Customer Designated vs. Customer Approved? Definitions
chinadaddy02
Had my 1st preliminary assessment last week and it went ok. Had a question about a finding in my Purchasing area,
What is the difference between a customer designated vs. customer approved supplier? Is it, for a customer designated supplier, if a a customer says to use a supplier but it is not on our approved supplier list, then it is ok to use the supplier the one time for the particular project? Then for a customer approved the customer wants us to use the supplier and we would put it on our approved supplier list, but still maintain the supplier as any other supplier (periodic on-site audits)?
Will probably have more questions in the future.
ralphsulser
Re: Customer designated vs. customer approved?
1st question-yes, and make sure you get a customer authorized document stating so with the details of duration and/or frequency, and make sure it is signed and dated.
2nd question-yes, even though customer approved, supplier needs to meet your customer approval list criteria unless waived in writing by you customer as above.
Duke Okes
Here's my interpretation, although your customer/industry may vary:
Customer designated means you didn't have to go through a selection process. However, they should still be on your approved supplier list, and you should still review their performance (and report results to them as well as to customer)
Customer approved means you may have selected them, but customer maintained right to approve/deny.
K
KwalityWonk
I tend to agree with Duke. Customer designated in Aerospace often means a single source of supply for a given product or process. Sources may often have to go thru qualification processes in order to manufacture a product or perform a process. Proprietary products and processes are often specified on Customer Blueprints, and while the specification may be an industry standard spec, the customer prefers one supplier over another based on design or validation testing. I believe the point that should be taken from the clause is that you are ultimately responsible for the quality of the product regardless of whether you you used customer directed / approved processors. And yes, they would need to be on your approved supplier list, but the controls you have in place for Customer Directed Suppliers may be as simple as 'Customer Directed', and validating the product or process at receiving or final inspection, to ensure you get what you payed for.
Ajit Basrur
Yes Duke is right - customer designated means that the customer goes through the selection process, audits and approves the supplier. After having done this, they mandate their supplier to use this qualified "sub-supplier".
L
lrsiyer
I go with Duke. Designated means already verified and designated to the down tiers.
Approved - No need to explain.
Perhaps having the wording of the clause in question would help because I'm not familiar with the standard, but I'm confused. How could a customer designate (which I interpret to mean "mandate") a supplier if that supplier were not approved? :confused:
somashekar
Please let us see the finding issued as it is worded, if this concerns to customer approved supplier.
There is no difference as far as a QMS application goes. Some say designated and some other say approved. Perhaps you are holding to both and now confused, trying to find the difference.
Wes Bucey
Prophet of Profit
FWIW:
Whether the customer provides a list of "approved" suppliers or a single "designated" supplier is immaterial in terms of whether the material from such supplier may be incorporated in a component, package or kit, or assembly your organization delivers to the customer. You need a written process or procedure to address this situation.
As a supplier, the situation should have been covered and signed off during Contract Review.
In terms of "approved" suppliers list provided by a customer, your organization may pick and choose which of them to approve and use yourself. The routine for your organization should include the same approval criteria you would use for any random supplier picked out of a telephone directory.
In terms of "designated" supplier
dictated [mandated] by your customer, you should ask (during Contract Review) whether the customer guarantees the quality and service of such designated supplier. If not, why not? Despite the guarantee or lack thereof, you still need to assure the quality of the product or service BEFORE installing it in the product you deliver to your customer. This is accomplished in one of two ways:
  1. Through laborious incoming inspection before sending product to your production line.
  2. Through approving the supplier's internal methods in the same way you approve ANY supplier with whom you want or have a "dock-to-stock" agreement which bypasses your own costly incoming inspection.
IMPORTANT NOTE:
For "customer supplied" product, you definitely need to cover (in Contract Review)
  1. who pays for incoming inspection, if necessary?
  2. what criteria will be used to determine whether customer supplied product is conforming enough to be installed in the product you deliver?
  3. who pays for delays caused by nonconforming product supplied by customer?
  4. what are the repercussions if "hidden nonconformities" of customer supplied product are discovered AFTER the product is in the field? (This is occasioned by a case where a customer inadvertently supplied counterfeit bolts which had not been properly heat treated and subsequently broke in the field, causing consequential damages for the end users of the equipment. The supplier who installed the bolts was limited to a visual inspection of the "ID lugs" on the bolt [counterfeit], designating the hardness category.)
Q
qmanager2012
Hello, I have the same situation and trying to come up with a form/document that I would send to my customer to have them sign stating they have approved the supplier that they are directing us to procure from. We are ISO13485 certified (Medical). Can anyone provide a sample document? Thank you
E IATF 16949 Cl. 8.2.3.1.2 - Customer-designated special characteristics IATF 16949 - Automotive Quality Systems Standard 1
D Customer-Designated Special Characteristics vs. Special Characteristics IATF 16949 - Automotive Quality Systems Standard 2
Q TS 16949 Clause 7.2.1.1 Customer Designated Special Characteristics IATF 16949 - Automotive Quality Systems Standard 6
S Vendor Control for Customer Designated Supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M TS 16949 7.4.1.3 - Difference between Approved Source and Customer Designated Source IATF 16949 - Automotive Quality Systems Standard 2
B Customer-designated sources AS9100 Design and Development of Products and Processes 6
S Designated Customer Representative - TS 16949 - Section 5.5.2.1 Design and Development of Products and Processes 3
M Customer Designated Special Characteristics - TS16949 Clause 7.2.1.1 Design and Development of Products and Processes 14
briteme4 Customer Requests FAI on Tooling Fixture AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
G Too many customer complaints Customer Complaints 16
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
S Obligation to accept customer audits? IATF 16949 - Automotive Quality Systems Standard 23
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
