Customer complaint over a Reference Dimension
GunLake
Has anyone had a complaint for a reference dimension being out?
The dimension was out even during ppap, Which was accepted. But now they sent a complaint about it.
I am new as a Quality Manager, Very limited customer contact in my last QA Tech job, So not sure what my main course of action is here.
What type of feature are you referring to - feature of size or note or material or something else? We don't hold our suppliers to meet a reference dimension so seems I'm not hearing the whole story here. Could you elaborate?
Ninja
Looking for Reality
Yes please...
A dimension being "out" typically means that there is a tolerance to be within...and I've not seen tolerances on a reference dimension before...
...or is it "out" of the standard drawing tolerance only?
try2makeit
Show the dimension as it was ppap'd and accepted and leave it as that. Unless the customer makes more noise about it - tell them to get you a updated print with tolerances on the dimension and re-submit PPAP.
Sidney Vianna
Post Responsibly
People can only speculate, but, sometimes, when a customer is experiencing a business downturn, they will use ANY issue to reject parts from suppliers.
As for the reference dimension being out, now that you know that, you need to implement corrective actions to prevent it's recurrence.
Ninja
Looking for Reality
While I agree with the direction, I think it's a bit too soon to say that as a blanket statement...there remain unanswered pertinent questions above.
It may be that you are correct...but it may be that this is just a "new guy at the customer" red herring just as easily.
This still seems like an initial entry into cooperative discussion with the customer, perhaps leading to either your assertion, or it being renounced by someone else at the customer.
Regardless, it is a complaint and should be handled through the complaint handling system.
CycleMike
Registered Visitor
Make sure the reference dimension isn't shown somewhere else on the print. It's common for a toleranced dimension to be shown as a (ref) in a different view.
John Predmore
Reference dimension may also indicate a mating dimension from a different part number in an assembly, perhaps a a commercial-off-the-shelf part, shown for convenience. The dimension from the other part number must still be held for proper function, but the dimension comes via a different design authority, so it is cited as reference on your drawing. If the reference dimension serves as a crucial customer interface, although it serves no direct purpose in your manufacturing system, it might be wise to check the reference dimension to ensure customer satisfaction. We verified key dimensions of electrical connectors in our PPAP, for example.
The other example where I have seen reference dimension used is when two dimensions add to a total length, and only 2 of the 3 are detailed with a tolerance. As a convenience, the untoleranced dimension might be shown as reference, particularly if the calculation of the stack-up is not obvious, if the component dimensions do not appear in the same view. The third dimension is important, maybe less critical than the two, but the third length is determined by calculation.
In the latest Y14.5 drafting standard, reference dimensions do not appear with the "REF" identifier, but are shown in parentheses.
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S How to treat a customer complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
PhilM Nonconformance report, Customer complaint investigations and RMAs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Problem Resolution Report Monitoring - Customer complaint or PRR as general motors use Customer Complaints 12
R Does an RMA = a Customer Complaint Customer Complaints 4
E Is there an Automotive Customer Complaint Index? IATF 16949 - Automotive Quality Systems Standard 3
R In a software development company: Is every bug reported by the customer a complaint? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Decontamination responsibility on customer complaint investigation Customer Complaints 4
N Possibly worlds first customer service complaint Supply Chain Security Management Systems 0
A What is a Customer Complaint? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J FDA definition of a complaint - Customer orders spare parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Customer Complaint Definition - Food Distributor Customer Complaints 5
R Customer Complaint - Samples vs. Removal - FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Moncia Customer Complaint Procedure example needed Document Control Systems, Procedures, Forms and Templates 1
C Medical Device Malfunction - Customer Complaint - Response vs. Correction Other US Medical Device Regulations 3
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
Q Customer Complaint Vs. Nonconformance - CAPA SYSTEM Customer Complaints 2
L Creating a xlsx Customer Complaint file to track Complaints Excel .xls Spreadsheet Templates and Tools 2
N Customer Complaint - Rapid Response Containment Procedure Customer Complaints 4
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
R Customer Complaint/Nonconforming Product Inquiry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Can anyone share a Customer Complaint procedure not requiring logging complaints ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Customer Complaint Preventive Action Assistance Preventive Action and Continuous Improvement 3
Q When to issue a Customer Complaint related to efficacy of a Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Do I need to initiate a Customer Complaint for Engineering Samples? Customer Complaints 4
A Customer Complaint - Incident Reporting Hardcopy Signoff Customer Complaints 8
B Analysis & Closure of a Customer Complaint Customer Complaints 6
C Customer Feedback, Satisfaction, Complaint Procedure and Measurement Customer Complaints 8
N Closed Customer Complaint Response Form Examples? Customer Complaints 3
J Damaged Parts in Customer Returns - Complaint Investigation? ISO 13485:2016 - Medical Device Quality Management Systems 9
D Is an NCR required in this Customer Complaint scenario? Nonconformance and Corrective Action 6
B Categorization of Customer Complaint: Making Customers feel they are Top Priority Customer Complaints 4
B Understanding the attached sample Pareto Chart for Customer Complaint Quality Tools, Improvement and Analysis 20
J Should I file a Customer Complaint as a Nonconforming Material Report or a CAP? Nonconformance and Corrective Action 5
R Help defining Eyewear Customer Complaint Categories Customer Complaints 5
K Audit NC - No evidence of a full 5 Why Analysis for the Customer Complaint Problem Solving, Root Cause Fault and Failure Analysis 8
somashekar What if a non EU customer makes a complaint to NB ? EU Medical Device Regulations 2
R Everest Customer Complaint System by Lynk Software US Food and Drug Administration (FDA) 1
T Is a Nonconformance Report required for every Customer Complaint? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
J Who should accept the samples of Customer Complaint products ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Data Flow diagram for a Customer Complaint System - Help wanted Customer Complaints 6
B Small Company Customer Complaint System ISO 13485:2016 - Medical Device Quality Management Systems 2
L Internal Audit to Focus on Customer Complaint Re-occurrences Internal Auditing 4
W Re-Evaluating Corrective Actions - Recurrence of a Customer Complaint Nonconformance and Corrective Action 7
P Customer Complaint due to unanswered telephone during audit Internal Auditing 16
B Are Parts in a Positive Recall w/o Customer Complaint considered as External PPM? Quality Manager and Management Related Issues 6
