Customer keeps rejecting my Process Control Plan (PCP)
Boubacar
I've attached a process control plan that I have sent to my customer. The customer is not automotive but are using the PCP framework. As I am a relative newbie regarding process control plans, I'm wondering if anyone can take a look and give me recommendations.
Customer's comments:
Some of the statements don't appear in the correct columns.
What is the criteria in the verification of step 7 (tinting and promoting)
What are instruments/gauges verified to calibrated standards (length, level, ultrasound).
I've asked for clarification with them and they sent me a sample PCP but I think that mine generally matches (although difficult because of different processes).
Also, I acknowledge that the PCP is extremely generic, this was on purpose as the customer has alot of custom work that may involved different specs, processes etc.
Any comments would be greatly appreciated.
Re: Customer keeps rejecting my PCP
It's hard to tell what the customer is looking for. I understand the comment about step 7; mixing resin isn't an evaluation or measurement technique. How do you determine whether the mix is compliant or not? You should ask the customer for specific examples of things not being in the correct fields, and what they mean with regard to calibration.
Z
zancky
Hi Boubacar,
our control plan have the same format but the content is quite different:mg:
I suppose You need a real example, I can confidentially send one but I can only do if You send me a message in my area with Your e-mail address
My customer will not accept Your control plan too
bobdoering
Stop X-bar/R Madness!!
What are instruments/gages verified to calibrated standards (length, level, ultrasound).
Also, I acknowledge that the PCP is extremely generic, this was on purpose as the customer has a lot of custom work that may involved different specs, processes etc.
I agree with your customer, although as a part of their vendor development, they should sit down with you for a few hours and go through this process with you.
Generically speaking:
1. Most control plans start at the process input, which is raw materials. Some of the previous steps can be addressed elsewhere in the quality system.
2."Move material to storage area" Is this staging of the material prior to mixing? If so, how do you know how much and what material to move? Process and product parameters need to be measurable - either by attribute or variable means. one process parameter may be "Move correct material to staging area". What is the tolerance? "Correct material according to blend sheet" (attribute) What is the size and frequency? every batch, 100%. What is the control method? "Verify bar code or material label to batch sheet" - it tells the operator what material and how much for that batch.
The next item for "Move material to storage area" may be "Move correct quantity of material to staging area". What is the tolerance? "Correct amount of material according to blend sheet +/- 5 lbs" (variable) What is the size and frequency? every batch, 100%. What is the control method? batch sheet - it tells the operator what material and how much for that batch. It may also be using a scale to verify the weights.
3. Mixing Resin: Product Characteristic: may be "Add correct quantity of resin tint". What is the tolerance? "Correct amount of material according to blend sheet +/- 5 lbs" (variable) What is the size and frequency? every batch, 100%. What is the control method? batch sheet - it tells the operator what material and how much for that batch. It may also be using a scale to verify the weights. I would also expect to see Process Characteristics: How long do you mix? Do you add any heat or cool? Is so how much? What RPM do you mix? They can also be generic, directing the operator to the blend sheet for specific info for the product.
I could go on for hours, but I thought this may be a good start for further discussion. :cool:
Randy Stewart
:agree1:Good job Bob, very understandable. It should help them a lot. Too bad the customer wouldn't take the time to share similar info.
Sounds like you've gone through this a time or two.:applause:
Caster
An Early Cover
There is a chance that all of this is covered in the statement "Mix resin as indicated resin mix book"
IF (a big IF) the "resin mix book" covers these questions, I could be talked into accepting the CP as is.
Mixing temperature and RPM MAY (a big MAY) be considered company trade secrets and it would not be appropriate to publish them on a CP.
You never know how much or little detail the customer wants, and often you get a new person at the customer who makes you change what the last one asked for.
Unless you are doing CP for your own benefit, the game seems to be keep making the minimum demanded changes requested until they need the parts and have to sign the warrant.
bobdoering
I would still cite them as controlled variable ("take credit for the control"), but leave the specific RPM, etc., in the recipe for confidentiality. I bet they control it - or they will be sucking bubbles out the resin for quite a while if they whip it into a frenzy. Playing the role of a customer, I would want to see what variables the vendor is attempting to control (and how they are attempting to control them), which ones they actually pondered about (effective FMEA process?) - whether they cite the specifics in the control plan or not. I will be able to ponder what failure modes to expect, from experience, if the vendor is not "taking credit" for controlling certain process and product parameters.
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
G Too many customer complaints Customer Complaints 16
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
S Obligation to accept customer audits? IATF 16949 - Automotive Quality Systems Standard 23
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
W Direct to customer export of medical device (class I: prescription lenses + frame) US Food and Drug Administration (FDA) 2
S How to treat a customer complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
JoCam Labeling to Customer Requirements EU Medical Device Regulations 1
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
Q Customer Satisfaction through On-Time Delivery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
0 PPM calculation of customer complaints for PMS Customer Complaints 10
