Q
Hello Fellow Coves;
I am working on a GRR with one of the vendors. It turns out that the GRR on the Outer Diameter failed as the P/T ratio was greater than 30%. In this case it was 53%. The review of the material I had indicated that I should calculate a probability of misclassification but I am not seeing much hopes. Can someone take a look and advise how to proceed please.
Probabilities of Misclassification
Joint Probability
Part is bad and is accepted 0.000
Part is good and is rejected 0.000
Conditional Probability
False Accept *
False Reject 0.000
* WARNING * Probability of part within spec limits = 1.
• Raw Data in Excel Sheet
• Minitab File with the Analysis
QE
Joint Probability
False Accept *
False Reject 0.000
QE
