Critical Supplier Agreement acc. to NBOG 2010-1 Annex II
htcoztrk
We had an surveillance audit for CE certication according to Medical Device Directive 93/42/EEC.
One of the non-conformities is as following: "Contracts with critical suppliers do not meet all the requirements of NBOG 2010-1 ANNEX-II.
For example: The content of the contract does not include the requirement to be open to 3rd party inspections and responsibilities on each party are not defined."
We already had a quality agreement with the critical supplier in the past. We asked them to renewed it to close this non-conformity however they refused to agree any 3rd party audit or share their production records because they are already working with very big companies and they do not have time to spend for audit or other stuff because they find our company's purcahse volume small. But we're already working with this supplier since 2004 and we had no adverse event until today also we invested a lot for biocompatability tests, functional tests and product quality is very already confirmed by customers. So we do not want to change the supplier.
What should we do in this case? Is there any way to justify this sitaution so I can close the non-conformity?
-Hatice
yodon
As a contract manufacturer for a medical device, they have to agree to unannounced audits by the notified body. If you list them as a critical supplier then the NB has every right to show up, unannounced, and conduct an audit. If they refuse, you still bear the cost of the audit (not to mention your CE mark will likely be in jeopardy).
htcoztrk
Thank you for your reply. The current issue is that they do not agree to sign an QA including a clause of announced or unannounced but without such clause the non-conformity won't be closed. So my question is what will happen to certified product in case if we cannot close this NC? We only have 1 month left for due time for final corrections. Could unable to provide a QA may cause suspension of our certificate?
Sidney Vianna
Post Responsibly
Very likely, this supplier is under NB oversight themselves or via the fact that they are a critical supplier to other large customers. The records of such oversight activity might provide your NB with the assurance they need to consider this supplier properly monitored. If that is the case, your contract with the supplier could be phrased in a way to reflect that context.
Good luck.
planB
Hatice,
some ideas:
1) You design a new template for quality agreements for critical suppliers that contains the required 3rd-party audit clause, stating in you supplier-control procedure that this template has to be employed for new critical suppliers
2) You show your NB that your current supplier refuses to set-up and adapted quality agreement
By (1) and (2) you can demonstrate due diligence to your NB and that may be sufficient.
A note re. your supplier: the rationale of "other very big companies" is invalid, because in case they provide similar services of similar criticality to other larger-volume companies, they should be used to these kind of quality clauses. So in the long run, I would recommend you to look out for another supplier. At least for biocompatibility, there are plenty around that have no issue to sign contracts with 3rd-party audit clauses.
HTH,
Gerhard
Hi Hatice,
I was curious if you were able to find a resolution. In the past, we have had trouble getting some suppliers to agree to 3rd-party audits. They are a critical supplier to us but we are not a critical customer to them. In some cases it is simply not feasible to get a new supplier. I have in the past had suppliers agree to 3rd party audits if we pay compensation for the audit days.
Thanks!
LBM
Juzaili
Sorry to ask, we also just received the same NC from the NB. anyone can share a sample of the contract for Medical Devices. My NB said its too old and not as per NBOG_BPG_2010 annex 2. anyone can help me.
planB
Have to ask again: "Competency of suppliers raw materials specifications" is really the original wording of the NC? Which "quality certificates" is the NC referring to?
A Critical Supplier/Quality Agreement Procedure ISO 13485:2016 - Medical Device Quality Management Systems 8
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 2
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
F Is there such a thing as 'Critical supplier' status under the Dept. of Health (UK)? Medical Device and FDA Regulations and Standards News 2
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
S Critical supplier - Obligated to have an ISO-certified QMS? ISO 13485:2016 - Medical Device Quality Management Systems 8
C Partial Design Validation and changes to a critical supplier 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Is a Domain Registrar a Critical Supplier? ISO 13485:2016 - Medical Device Quality Management Systems 11
Q Critical Supplier's Senior Management Changes Supplier Quality Assurance and other Supplier Issues 4
J Product not in the Registration Scope of a Critical Subcontractor/Supplier CE Marking (Conformité Européene) / CB Scheme 11
A Determining Critical Tests for my Injection Plastic Molding Supplier Reliability Analysis - Predictions, Testing and Standards 4
E Changing Critical Supplier: What are the requirements Other US Medical Device Regulations 8
J What to expect when a Critical Supplier moves? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
Steve McQuality How to Determine Critical Supplier/Vendor Supplier Quality Assurance and other Supplier Issues 15
A Definition Critical Supplier - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
G Choosing Supplier Evaluation Methods - Determining what a Critical Supplier is Supplier Quality Assurance and other Supplier Issues 31
A Supplier 8D does not stop the problem - Critical defects - How to make 8D effective? Supplier Quality Assurance and other Supplier Issues 4
Marc Supplier Delivery Performance Monitoring - Critical Path Scheduling - TE - 4.15.6 Supplier Quality Assurance and other Supplier Issues 2
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Critical Characteristics APQP and PPAP 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
B ISO 11607-2 "Critical Parameter" vs. "Process Parameter" Other Medical Device Related Standards 6
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
D Definition of "Critical Laboratory Equipment"? General Measurement Device and Calibration Topics 1
C Critical Suppliers for EU medical device approvals May 2020 EU Medical Device Regulations 1
M Informational Critical Thinking and the Process of Evidence-Based Practice Medical Device and FDA Regulations and Standards News 0
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 15
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
andika_untoro What are a good Critical to Quality (CTQ) metrics for a biotech manufacturing production? Lean in Manufacturing and Service Industries 0
A API Q1 9th ed Addendum 2 - Vendor Assessment for critical products Oil and Gas Industry Standards and Regulations 18
M Does a CDR (Critical Design Review) have to have a moderator that is unconnected to the team? Design and Development of Products and Processes 4
C AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical Items AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J What level PPAP for 5 critical parts? APQP and PPAP 8
D Determining Critical Components for conformity with IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 21
S Financial status of critical vendor IEC 27001 - Information Security Management Systems (ISMS) 7
Ajit Basrur CDRH Premarket Approval Application Critical to Quality Pilot Program US Food and Drug Administration (FDA) 0
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
S Who compiles the Critical Component List, Insulation Diagram etc.? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
F Medical Device HACCP (Hazard Analysis and Critical Control Point) Risk Management ISO 14971 - Medical Device Risk Management 2
T Validation Plan for a new Class II Medical Device (Critical Care Medical Ventilator) IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
R How to Train Staff for Critical Thinking Misc. Quality Assurance and Business Systems Related Topics 3
M Are Critical Business Processes Assets that need to be included in Asset Inventory? IEC 27001 - Information Security Management Systems (ISMS) 1
C The difference between a Critical Dimension vs. Critical Characteristic Misc. Quality Assurance and Business Systems Related Topics 2
MDD_QNA What is the function of the Critical Component List? ISO 14971 - Medical Device Risk Management 2
C What is considered a "Critical" Raw Material? (Re: DNA Synthesis) Misc. Quality Assurance and Business Systems Related Topics 3
