Customer Documentation Errors when completing an AS9102 FAIR
cjod86
I am working on completing an FAI report for a customer and I've come across some errors on the assembly drawing. Should I have the customer correct the errors/typos and update the drawing for proceeding? Or, is there a proper way to fill out the report to call out errors in the customer documentation?
Thx,
Chris
rickpaul01
Involved in HankyPanky
Getting an updated drawing can sometimes be difficult. I note on the FAIR the problem with the drawing and what we did that was different. When the customer accepts the FAIR, I use that as acceptance documentation of the deviation to the drawing.
cjod86
Thanks Rick (or is it Paul?),
To add some additional detail that maybe you could also provide feedback on, here I go:
So the drawing lists notes 1-9, with 1, 4, 7, 8, & 9 being flag notes. However, one area of the drawing identifies flag note 5, which is not one of the flag notes. It is a typo and should actually identify flag note 7. What is the proper way to assign characteristics on the ballooned drawing given this?
If there was no typo, I would assign the same characteristic to both the note on the list of general notes, as well as to the flagged area on the drawing. Should I do this the same, even though the flagged area on the drawing indicates the wrong number? Or should I assign two separate characteristics?
rickpaul01
I would fill out all the information as if the drawing was correct, and then in the far right cell, make a note in Red. "The drawing references note 5, but this is incorrect. This characteristic was evaluated in accordance with note 7, and found to be in compliance."
Rick Paul
dsanabria
Step 1 - contact your customer for a revise drawing. If they won't ask them for an amended PO with corrections. (or write down on an e-mail and send them a copy of the e-mail and place another copy with the records for future reference - CYA)
Step 2 - Complete the FAIR per AS9002 - in the areas that you see duplications or omissions number them - ex 5a, 5b and place those same letter on form 3. On 5a you could make a note is it is missing and on 5b place the actual value on 5 b - as an example of the issue.
Remember that the FAIR is to document the process and issues if there are any. If the customer makes a correction, all you have to do is submit a DELTA FAIR with only the pending issues.
Michael_M
This is what I do as well. On form 3 I record in the 'requirements' section exactly what the print calls for; however, in the 'Comments' section I will record discrepancies from print.
Sometimes it is as simple as "Print calls for 4x, only 2x actual dimensions apply". In the results section, I will put what it should be (2x instead of 4x for example).
So far, no one has complained about this method.
D Lacking Documentation of Customer Requirements, what do I need? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B Cost for PPAP - Customer pays for samples and PPAP documentation from supplier APQP and PPAP 8
S PPAP for VW QPN - PPAP documentation for Volkswagon customer APQP and PPAP 4
6 Customer Property documentation (Audit Finding) - Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Technical Documentation Records - Customer drawing, Revision Level, PPAP, etc. Document Control Systems, Procedures, Forms and Templates 1
T Qualified Laboratory Documentation and Customer Specific Requirements APQP and PPAP 14
I Combining Corrective Action / NCP / Customer Complaint Documentation Customer Complaints 8
briteme4 Customer Requests FAI on Tooling Fixture AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 3
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
G Too many customer complaints Customer Complaints 16
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
S Obligation to accept customer audits? IATF 16949 - Automotive Quality Systems Standard 23
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
W Direct to customer export of medical device (class I: prescription lenses + frame) US Food and Drug Administration (FDA) 2
