Cross-Referencing ISO 9001/ISO 14001/OHSAS 18001
N
Nyack
Quick background. I have recently converted the H&S Manual for our organisation to comply with OHSAS 18001. We will probably not go for certification, just compliance to the principals.
The question I have is that we do have 9001 and 14001 audited. Now in order to properly index and reference all three documents as a single whole it would be preferable to cross-reference/associate the documents section by section and tie them all to work instructions also.
My questions are the following:
a) Direct - If a document in the ISO 14001 refers to a document in the H&S Manual (say for example, the Fire section indicates that a similar section is in the H&S Manual - as it is an associated document.)
b) Indirect - If a document in ISO 14001 refers to a Work Instruction. This Work Instruction is also used within the H&S Manual (which can be seen via the document control system / Master Index). So, there is an indirect reference to the H&S Manual from the ISO 14001 EMS.
The question is, does this make the H&S Manual auditable under the 9001/14001 audits?
Thanks in advance.
suildur
Re: Cross-Referencing 9001/14001/18001
Anything which your certified system(s) use and refer to is subject to audit.
Assume your OHS manual or any other OHS document is an external document; if your QMS and EMS refers to that external document, it is subject to audit.
However, in your case, when QMS or EMS refers to a clause, paragraph or a section of any OHS document, then the auditor will check only that part, not the whole manual, document or OHS system. But, also keep in mind, if you refer to an OHS document and there is another reference in where you referred to previously, then that new referred OHS document is subject to audit, too.
samsung
ISO 9001:2008 clarifies the Documentation Requirements in a 'note' at the end of section 4.2.1 as
A single document may address the requirements for one or more procedures. A requirement for a documented procedure may be covered by more than one document.
It shows that since the documentation requirement of 14001 is, in part, covered by the H&S manual, it is very much auditable. Now, while it's a part of your EMS, it has to be controlled per 4.4.5 Control of documents (ISO 14001)
Documents required by the environmental management system and by this International Standard shall be controlled.
Sidney Vianna
Post Responsibly
No, if the auditor(s) are competent and well informed. Every audit has a scope and criteria. If I am auditing an organization's QMS and EMS, I must not delve into issues beyond these management systems. This issued has been discussed extensively here. For example in the Health & Safety in ISO 9001:2000 Audits - OH&S Regulations thread.
There might be some grey areas between E and H&S and Q. However, for the most part, even if you have an integrated SHEQ program, auditors must stick to the boundaries of the audit. Are there any requirements in ISO 9001 and 14001 for occupational health & safety? No. Thus, keep away Mr. Auditor.
samsung
It's not a matter of auditing the H&S issues while auditing QMS or EMS. What is auditable is not the H&S system but the document (titled as H&S manual) which contains some procedures or work instructions required for his EMS and is referenced in the 'auditable' documents (of EMS).
Sidney Vianna
Post Responsibly
If the H&S Manual contains documents that are part of the EMS, then those relevant documents are definitely auditable because they are part of the EMS.
samsung
Yes, certainly they should be. And even if the OP's OHS system is not certified, this particular document (H&S manual) needs to be controlled per relevant requirements.
Thanks.
Hi !
My answer: if the "X"MS to audit in a company includes some documents shared with another "Y"MS, then these documents must be audited.
But these documents must be only audited in comparison to the "X"MS standard requirements (and not the "Y"MS standard requirements).
Bye.
PS : I reminds you that the exact OHSMS British Standard name is BS OHSAS 18001
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
V Submission for a cross-labelled combination product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
Q Looking for Cross Functional Matrix of Medical Device Regulations around the World Other Medical Device Regulations World-Wide 5
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
P Cross Section Issue - Dissecting a plastic part for measurement Manufacturing and Related Processes 4
Q Multiple Quality Standards - AS9100 and ISO13485/9001 Cross Reference Matrix Quality Manager and Management Related Issues 3
S Cross Tab Attribute Gauge Study form Excel .xls Spreadsheet Templates and Tools 3
S Who is doing BGA cross sectional analysis in assembled PCBA in INDIA? Reliability Analysis - Predictions, Testing and Standards 1
Marc Cross Country - Traveling in Style! Coffee Break and Water Cooler Discussions 4
QMMike Cross sectioning (wafering?) saw for rubber and plastics Manufacturing and Related Processes 3
I RoHS vs Non-RoHS - Best Practice for preventing Cross-Contamination? RoHS, REACH, ELV, IMDS and Restricted Substances 1
T How to perform an MSA on Cross Hatch Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
triathlonx13 Rubber - Tear and Adhesion Strength Peel Cross Head Speed Design and Development of Products and Processes 3
B Cross-reference list/table between HTM 2010 and ISO 17665 Other Medical Device Related Standards 1
Marc Facebook Profiles Now cross-referenced with retail purchases! After Work and Weekend Discussion Topics 3
P Cross Site Benchmarking of levels of business excellence Benchmarking 3
T ISO/IEC 27001 to ISO/IEC 12207 Mapping - Cross Reference Matrix IEC 27001 - Information Security Management Systems (ISMS) 2
E Cross Reference Matrix for TGA and ANVISA requirements Other Medical Device Regulations World-Wide 3
R Assembling a Cross Functional Root Cause Analysis Team Problem Solving, Root Cause Fault and Failure Analysis 4
Q What are the benefits of a Cross-Functional Internal Audit Team? Internal Auditing 14
A ISO 9001 and ISO 17020 Clauses Correspondance (Cross Reference Matrix) Other ISO and International Standards and European Regulations 4
D Cross-Reference between ISO9001:2008 and ISO17025:2005 ISO 17025 related Discussions 3
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Auditing Checklist for MDD 93/42/EEU that will cross reference several regulations EU Medical Device Regulations 9
S Cross Cutting Test on Paints and Varnishes (ISO 2409) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G Can I have more than 3 Appraisers to Cross Tab method? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Color Cross Reference - PMS and NCS colors samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
suildur Cross Reference List for ISO 9001 & ISO/IEC 17020 General Measurement Device and Calibration Topics 12
Miner Any Nordic (cross country) skiers out there? Coffee Break and Water Cooler Discussions 1
S Critical Control Points development and Cross contamination in food preparation Food Safety - ISO 22000, HACCP (21 CFR 120) 3
B Food Cross Contamination question Food Safety - ISO 22000, HACCP (21 CFR 120) 17
A A MUST READ---cross selling...good one.. Funny Stuff - Jokes and Humour 3
D Control of monitoring and measuring equipment - infrared thermometer for cross-check ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R HACCP-ISO 22000 cross reference wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
M Change Control Form - Approval process for cross departmental communication ISO 13485:2016 - Medical Device Quality Management Systems 4
Marc Aircraft 'Heavy' Passenger Jet Landing in 150 MPH Gusting Cross Wind Travel - Hotels, Motels, Planes and Trains 10
P MSA Attribute Studies - Calculate Cross Tabs, Effectiveness, Miss Rate, False Alarm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
R AS9100 vs. ISO 9001 Comparison (Cross Reference) Matrix AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Jim Wynne A horse of a different color - Zebra-Horse Cross-Breed Coffee Break and Water Cooler Discussions 1
T Creating Swim Lanes to document where processes cross functional boundaries ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Attribute GRR - Cross tab - Kappa - What does "Expected Count" mean? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
gard2372 Any websites or matrices to cross reference EN or DIN standards to SAE/ASME etc...? Other ISO and International Standards and European Regulations 3
B Does anyone have a good cross reference from QS9000 to TS16949? IATF 16949 - Automotive Quality Systems Standard 2
C Seeking ISO 9001 and ANSI Z10 crosswalk (cross reference matrix) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M TS vis-a-vis QS - Seeking TS-16949 to QS-9000 cross reference matrix IATF 16949 - Automotive Quality Systems Standard 6
Marc Acronym MRB - Material Review Board - A cross functional review - Acronym Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
