Customer Print Specifications on PFMEA
vailmij
Hello, I hope you all would be willing to help clarify something for a me:
Should ALL customer print specifications and notes be included as Requirements on a PFMEA?
For example, a drawn metal component that has print specs such as OD, ID, OAL, Radii, Pierce Hole Diameters, Angles, Chamfers, etc. and notes such as "burrs no larger than X" or "parts must be free from cracks splits...". There are typically 20 - 40 specs on each print - many of which are only measured at set-up (first piece) because they are what we consider "tool-controlled."
The PFMEA should be based on the process steps shown in the process flow diagram. For each process step, potential failure modes (of the process, preferably) should be considered. There is no need or requirement to base the PFMEA on drawing dimensions/requirements.
vailmij
Thank you for your reply, Jim. Couldn't it be said though that an oversized OD, for example, is a potential failure mode of the stamping process? I guess I'm just having a hard time understanding the distinction between product specifications and process requirements.
I did some research before posting and found this thread from last year. They seem to interpret that product specifications are the Requirements.
How to fulfill PFMEA "requirement" column?
In such a case, it would seem that we would need to list all product specifications on a PFMEA. I personally do not agree with this interpretation, but there is obviously some confusion.
Edit: Added link to a previous thread.
I take a different approach, one that to me makes more sense in defining failure modes. I think it's best to define failure modes as failures of the process (as opposed to part defects), with the effects being the manifestation of process failures. The thing is called, after all, Process Failure Mode and Effect Analysis. So--the process failure mode might be "Worn punch" with one of the possible effects being ".150 ±.005 hole oversized."
You don't necessarily list all print specifications--you determine what the possible process failure modes are and the potential effects.
optomist1
A Sea of Statistics
remember PFMEA/DFMEAs are a team sport, a diversity of inputs from team members usually yields a better outcome...a collaborative effort...
vailmij
So, using this example, your PFMEA would read:
Process Step: Stamping
Requirement: Fully Formed Part​
Potential Failure Mode: OD Oversized​
Potential Cause of Failure: Worn Die​
Potential Failure Mode: ID Undersized​
Potential Cause of Failure: Worn Punch​
Potential Failure Mode: Missing Pierce Hole​
Potential Cause of Failure: Broken Punch​
........ etc.
rather than:
Requirement: OD .150 ±.005​
Requirement: ID .120 ±.005​
Requirement: Pierce Hole .020 ±.001​
Hi, yes we are pretty good about getting several people involved in the development of our PFMEAs. We recently had a minor non-conformance from our IATF audit in regards to some discrepancies on our PFMEAs. That sparked the conversation about whether or not we are creating the PFMEAs correctly.
Golfman25
Vailmij, you can do both ways. We do family PFMEAs (old form) so we use "generic" terms like OD oversized/undersized. We actually call out the operations, such as "Trim" and then identify the failure modes such US/OS dim., burrs, etc. Then identify effects, usually assembly issues, and then causes and controls.
One note, even if something is tooling controlled it should go on the FMEA as a failure mode. It wouldn't be part of your in process controls on your control plan.
Good luck.
vailmij
Hi Golfman,
That is an interesting idea. So say, an operation is "piercing" but there are multiple different-sized pierce holes, one of which is a CC. How do you identify and score the CC item separately on such a PFMEA?
C Control Plan - Links to Customer Documents (e.g. Print) or the Actual Specifications? FMEA and Control Plans 22
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
E Conflicting dimensions on customer print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K APQP requirement when a new print or spec is received from a customer - Existing Part APQP and PPAP 3
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
A Sample Parts vs. Controlled Customer Prints? Parts to Print but Rejected Quality Manager and Management Related Issues 6
P Is a Drawing (Print) Customer Intellectual Property? ISO 13485:2016 - Medical Device Quality Management Systems 16
R CAD Print Conflicts with the Customer Supplied Paper Drawing Manufacturing and Related Processes 19
G Manufacturing Aide - Putting a "Manufacturing Aide or note" on a customer print? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M What to "bubble" on customer print vs. internal print APQP and PPAP 4
T Control of Customer Supplied Material - Build to Print Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Customer changed print without notice and is now rejecting parts - What to do? Manufacturing and Related Processes 11
K Yet another design question - Customer is asking for a print but we do not do design Design and Development of Products and Processes 19
J TS 16949 Clause 4.2.3.1 - Customer Print Revisions IATF 16949 - Automotive Quality Systems Standard 3
G Customer Print Control Document Control Systems, Procedures, Forms and Templates 3
R PPAP-Number & Layout Customer Print or Mine? APQP and PPAP 1
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
G Too many customer complaints Customer Complaints 16
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
S Obligation to accept customer audits? IATF 16949 - Automotive Quality Systems Standard 23
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
