Cross Section Issue - Dissecting a plastic part for measurement
P
Priss80
I have dificulty when dissect plastic part for meanurement. There is a lot of burr at the cut edge and cause the measuremnt not accurate. Can you recommend clean cross section method?
Stijloor
A Quick Bump!
Can someone help?
If your questions were answered here, please consider helping others.
Thank you very much!
Danny Hoover
I am currently looking into a dual platen, wet, Grinder/Polisher.
I found many suppliers using this search "metallographic sample preparation"
We currently use wet sanding, course to fine, to eliminate burred edges and melting prevention.
If I get any information I will follow up.
Thanks,
DH
Michael_M
What are you using to cut the part? The device used will help determine the cut 'quality'.
For example, a band-saw will leave burrs, a cut-off saw will leave a burr on the 'bottom edge', etc. With everyone else's answers, I assume this is a specific requirement that I am not aware of (so take my advice knowing I do not know the process you are performing).
I work in metal (steel, brass, and aluminum). When I have to cut a part in 1/2, I use a manual milling machine and a sharp end-mill (the end-mill is the key, if dull, it will create lots of burrs). I also have the teeth of the end-mill exit the part on the side or surface I am not checking. Then I lap the part.
This does a couple of things, I minimize the burr and I cut the part in 1/2 within about +/- .001. If you are measuring parts, when you cut in 1/2, there is some error on angles the further from 1/2 you are. Generally speaking the error is not bad even at +/- .010 but I try for perfection simply to remove the question mark.
W Cross reference between APQP and VDA MLA? APQP and PPAP 0
K Looking for a tape to perform cross hatch test on powder coating parts Reliability Analysis - Predictions, Testing and Standards 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
V Submission for a cross-labelled combination product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
Q Looking for Cross Functional Matrix of Medical Device Regulations around the World Other Medical Device Regulations World-Wide 5
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
Q Multiple Quality Standards - AS9100 and ISO13485/9001 Cross Reference Matrix Quality Manager and Management Related Issues 3
S Cross Tab Attribute Gauge Study form Excel .xls Spreadsheet Templates and Tools 3
S Who is doing BGA cross sectional analysis in assembled PCBA in INDIA? Reliability Analysis - Predictions, Testing and Standards 1
Marc Cross Country - Traveling in Style! Coffee Break and Water Cooler Discussions 4
QMMike Cross sectioning (wafering?) saw for rubber and plastics Manufacturing and Related Processes 3
I RoHS vs Non-RoHS - Best Practice for preventing Cross-Contamination? RoHS, REACH, ELV, IMDS and Restricted Substances 1
T How to perform an MSA on Cross Hatch Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
triathlonx13 Rubber - Tear and Adhesion Strength Peel Cross Head Speed Design and Development of Products and Processes 3
B Cross-reference list/table between HTM 2010 and ISO 17665 Other Medical Device Related Standards 1
Marc Facebook Profiles Now cross-referenced with retail purchases! After Work and Weekend Discussion Topics 3
P Cross Site Benchmarking of levels of business excellence Benchmarking 3
T ISO/IEC 27001 to ISO/IEC 12207 Mapping - Cross Reference Matrix IEC 27001 - Information Security Management Systems (ISMS) 2
E Cross Reference Matrix for TGA and ANVISA requirements Other Medical Device Regulations World-Wide 3
R Assembling a Cross Functional Root Cause Analysis Team Problem Solving, Root Cause Fault and Failure Analysis 4
Q What are the benefits of a Cross-Functional Internal Audit Team? Internal Auditing 14
A ISO 9001 and ISO 17020 Clauses Correspondance (Cross Reference Matrix) Other ISO and International Standards and European Regulations 4
D Cross-Reference between ISO9001:2008 and ISO17025:2005 ISO 17025 related Discussions 3
S Cross Tabulation in Attribute MSA - Help Needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Auditing Checklist for MDD 93/42/EEU that will cross reference several regulations EU Medical Device Regulations 9
S Cross Cutting Test on Paints and Varnishes (ISO 2409) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
G Can I have more than 3 Appraisers to Cross Tab method? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Color Cross Reference - PMS and NCS colors samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
N Cross-Referencing ISO 9001/ISO 14001/OHSAS 18001 Occupational Health & Safety Management Standards 17
suildur Cross Reference List for ISO 9001 & ISO/IEC 17020 General Measurement Device and Calibration Topics 12
Miner Any Nordic (cross country) skiers out there? Coffee Break and Water Cooler Discussions 1
S Critical Control Points development and Cross contamination in food preparation Food Safety - ISO 22000, HACCP (21 CFR 120) 3
B Food Cross Contamination question Food Safety - ISO 22000, HACCP (21 CFR 120) 17
A A MUST READ---cross selling...good one.. Funny Stuff - Jokes and Humour 3
D Control of monitoring and measuring equipment - infrared thermometer for cross-check ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R HACCP-ISO 22000 cross reference wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 4
M Change Control Form - Approval process for cross departmental communication ISO 13485:2016 - Medical Device Quality Management Systems 4
Marc Aircraft 'Heavy' Passenger Jet Landing in 150 MPH Gusting Cross Wind Travel - Hotels, Motels, Planes and Trains 10
P MSA Attribute Studies - Calculate Cross Tabs, Effectiveness, Miss Rate, False Alarm Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
R AS9100 vs. ISO 9001 Comparison (Cross Reference) Matrix AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Jim Wynne A horse of a different color - Zebra-Horse Cross-Breed Coffee Break and Water Cooler Discussions 1
T Creating Swim Lanes to document where processes cross functional boundaries ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Attribute GRR - Cross tab - Kappa - What does "Expected Count" mean? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
gard2372 Any websites or matrices to cross reference EN or DIN standards to SAE/ASME etc...? Other ISO and International Standards and European Regulations 3
B Does anyone have a good cross reference from QS9000 to TS16949? IATF 16949 - Automotive Quality Systems Standard 2
C Seeking ISO 9001 and ANSI Z10 crosswalk (cross reference matrix) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
