There are "considerations" whether the customer drawing is disposable or whether it falls under your normal quality retention period.
Some, not all, of these considerations are:
- was the drawing used to make or assemble the product or merely a reference for where your product would go in a final assembly?
- did you have to make additional shop drawings to create the product based on customer's drawing?
- did the customer's drawing merely duplicate your own drawing for a standard off-the-shelf product?
- are there regulatory issues involved?
- since the customer (by your information) declares the drawing as disposable, what quality documents are you retaining after the order is closed? why? (if you have a reason to keep a file of quality documents relating to the product, you probably should keep the drawing IF you used it to build the product)
- is there a possibility the customer may come back in the future and complain the product doesn't meet spec?
- is there a possibility the customer may come back in the future for a reorder (same version level?)
In regard to number 3, I have seen numerous companies actually send a bolt manufacturer a drawing of a standard off-the-shelf bolt instead of merely saving time and money by referring to the catalog number.
If the order returns with a new version of the drawing, it is nice to compare against the original and refer to manufacturing notes rather than "reinvent the wheel" from scratch - some version changes are miniscule and do not affect the manufacturing process (often only size, finish, because more drastic change usually triggers a completely new part number.)
