Currency of Technical Data - FAA Part 145 Repair Station
P
p1stonbroke
Hi.
I was hoping that somone might be able to clarify a point of law relating to the European Aerospace Laws ((EC) No 216/2008) and Regulation 1702/2003
Working as a 145 repair station, we need to ensure that the technical data supplied to us by our customers (operators) is up-to-date. The Operators have been shown in the past to sometimes not keep us up to date with the technical data.
Ideally we'd like to go to the OEMs for the parts which we repair and maintain for the technical data, however my understanding is that they have no legal obligation to provide this information to a subcontractor (i.e. us), only to the operator.
These two together mean that there is a high risk of repairing or maintaining parts/applicances using superseded information, or missing SB’s
What I am looking for is leverage, anything which would permit, under law to request that the OEM provides conformation of the current revision of the technical data,– the logic being that as this data is to be used in the maintenance of aircraft parts and appliances, withholding this information when asked could potentially make them liable should out-of-date information be used?
Has anyone tackled this particular conundrum themselves? any suggestions?
Marc
A quick "Bump". My Thanks in advance to anyone who can help with this one.
Rolfieh
There is no requirement for the OEM to supply the CMM beyond the requirememnts of the contract with their Tier 1 customer. The data in a CMM is proprietary to the OEM. There are current attempts by third parties to have the FAA define the CMM as instructions for continued airworthiness and therefore required for continued safe operation of the aircraft. As an OEM we have to bear the burden of $X million development costs for a new project that we are then paid minimal and often negative margins on the OE equipment to then lose the aftermarket work to third parties who have considerablly small costs and overhead burdens. I do not see why we should give the CMMs to third parties.
maozetung
Goodmorning,
It is not clear to me if your Maintenance Organization is approved to maintain aircraft, components or both of them. Anyway I can confirm you that the TCH/OEM has no obligation to provide you with maintenance data unless you subscribe to such data, in short, to have the data, you have to make an agreement for the supply of the service. I.e. Airbus has a wonderful portal called airbusworld where you can find almost everything. If you don't want to subscribe, as an alternative you should ask to the Operator to provide you with the login and password of its account to get access to the data.
If you maintain components you have to demonstrate to the OEM that you're a repair station approved to repair this and that P/Ns and apply for a subscription.
Anyway I can't understand how you could be approved to carry out such maintenance without having previously demonstrated to the Authority to have access to the maintenance data relevant to your organization’s approval class rating.
With regards to IR 1702/2003 it concerns initial airworthiness of products thus, as a maintenance organization, you're not affected by, conversely to maintain EU registered aircrafts or components intended for fitment to EU registered aircrafts you should give a look to IR 2042/2003 Annex II which concern continuing airworthiness of products.
Your organization shall establish a procedure to ensure that maintenance data you control is kept up to date. In the case of operator/customer controlled and provided maintenance data, your organization shall be able to show that either you have written confirmation from the operator/customer that all such maintenance data is up to date or you have work orders specifying the amendment status of the maintenance data to be used or you can show that you are on the operator/customer maintenance data amendment list.
Regards
P
p1stonbroke
Chairman Mao,
Thanks for your reply, it backs up that we're doing as much as we can to make sure the tech data we have is up to date.
Yes the organsiation has aerospace maintenance approvals, but at C-Rating Level - meaning maintenance of components.
As I stated in my initial question, the reason I was trying to find out if there was any legal obligation, was becasue we've sometimes found out that the operators data is actually out of date, through the very same portal you mention, or the other main one Boeing online.
You're right, I got mixed up with my IRs - we're a 21G, 145 and 21J approved organisation, and often the maintenance work requires a mod which means design and manufacturing of new parts for installation as part of the maintenance process.
Very many of our customers do permit us access to roam through their technical data, but the issue stands that if they give us out of date information, we can potentionally work to it, and as such a requirement on te OEM to provide data would have been good
However, I've been pursuing this line, and many OEMs will provide current revision and date of issue when requested, which gives us the opportunity to return to the operator to request that they get the new version.... so it kinds of works in a round about way.
Adding a caveat that our customer specifies the revision/date of the tech data to be used is a good idea - I like it.
Marc Europe Adding RFID Tags to Euro Currency World News 3
K Technical file for mhra CE Marking (Conformité Européene) / CB Scheme 2
H MD Technical Documentation and SALES possibility EU Medical Device Regulations 0
O Soft and technical skills for a VP of Quality Career and Occupation Discussions 1
A CE-IVD Technical File with Multiple IFUs EU Medical Device Regulations 4
A DMDIV-Variants : definition and technical documentation CE Marking (Conformité Européene) / CB Scheme 4
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
R MDR & depth of technical files review by NB's EU Medical Device Regulations 18
J Saudi Arabia Technical File Requirements Other Medical Device Regulations World-Wide 1
P MDR/IVDR Annex III - Technical documentation on PMS EU Medical Device Regulations 1
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
D Hospital Decontamination and the MDR - Technical Files, UDI and PMS EU Medical Device Regulations 3
F Software as a Medical Device (SaMD) Technical File Requirements Manufacturing and Related Processes 3
S Technical File for Surgical Mask in Class 1 MDD Elsmar Cove Forum ToS and Forum Policies 1
A Technical File - Updating Applied Standards EU Medical Device Regulations 4
M What to be careful about/focus on when doing a Technical File review EU Medical Device Regulations 4
Watchcat Anyone had an MDR technical file review/audit yet? EU Medical Device Regulations 13
G Same intended use devices - Technical file EU Medical Device Regulations 5
I Maintaining Technical Documentation under MDD and MDR EU Medical Device Regulations 1
M Basic UDI and technical documentation EU Medical Device Regulations 1
B Clause 5.1.12 of Technical Standard IEC 62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
V Iso13485 certification vs CE technical audit ISO 13485:2016 - Medical Device Quality Management Systems 3
F Management of Software version while NB reviews Technical file CE Marking (Conformité Européene) / CB Scheme 7
D Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
F Recommended practice for furnishing Technical Procedures ISO 17025 related Discussions 1
S How to find technical specification for facilities maintainance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
N Technical file requirements class 1 device MDR Other Medical Device Regulations World-Wide 6
R Implementing Design History Documents/ Technical Documents in the QMS ISO 13485:2016 - Medical Device Quality Management Systems 3
T Change in BRH (Brazilian Registration Holder) Technical Manager Other Medical Device Regulations World-Wide 2
C Maintenance of Product Technical Documentation EU Medical Device Regulations 3
O Medical Device Technical File Confidentiality - On site reviews EU Medical Device Regulations 14
N How to Write and Compile a Technical File for CE Marking CE Marking (Conformité Européene) / CB Scheme 4
N Technical File Reviewer has requested more testing to ISO 10993 Other Medical Device Related Standards 10
M Informational USFDA draft guidance – Technical Performance Assessment of Quantitative Imaging in Device Premarket Submissions Medical Device and FDA Regulations and Standards News 0
M Informational USFDA draft guidance – Technical Considerations for Non- Clinical Assessment of Medical Devices containing Nitinol Medical Device and FDA Regulations and Standards News 0
C Access to Technical Documentation - MDR Chapter VI Article 61 EU Medical Device Regulations 4
M Technical File (STED) labelling - When you compile tech files do we have to include all the product labels? EU Medical Device Regulations 2
M Informational IMDRF final document – Assembly and Technical Guide for IMDRF Table of Contents Submissions Medical Device and FDA Regulations and Standards News 4
N EU MDR Basic UDI-DI and Technical Documentation for Systems EU Medical Device Regulations 22
M Medical Devices and ASD-STE100 (Simplified Technical English) Other Medical Device Related Standards 0
B IATF 16949:2016 – Technical Specification (eBook edition) IATF 16949 - Automotive Quality Systems Standard 1
S MDR Technical File Structure Requirements EU Medical Device Regulations 12
L 510k exemption process - Do you still need to submit technical dossier? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D MDD to MDR - Technical File conversion EU Medical Device Regulations 4
J Connection between Technical File and Declaration of Conformity CE Marking (Conformité Européene) / CB Scheme 2
I MDD Class I software technical documentation sample EU Medical Device Regulations 2
M Annex II - Technical Documentation. V&V, Performance and Safety EU Medical Device Regulations 3
T Technical File Review - Transfer to a new NB EU Medical Device Regulations 3
J Brazil - Submitting Technical Files Other Medical Device Regulations World-Wide 2
