Customer Audit Finding ISO13485:2016 7.6
Deli88
Hi Cove,
I'm struggling to close out an audit finding with a customer.
The finding was against Magnehelic gauges on a brand new cleanroom we completed recently. The gauges had not been properly calibrated or verified at the time of the audit Our procedure states that we must calibrate equipment before it is put into use, and we do normally with all our equipment.
The reason the gauges weren't calibrated or verified was because it was believed that the commissioning company had carried out verification during the validation of the cleanrooms, however, they had not verified the gauges only the room pressures.
The gauges have since been verified and are included in our schedule for calibration.
How do you root cause an accidental omission of a single piece of equipment?
JoshuaFroud
There are a couple of ways you could approach this;
Prior to use, was the installation report reviewed? If so this should have picked up the gauges had not been calibrated - There is a potential gap in your hand over procedure stating what must be verified prior to production use, or if it is in the procedure a training issue with the operator conducting the review.
You've stated that the gauges are not included on your calibration schedule, were they not before the lack of calibration was detected? If not, that is another gap as a new device requiring calibration was introduced to the manufacturing stream without being added to the appropriate schedules. It is probably covered in a procedure who is responsible for ensuring new equipment is added to the required registers, if so the root cause could lie here.
When I have worked with Gauges of this nature in the past they have had a calibration sticker on them, in our SOP is asked the operator to verify (and sign for) the gauge being within calibration before conducting manufacture - if this check was in place the error would have been detected prior to the first production run starting. Again, this is either a procedural or training weakness.
If you want to take it back even further, does the contract with the installer of the clean room state they should have calibrated the gauges and provided evidence as such prior to job completion. If not, adding this requirement into further contracts (in addition to production hand over verification) would help to prevent re-occurrence.
Depending on your internal procedures, there are multiple points at which this could have been detected prior to material being produced in an environment controlled by an uncalibrated gauge. I would pick one (or more) of these are the root cause and work to address them.
Al Rosen
Hi Cove,
The Root Cause was the procurement process and the failure to perform Installation Qualification.
Golfman25
The problem being your not in the business of procuring cleanrooms. How many more are you going to do? Like others have said, there is a miss in your procurement/handoff/verification processes. To me, this is a correction -- you got the gages verified. Full root cause/corrective action probably won't get you anywhere. You'll need to tap dance around it to get your CA "approved." Good luck.
Ronen E
Problem Solver
Moderator
I mostly agree with @Golfman25. Not every glitch requires a CA. Here it's more of a customer-relations issue - soft-manage to maintain customer satisfaction (real Quality) and, as already done, ensure correction.
Before a root cause is sought, a clear definition of the problen/failure is necessary. If it's the cleanroom gauges not being calibrated, see Golfman's post. However, this can be generalised and then the root cause determination may be different. But I would first ask: Is this a real recurring / major issue? Has anything similar occured with other manufacturing equipment? How may times? How often?
Being efficient is not about dealing with everything. It's about identifying what matters and focusing resources allocation there.
Tagin
Hi Cove,
1) It is unclear from this text whether the lack of verification violated your procedure: were the gauges put into use before verification or not? If they were put into use before verification, then there is an issue with following procedure.
2) Even if it was expected that the commissioning company had carried out verification on your behalf, that verification result should have been recorded in your calibration records. This would indicate a calibration record-keeping failure.
It might be that a simple installation checklist could have prevented this, and that the corrective action is to implement such checklists for any future installations of equipment/facilities.
If a checklist was used, but this gauge verification was not on it, then maybe it indicates the need to have a predefined template for such checklists, which includes all important areas (such as calibration), as a way to provoke thinking about such things that can occur with an installation and so making sure they happen.
Ed Panek
QA RA Small Med Dev Company
Assuming you added this supplier to your approved supplier list you could add a check item on the supplier review that references "Are calibrated items a consideration for this purchase?"
Q Customer Requirements - AS9120B Audit Finding AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
A Excel Spreadsheet Validation - Customer Audit Finding Other US Medical Device Regulations 2
A Need to Audit an External Calibration Laboratory? - Customer Audit Finding Other Medical Device Regulations World-Wide 5
D Customer Audit Finding against ?where appropriate? of ISO 9001, Clause 7.4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
6 Customer Property documentation (Audit Finding) - Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B AS9100 Certification Audit Accounting for Additional Customer QMS Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
R Audit from Customer - concerned with IP protection ISO 13485:2016 - Medical Device Quality Management Systems 4
L Documenting internal audit of customer specific requirements IATF 16949 - Automotive Quality Systems Standard 10
S Customer audit report review and approval ISO 13485:2016 - Medical Device Quality Management Systems 3
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
N Customer asking if their notified body can audit us ISO 13485:2016 - Medical Device Quality Management Systems 5
T Customer audit demands - that I state in my QM who can shut down production AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
Genofear Customer wants to audit our supplier audits - seems inappropriate General Auditing Discussions 16
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A ISO/TS 16949 - Sharing Certification Audit Report (NCR's) with the Customer IATF 16949 - Automotive Quality Systems Standard 8
T "Customer Specific" Internal Audit suggestions needed Internal Auditing 12
C Customer Satisfaction Process - Audit "Suggestion for Improvement" General Auditing Discussions 14
R What objective evidence can/can't be supplied during a customer audit? General Auditing Discussions 3
G Customer Requests On-site Audit Supplier Quality Assurance and other Supplier Issues 9
T ISO 9001 Audit by Customer Customer and Company Specific Requirements 14
K Customer Audit - Just a positive rant really General Auditing Discussions 2
T CSR (Customer Specific Requirements) Audit Check List Customer and Company Specific Requirements 5
A Audit NC - Not identifying our Customer Specific Requirements - TS16949 (7.3.6.3) General Auditing Discussions 7
U Customer Audit Nonconformity on Internal Audit Program done by Corporate QA General Auditing Discussions 19
C Charging a customer who wants to audit our QMS? ISO 13485:2016 - Medical Device Quality Management Systems 16
S Internal Audit - No Proof of Acceptance of Customer New Payment Terms Internal Auditing 10
J Audit Programme - Include CB Audits, Customer Audits, Supplier Audits? General Auditing Discussions 18
K Audit NC - No evidence of a full 5 Why Analysis for the Customer Complaint Problem Solving, Root Cause Fault and Failure Analysis 8
A Best Way to Audit Customer Feedbacks Customer Complaints 3
T Would one deny a Request for a Customer Audit ? Misc. Quality Assurance and Business Systems Related Topics 21
S Customer Audit needs to see External Supplier Management Procedure Supplier Quality Assurance and other Supplier Issues 7
J AS9100 Rev C Internal Audit Procedure/Plan - Addressing 8.2.2 - Customer Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M Customer Audit and Access Policies Misc. Quality Assurance and Business Systems Related Topics 3
S Customer Requesting 3rd Party Audit Report (AIB) - Help! Quality Manager and Management Related Issues 17
ScottK Using Customer Audits as part of the Internal Audit Plan for ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Internal Audit-Customer Related Processes Internal Auditing 2
D Auditing Suppliers - Supplier audit by a customer who is also a competitor Supplier Quality Assurance and other Supplier Issues 13
O Internal Audit of Customer Specific Requirements Checklist - Where to start? Internal Auditing 9
N Customer Focus Process Audit Process Audits and Layered Process Audits 4
A Before the ISO-9001 certification audit can we submit the documents to our customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L Internal Audit to Focus on Customer Complaint Re-occurrences Internal Auditing 4
W Charging the Customer for a Supplier Audit? ISO 13485:2016 - Medical Device Quality Management Systems 8
M Giving copy of external audit report to customer General Auditing Discussions 20
F Customer Quality Audit Question - Giving the auditor a "guided" tour General Auditing Discussions 21
P Customer Complaint due to unanswered telephone during audit Internal Auditing 16
L IS/TS 16949 Initial Cert. Audit - placed on 3rd party containment with Customer IATF 16949 - Automotive Quality Systems Standard 3
C Customer Right to View Certification Body Audit Reports? General Auditing Discussions 11
R Customer Audit - C.A.S.E. Standard 1-A vs. AS9110 - Aircraft Assemblies Maintenance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
