Customer Property - The best way to inspect MLO and what acceptance criteria
bronco-vinny
I was writen up by our customer for :mad:
AS9100 Rev. B , Section 7.6 Control of Monitoring and Measuring Devices
For Lack of control on MLO (PCM/Mylar) tools uses as Media Of Inspection.
* No objective evidence that MLO periodic check was performed
* No process to perform MLO grid check/dimensional targets check prior to use.
What is the best way to inspect MLO and what acceptance criteria should I use?:thanx:
Wes Bucey
Prophet of Profit
Re: Customer Property
Since you have cited AS9100, I've moved the thread to the Forum specific for that Standard.
I don't have an "extractable copy of the AS9100 Standard, but since it is based on ISO 9001, and has similar numbering, the ISO Standard clause might suffice:
7.6 Control of monitoring and measuring equipment
The organization shall determine the monitoring and measurement to be undertaken and the monitoring and measuring equipment needed to provide evidence of conformity of product to determined requirements.
The organization shall establish processes to ensure that monitoring and measurement can be carried out and are carried out in a manner that is consistent with the monitoring and measurement requirements.
Where necessary to ensure valid results, measuring equipment shall
a) be calibrated and/or verified, or both, at specified intervals, or prior to use, against measurement standards traceable to international or national measurement standards; where no such standards exist, the basis used for calibration or verification shall be recorded (see 4.2.4);
b) be adjusted or re-adjusted as necessary;
c) have identification in order to determine its calibration status;
d) be safeguarded from adjustments that would invalidate the measurement result;
e) be protected from damage and deterioration during handling, maintenance and storage.
In addition, the organization shall assess and record the validity of the previous measuring results when the equipment is found not to conform to requirements. The organization shall take appropriate action on the equipment and any product affected. Records of the results of calibration and verification shall be maintained
(see 4.2.4).
When used in the monitoring and measurement of specified requirements, the ability of computer software to satisfy the intended application shall be confirmed. This shall be undertaken prior to initial use and
reconfirmed as necessary.
NOTE Confirmation of the ability of computer software to satisfy the intended application would typically include its verification and configuration management to maintain its suitability for use.
Your thread title says "Customer Property" - I don't see how that is pertinent.
It seems apparent to me an organization should tend to ALL its monitoring and measuring equipment should be cared for and kept in calibration if it is used in operations, regardless of who owns it, since the manufacturer conforming to the Standard is responsible for the equipment while in use regardless of who supplies it.
What do YOU mean by MLO? My only use of such acronym or abbreviation has a definition of "Material, Labor, and Overhead."
Added in edit:
It took me about 15 minutes to figure out "MLO" went with "inspection" as "Master Layout"
(My AHA moment!)
P 7.5.10 Customer property - applies to leased/rented equipment? ISO 13485:2016 - Medical Device Quality Management Systems 10
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 9
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
C What falls under the 'Customer Property' according to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 29
S Customer Property - If at all the customer return the product ISO 13485:2016 - Medical Device Quality Management Systems 2
M Damaged Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 7
A Identification of Customer Property: Customer-Supplied Thumb Drives & Ext Hard Drives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Receiving Inspection of Customer Owner Property IATF 16949 - Automotive Quality Systems Standard 5
E Owns Customer Property but No Product Integration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Uriel Alejandro 7.5.4 Customer Property in a Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S ISO 9001 Clause 7.5.4 - Damaged or Lost Customer Property Record ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E ISO 9001 - 7.5.4 Customer Property - Services (e.g.: Training) on Rental Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Does anyone have an example Customer Property Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
G Customer Property Cl. 7.5.4 - Where does ISO 9001 stop and ISO 27001 start? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
B Customer Property Exclusion as it applies to Personal Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Identification of Customer Property - Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P Is a Drawing (Print) Customer Intellectual Property? ISO 13485:2016 - Medical Device Quality Management Systems 16
L Customer Property Checklist example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
somashekar FDA cGMP on Feedback, Advisory Notice and Customer Property 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Customer Property Log example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
E How Do You VERIFY Customer Property? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Customer Property Identification Requirement - ISO 9001 Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 77
Q Customer Property Tools - par. 7.5.4.1 - Electronic identification of a certain tool IATF 16949 - Automotive Quality Systems Standard 6
J Customer Property ISO 9001:2008 Clause 7.5.4 - Does this include E-mails? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Supplier's Property - Does 7.5.4 Customer property apply to supplier's property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N Customer Property Logs - Tracking customer property, specifically production tooling IATF 16949 - Automotive Quality Systems Standard 5
B What is Customer Owned Property for moulds and spare parts factory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Notification of lost/damaged Customer Property - Customer Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D TS 16949 Clause 7.5.4 Customer Property, Intellectual Property requirements IATF 16949 - Automotive Quality Systems Standard 5
M 7.5.4 Customer Property - ISO 9001:2008 Intellectual Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Can I exclude Customer Property? ISO 9001 Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
D Clarification on "Customer Property" - TS 16949 Clause 7.5.4 IATF 16949 - Automotive Quality Systems Standard 4
6 Customer Property documentation (Audit Finding) - Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Can the documents supplied by the client categorised as customer property?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
H What can be customer supplied properties (property) for the software industry? Software Quality Assurance 18
K Customer Property - Notifying Customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Purchase Order and its relationship with customer property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Absence Of Any Form Of Customer Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Identifying production dies to satisfy the 7.5.4 Customer Property clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
H Not having a form for Customer Property Damage - ISO 9001 Clause 7.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Customer Supplied Property - System breakdowns at every level including sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A How is Customer Property defined by TS 16949? IATF 16949 - Automotive Quality Systems Standard 6
G 7.5.4 Customer Property (Shipping Containers) IATF 16949 - Automotive Quality Systems Standard 2
K Defining Customer Property - Specifications, templates, patterns from customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
T Customer Property ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Claes Gefvenberg Customer Property - 7.5.4 (intellectual property) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Customer Property - 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Customer requirements on specific standards Various Other Specifications, Standards, and related Requirements 4
Crimpshrine13 Customer Scorecards - Missing Scorecard from one Customer IATF 16949 - Automotive Quality Systems Standard 27
B Customer Preference Testing Customer and Company Specific Requirements 2
