Customer Radiation Requirement headache
rstocum
Last year one of our major customers warned us that they would start requiring certification that materials used to make their parts have less than a stated level of ionizing radiation. This month, we started receiving revised drawings from this customer with a new specification referenced that makes this new requirement official. The specification bans the presence of a number of substances like cadmium and mercury, which our suppliers already certify is not present in the materials they supply except in trace amounts.
My initial contact with one of our bigger material distibutors indicates that their suppliers check for radiation on their incoming materials, and when their finished materials are outgoing. They do not have a generic compliance letter to this effect. I am not sure how to approach getting a compliance letter of this type. I can't contact each manufacturer the distributor buys from, whose material we use.
Has anyone else had to deal with a radiation requirement like this? How did you handle it?:confused:
Wes Bucey
You can, however make a value decision among suppliers by including to each a statement to the effect
"If you cannot supply traceability of each lot of material back to original mill with that mill's certification the material meets our stated radiation level criteria, nor (in the absence of such certification) provide your own certification by an independent lab for EACH lot, then we can no long purchase material from you."
Alternately, You can purchase a calibrated radiation detection device and announce to each supplier that
"shipments which do not pass radiation inspection will be rejected and returned to supplier at supplier's expense."
There is a method and reason to this apparent "out-of-the-blue" request by your major customer.
Some mills throughout the world have been buying scrap metal from facilities where much of that scrap has been contaminated by cobalt60.
Obviously, mills which buy this contaminated scrap are considered likely candidates to lie (or be completely ignorant) about the source of their scrap, which may give them a profit advantage.
MIREGMGR
This probably is a requirement that we should consider adding to our small quantity purchases of fabricated stainless parts.
Can anyone supply a copy of such a specification?
Wes Bucey
This is a case where I would make it a point to consult a prime source and not depend on casual comments from folks in a discussion forum to make my final decision. I know what I might write in general, but I have no clue to the correct instrumentation or min/max readings of such instruments to provide an acceptance criterion.
Thus said, why not pose the question to the Nuclear Regulatory Commission?
rstocum
MIREGMGR,
I can't give you a copy of our customer's spec, but I can tell you that it requires our finished product to emit less than 1 Bq/g of any type of ionizing radiation.
As I am unfamiliar with handling radioactive material I had to look Bq/g up. It stands for Becquerels per gram. 1 bequerel = .000000027 millicuries of radiation, and is apparently the measure of 1 nucleus decay per second.
This seems to me to be a teeny, tiny amount of radiation! Can anyone tell me if my impression is correct? I am assuming that detection equipment sensitive enough for this specification would not be easy to get, or inexpensive.
Wes,
Thank you. Your suggestion will probably be the only approach I can use.
Randy
A Becquerel is very small unit indeed but it's what is used in lieu of the "curie" and the smaller curie elements ...as you stated millicurie....as a more precise tool.
I am familiar with the handling of ionizing material and their requirement may be based upon multiple factors including national regulations, identified industrial hygeine and health issues and product safety requirements.
What needs to be understood is that all radioactivity is not the same and the effects of smaller quantities of one isotope may be more destructive than those of larger ones...a exposure to 10 curies of Tritium (you pee will glow under UV) is nowhere near as bad as expose to a 0.01 curie exposure to Plutonium (your bladder may be disolved if expose is long enough). Of course this may be a bad example because of the different Alpha, Beta and Gamma properties of each but that is essentially it.
I didn't pay attention to your location, but here in the US under OSHA and a smathering of other regulations you may need to have a RSO or RPO (radiation safety officer, radition protection officer) or whatever you want to call them to manage an ioning radiation program for you...This of course is dependant upon the sources, activity levels and you legal environment.
OK...Indiana...US OSHA to start with...
You may want to check this US Fed OSHA link out which has been adopted in its entirety by Indiana OSHA....http://www.osha.gov/pls/oshaweb/owadisp.show_document?p_table=STANDARDS&p_id=10098
There is other information available on the web. The request you are having to meet is not unusual or out of line, one of my clients, a major metal producing company has the same requirement for metals sent to it for recycling. Let me check if there is public information on that because I cannot violate confidentiality if there is not.
H
Hemi999
Quicker then the NRC would be to search out and ask the State radiation office. Each state has one and they could give you an answer quicker then the NRC.
rstocum
Update:
I drafted a compliance letter and had purchasing send it out to all suppliers who supply components or raw material to the customer with this requirement. The signed letters are trickling in, and those who don't return one will get a follow up call. If they end up not signing to it, they will be replaced.
If anyone is interested in a sanitized copy of the letter, I will try to attach a copy to this thread. It is pretty generic, but it will have the company name, etc. changed.
The customer with the requirement has already done an on-site audit here, and covered what we are doing about the requirement. We did good in the audit, but I still questioned the amount of radiation in the requirement, and how to detect it. The auditor didn't know, but promised to look into how the requirement was developed to see if the requirement was unreasonable.
Fat chance I'll ever hear anything back on that one, but it was worth asking.
Thanks again to all who advised on this one.
Rich
D Suggestions for Ishikawa for hyperdetailed customer - plastic molding automotive parts Nonconformance and Corrective Action 9
J WAIVED ON Q1 - We Don't have to comply with FORDS customer specific requirements IATF 16949 - Automotive Quality Systems Standard 2
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
M IATF16949 Clause 9.1.2.1e - Customer notification related IATF 16949 - Automotive Quality Systems Standard 4
G Too many customer complaints Customer Complaints 16
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
S Annual Inspection Layout - Based on Customer print ? IATF 16949 - Automotive Quality Systems Standard 8
G Risk of stopping your customer's line IATF 16949 - Automotive Quality Systems Standard 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
G Bad Parts cause Customer line stop IATF 16949 - Automotive Quality Systems Standard 13
O IATF 16949 News Ford Motors Customer Specific Requirements Update - Nov 2020 IATF 16949 - Automotive Quality Systems Standard 5
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
B Retention Samples when Customer Leaves Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
M Email Template that go to a customer and then get returned to us for RMA/Warranty Document Control Systems, Procedures, Forms and Templates 1
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
V Quality review Meeting with Customer for complaints we received Customer Complaints 6
D IATF16949 - Interpretation of Customer Requirements clauses IATF 16949 - Automotive Quality Systems Standard 3
S Obligation to accept customer audits? IATF 16949 - Automotive Quality Systems Standard 23
D IATF16949 7.5.3.2.1 Record Retention - Our Product or Customer Product? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
S Customer Specific Requirements (CSR) not signed/approved IATF 16949 - Automotive Quality Systems Standard 17
B FCA US IATF 16949 Customer Requirements updates Customer and Company Specific Requirements 3
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Ooi Yew Jin Customer E audit preparation Quality Manager and Management Related Issues 2
qualprod Managing a "special" customer into the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Who is the customer in the ISO/IEC 17025:2017? ISO 17025 related Discussions 1
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Design Transfer Template capturing Customer Specific Requirements Other Medical Device Related Standards 3
W Direct to customer export of medical device (class I: prescription lenses + frame) US Food and Drug Administration (FDA) 2
S How to treat a customer complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
JoCam Labeling to Customer Requirements EU Medical Device Regulations 1
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
Q Customer Satisfaction through On-Time Delivery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
T Nonconforming product at customer detected by a routine inspection by field service Nonconformance and Corrective Action 9
0 PPM calculation of customer complaints for PMS Customer Complaints 10
