measures in a good balanced scorecard dashboard like the one I put in there. The page has some other suggested measures. I will see about doing some more with that and editing the attachment.
P CCP Critical Limit and Corrective Action - Plastic Brush Parts Food Safety - ISO 22000, HACCP (21 CFR 120) 14
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
M Critical Characteristics APQP and PPAP 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B ISO 11607-2 "Critical Parameter" vs. "Process Parameter" Other Medical Device Related Standards 6
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
F Is there such a thing as 'Critical supplier' status under the Dept. of Health (UK)? Medical Device and FDA Regulations and Standards News 2
D Definition of "Critical Laboratory Equipment"? General Measurement Device and Calibration Topics 1
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
C Critical Suppliers for EU medical device approvals May 2020 EU Medical Device Regulations 1
M Informational Critical Thinking and the Process of Evidence-Based Practice Medical Device and FDA Regulations and Standards News 0
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 15
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
H Critical Supplier Agreement acc. to NBOG 2010-1 Annex II EU Medical Device Regulations 10
andika_untoro What are a good Critical to Quality (CTQ) metrics for a biotech manufacturing production? Lean in Manufacturing and Service Industries 0
A API Q1 9th ed Addendum 2 - Vendor Assessment for critical products Oil and Gas Industry Standards and Regulations 18
M Does a CDR (Critical Design Review) have to have a moderator that is unconnected to the team? Design and Development of Products and Processes 4
S Critical supplier - Obligated to have an ISO-certified QMS? ISO 13485:2016 - Medical Device Quality Management Systems 8
A Critical Supplier/Quality Agreement Procedure ISO 13485:2016 - Medical Device Quality Management Systems 8
C AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical Items AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J What level PPAP for 5 critical parts? APQP and PPAP 8
C Partial Design Validation and changes to a critical supplier 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Determining Critical Components for conformity with IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 21
S Financial status of critical vendor IEC 27001 - Information Security Management Systems (ISMS) 7
Ajit Basrur CDRH Premarket Approval Application Critical to Quality Pilot Program US Food and Drug Administration (FDA) 0
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
Q Is a Domain Registrar a Critical Supplier? ISO 13485:2016 - Medical Device Quality Management Systems 11
S Who compiles the Critical Component List, Insulation Diagram etc.? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
T Validation Plan for a new Class II Medical Device (Critical Care Medical Ventilator) IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R How to Train Staff for Critical Thinking Misc. Quality Assurance and Business Systems Related Topics 3
M Are Critical Business Processes Assets that need to be included in Asset Inventory? IEC 27001 - Information Security Management Systems (ISMS) 1
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
MDD_QNA What is the function of the Critical Component List? ISO 14971 - Medical Device Risk Management 2
C What is considered a "Critical" Raw Material? (Re: DNA Synthesis) Misc. Quality Assurance and Business Systems Related Topics 3
M Notified Body (NB) Audits of Sub-Contractors and Critical Suppliers EU Medical Device Regulations 35
H Definition of a Critical Process EU Medical Device Regulations 9
Q Critical Supplier's Senior Management Changes Supplier Quality Assurance and other Supplier Issues 4
M Justification for Not Having a Validation Plan for a Critical Process ISO 13485:2016 - Medical Device Quality Management Systems 4
P TSO Parts and Critical Components EASA and JAA Aviation Standards and Requirements 2
N VDA 1 Critical Characteristics Requirements Help needed VDA Standards - Germany's Automotive Standards 6
A Critical Suppliers which will not allow us to audit them Oil and Gas Industry Standards and Regulations 11
T AS9003 7.4.3 Critical Raw Material Verification Advice AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
