Customer Property Identification Requirement - ISO 9001 Clause 7.5.4
Big Jim
#41
Requirements in the standard that are applicable to individual customers, (such as the one that's the subject of this thread) may be waived by individual customers. The waiver should be in writing, and specific as to the scope of the waiver.
Can you elaborate on this?
#42
TO give an example from the clause under discussion (7.5.4), there's this bit: "If any customer property is lost, damaged, or otherwise found to be unsuitable for use, this shall be reported to the customer and records maintained." Putting aside the grammatical train wreck of that sentence, a customer may waive the reporting requirement, but perhaps not the record-keeping part of it.
Richard Pike
#43
If any Customer Property is lost etc, this will have consequences to the production process and the Customer would have to be informed of the situation (i.e the property cannot simply be replaced). This is a typical example of the fact that no requirement of any standard can be viewed in isolation!
Big Jim
#44
I still don't see a justification for a waver. Is there an element of the standard you can point out that allows a waver? It certainly isn't 1.2.
Richard Pike
#45
Of course an organization must notify its Customer if it damages (or otherwise) their property. If they don't, the will infringe numerous other QMS requirements as well as customer trust, not to mention production integrity because they are now not using the equipment that was agreed. The method that is used to do this must be recorded, even if only by filing a copy of an email. This is surely just normal business practice, regardless of whatever QMS is in place.
Marc
#46
I think as Jim has pointed out, this would be for a specific customer and would not apply to any other customer. A specific customer may not see a need for any accounting, for what ever reason. Because of this, we can not, from what we know in this thread at this point, know why a customer would waive tracking / accounting for their property, so it's really not relevant. If a customer waives that requirement, it is their prerogative. It may be unusual, bit apparently is does happen.
This does not relieve the company from complying with the standard for any customer who has not waived the requirement.
As to an element of the standard that allows a waver, there isn't anything in the standard which says a customer can *not* waiver the requirement.
Richard Pike
#47
Baffled- So if i have a single dedicated customer and that customer waives ALL requirements ? :notme:It seems that we are only going to get "opinion" here and as most Auditors opinion are of course wrong.:rolleyes:. My "opinion" for what it is worth is that normal business sense will apply, that all organizations will comply - to the degree necessary - to meet the requirements. Of course business sense must be coupled with auditor sense. I appreciate everybodys input though - thanks.
#48
Let's say that our business is taking something received from the customer and somehow "adding value" to it. The things we receive belong to the customer, but thousands of them are received weekly, and our process is such that some small percentage of them are scrapped. The customer is aware of the fallout and has no problem with it. We tell the customer that the standard requires us to report loss of their property, and they tell us that they don't want to be bothered with it. Does the standard require us to annoy the customer? No.
howste
Thaumaturge
#49
ISO 9001 doesn't specifically mention waivers, but here's what 1.2 does say:
Where exclusions are made, claims of conformity to this International Standard are not acceptable unless these exclusions are limited to requirements within Clause 7, and such exclusions do not affect the organization's ability, or responsibility, to provide product that meets customer and applicable statutory and regulatory requirements.
1) 7.5.4 is within clause 7.
2) In the case mentioned by Jim, waiving the reporting requirement (by the customer) doesn't affect the organization's ability to provide product meeting requirements.
It looks like it's allowed to me.
Marc
#50
<snip> So if i have a single dedicated customer and that customer waives ALL requirements <snip>
Requirements that apply to specifically to them, yes. Many requirements of the standard are not customer specific so to answer your question - No. A customer can not waive all the requirements of the standard.
Let's say you are a company with one customer. That customer does not supply any 'customer supplied materials' or other things such as returnable packaging. Since you have no 'customer supplied materials' it becomes a 'not applicable' requirement. However, the company must address the requirement in some way if only to specifically state in their documentation that there are currently no customers which supply 'customer equipment or supplies or product', but should the situation arise where a customer does supply 'customer equipment or supplies or product' a system to track and manage the 'customer property' will be established and implemented.
The point here is if you have no customers which supply materials or other 'property', how can you set up a system, and provide evidence that the system works?
A Identification of Customer Property: Customer-Supplied Thumb Drives & Ext Hard Drives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Identification of Customer Property - Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Customer Property Tools - par. 7.5.4.1 - Electronic identification of a certain tool IATF 16949 - Automotive Quality Systems Standard 6
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
C What falls under the 'Customer Property' according to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 10
S Customer Property - If at all the customer return the product ISO 13485:2016 - Medical Device Quality Management Systems 2
M Damaged Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 7
M Receiving Inspection of Customer Owner Property IATF 16949 - Automotive Quality Systems Standard 5
E Owns Customer Property but No Product Integration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Uriel Alejandro 7.5.4 Customer Property in a Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S ISO 9001 Clause 7.5.4 - Damaged or Lost Customer Property Record ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E ISO 9001 - 7.5.4 Customer Property - Services (e.g.: Training) on Rental Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Does anyone have an example Customer Property Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
B Customer Property Exclusion as it applies to Personal Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P Is a Drawing (Print) Customer Intellectual Property? ISO 13485:2016 - Medical Device Quality Management Systems 16
L Customer Property Checklist example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
somashekar FDA cGMP on Feedback, Advisory Notice and Customer Property 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Customer Property Log example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
E How Do You VERIFY Customer Property? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Customer Property ISO 9001:2008 Clause 7.5.4 - Does this include E-mails? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Supplier's Property - Does 7.5.4 Customer property apply to supplier's property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N Customer Property Logs - Tracking customer property, specifically production tooling IATF 16949 - Automotive Quality Systems Standard 5
B What is Customer Owned Property for moulds and spare parts factory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Notification of lost/damaged Customer Property - Customer Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Customer Property - The best way to inspect MLO and what acceptance criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D TS 16949 Clause 7.5.4 Customer Property, Intellectual Property requirements IATF 16949 - Automotive Quality Systems Standard 5
M 7.5.4 Customer Property - ISO 9001:2008 Intellectual Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Can I exclude Customer Property? ISO 9001 Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
D Clarification on "Customer Property" - TS 16949 Clause 7.5.4 IATF 16949 - Automotive Quality Systems Standard 4
6 Customer Property documentation (Audit Finding) - Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Can the documents supplied by the client categorised as customer property?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
H What can be customer supplied properties (property) for the software industry? Software Quality Assurance 18
K Customer Property - Notifying Customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Purchase Order and its relationship with customer property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Absence Of Any Form Of Customer Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Identifying production dies to satisfy the 7.5.4 Customer Property clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Not having a form for Customer Property Damage - ISO 9001 Clause 7.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Customer Supplied Property - System breakdowns at every level including sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A How is Customer Property defined by TS 16949? IATF 16949 - Automotive Quality Systems Standard 4
G 7.5.4 Customer Property (Shipping Containers) IATF 16949 - Automotive Quality Systems Standard 2
K Defining Customer Property - Specifications, templates, patterns from customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
T Customer Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Claes Gefvenberg Customer Property - 7.5.4 (intellectual property) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Customer Property - 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
