Critical Supplier Initial evaluation for single purchases
jay747
We purchase raw materials (Critical products) from suppliers who are included in our Approved Vendor List. Under certain circumstances, we are forced to buy the RM from other unapproved Suppliers. Now should these suppliers be subjected to evaluation for these single purchases prior to the purchase and be added to the AVL or is there any way around it? (with reference to API Spec Q1)
Sidney Vianna
Post Responsibly
Do you have a process to identify and mitigate risks for procuring critical products from unapproved sources? What additional checks and balances do you perform to ensure product conformity?
jay747
As of now, there is no system in place to 'identify and mitigate risks for procuring critical products from unapproved sources'. The Approved Vendor list is in place just to please the auditors for now. I plan to improve the purchase process. But for the upcoming audit, the approved vendor list is vastly outdated. I plan to include the suppliers of the previous two years to exhibit during the Audit . It's a monumental task now, and I'm trying to minimize the task at hand.
"What additional checks and balances do you perform to ensure product conformity?" what can be included to ensure conformance at the product level? We have an effective incoming inspection process for all incoming critical products.
Sidney Vianna
Post Responsibly
How can I answer that, if I have no idea of the type of the raw material at hand? As an universal method, sending samples of the incoming material to independent test labs is an advisable step.
Do the unapproved suppliers have some form of quality system certification?
Can you reach out to customers of this unapproved supplier and ask for references and data on their quality performance?
I understand that your primary concern at this time is to "pass the audit", but, in theory, "passing audits" should be an outcome of having effective systems in place. If I were you, I wouldn't worry too much. The default value for nonconformities these days in CB audits is close to ZERO. Audits are less and less a good measure of system adequacy and effectiveness.
Good luck.
Rene Minassian
Do it right the first time....
Straight answer, YES. Critical Purchase shall undergo the requirments of 5.6.1.2 it does no matter if one time or for general use.
Know it depens on how complicatde you have defined the requirments to collect the relevant information requied by 5.6.1.2. It should be a questionäre to the supplier for a) & b) and a first article inspecton (FAI) when receiving the product. to c), finished. It should not be usper complicated.
Example:
for a) the supplier should have a QMS at least for 9001 in place.
for b) the supplier should carry out a incomming good inspection for his purchases at least.
for c) FAI
BUT this neds o be in line with your procedure in compliance with API Q1.
jmech
Q1 doesn't give any exemptions for single purchases, so they need to go through the approval process if you want to conform to Q1.
Q1 allows you to make the approval process fairly simple (as explained by Rene) but your procedure needs to conform to Q1 and your actions need to conform to your procedure.
APIQR is still not shy about issuing nonconformities and they still cancel registrations if nonconformances are bad enough or don't get fixed to their satisfaction. APIQR is far from perfect, but they don't seem to be as slack as many other CBs.
Sidney Vianna
Post Responsibly
Good to know that. I think that, when you have a monopoly, you can deliver the service any way you see fit, without a fear of losing the customer.
jay747
Example:
for c) FAI
Thanks Rene Minassian.
For Compliance to requirement 5.6.1.2 (c) would a routine internal incoming inspection be sufficient?
This is my first API Q1 audit. I was previously working with ISO 13485 medical devices, so I'm working on my transition between the systems.
I agree with Jmech.
In fact, it's a very simple question. Whether you procure raw materials from approved suppliers on the Critical Qualified Suppliers List or from other non-approved suppliers, you are fully responsible for the quality of the raw materials and products, and therefore you must have strict control over the procurement of critical raw materials because they are a matter of product quality and even safety. And, in 5.6.1.1 Procedures, it is clearly stated that the organization should establish documented procedures to ensure that the procured products, components or activities meet the specified requirements. Therefore, strict procurement control should also be carried out for the procurement of non-approved critical suppliers.
jay747
I agree with Jmech.
Well, I understand what you are trying to say. We have clearly determined our requirements for what we are purchasing and have a proper incoming inspection procedure to ensure that requirements are met. if they are not being met the products are rejected.
My question is - Am I allowed to procure critical products from non-approved critical suppliers without being non-compliance with the requirement?
J API Q1 - 5.6.1.2 (b) - Initial Supplier Evaluation—Critical Purchases Oil and Gas Industry Standards and Regulations 1
Pmarszal Technical File - Critical Supplier List Questions CE Marking (Conformité Européene) / CB Scheme 2
D Critical Supplier will not allow us to audit Plant floor US Food and Drug Administration (FDA) 12
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 20
S Distinction between a critical supplier and a Virtual manufacturer EU Medical Device Regulations 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
B Software service provider as critical supplier ISO 13485:2016 - Medical Device Quality Management Systems 5
F Is there such a thing as 'Critical supplier' status under the Dept. of Health (UK)? Medical Device and FDA Regulations and Standards News 2
M Changing supplier of critical raw material (III class device) Other Medical Device and Orthopedic Related Topics 1
H Critical Supplier Agreement acc. to NBOG 2010-1 Annex II EU Medical Device Regulations 10
S Critical supplier - Obligated to have an ISO-certified QMS? ISO 13485:2016 - Medical Device Quality Management Systems 8
Al Rosen Critical Supplier/Quality Agreement Procedure ISO 13485:2016 - Medical Device Quality Management Systems 8
C Partial Design Validation and changes to a critical supplier 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Is a Domain Registrar a Critical Supplier? ISO 13485:2016 - Medical Device Quality Management Systems 11
Q Critical Supplier's Senior Management Changes Supplier Quality Assurance and other Supplier Issues 4
J Product not in the Registration Scope of a Critical Subcontractor/Supplier CE Marking (Conformité Européene) / CB Scheme 11
A Determining Critical Tests for my Injection Plastic Molding Supplier Reliability Analysis - Predictions, Testing and Standards 4
E Changing Critical Supplier: What are the requirements Other US Medical Device Regulations 8
J What to expect when a Critical Supplier moves? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
Steve McQuality How to Determine Critical Supplier/Vendor Supplier Quality Assurance and other Supplier Issues 15
A Definition Critical Supplier - Definition of Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
G Choosing Supplier Evaluation Methods - Determining what a Critical Supplier is Supplier Quality Assurance and other Supplier Issues 31
A Supplier 8D does not stop the problem - Critical defects - How to make 8D effective? Supplier Quality Assurance and other Supplier Issues 4
Marc Supplier Delivery Performance Monitoring - Critical Path Scheduling - TE - 4.15.6 Supplier Quality Assurance and other Supplier Issues 2
Bev D Development Process: FMEA, Critical Characteristics, Spec Setting and Controls Misc. Quality Assurance and Business Systems Related Topics 0
K Critical Material Vendors: Distributors Vs Manufacturers and Supply Agreements ISO 13485:2016 - Medical Device Quality Management Systems 1
M IEC 62366 Hazard-related Use Scenario vs FDA Critical Task EU Medical Device Regulations 3
S Critical spare management guideline IATF 16949 - Automotive Quality Systems Standard 1
L Automatically considered Critical Component when within a fire ENCLOSURE? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
G Critical Characteristics/Dimensions of PCBAs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
H Critical subcontractors & crucial suppliers EU Medical Device Regulations 5
A Critical Characteristics - Sheet metal stamping APQP and PPAP 9
D What are the Activity deemed critical for the API 6D Ball Valve ? Oil and Gas Industry Standards and Regulations 4
lanley liao Questions regarding the change of critical suppliers and key personnel Oil and Gas Industry Standards and Regulations 5
S Calibration Due date-Critical Connie General Measurement Device and Calibration Topics 16
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Critical Characteristics APQP and PPAP 2
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 2
B ISO 11607-2 "Critical Parameter" vs. "Process Parameter" Other Medical Device Related Standards 6
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
D Definition of "Critical Laboratory Equipment"? General Measurement Device and Calibration Topics 1
C Critical Suppliers for EU medical device approvals May 2020 EU Medical Device Regulations 1
M Informational Critical Thinking and the Process of Evidence-Based Practice Medical Device and FDA Regulations and Standards News 0
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
O Examples of Critical process parameter (CPP) and Critical quality attribute (CQA) Manufacturing and Related Processes 2
R Critical suppliers (Definition of) and MDSAP (Medical Device Single Audit Program) ISO 13485:2016 - Medical Device Quality Management Systems 22
C Suppliers re-classification from Critical to Significant or from Significant to Non-critical Supply Chain Security Management Systems 0
andika_untoro What are a good Critical to Quality (CTQ) metrics for a biotech manufacturing production? Lean in Manufacturing and Service Industries 0
