Customer Satisfaction - Would you advise to investigate the trend or the incidence?
K
Ka Pilo
ISO 9000:2005 - 3.1.4 customer satisfaction
customer's perception of the degree to which the customer's requirements (3.1.2) have been fulfilled
NOTE 1 Customer complaints are a common indicator of low customer satisfaction but their absence does not necessarily imply high customer satisfaction.
NOTE 2 Even when customer requirements have been agreed with the customer and fulfilled, this does not necessarily ensure high customer satisfaction.
If the complaints are due to perception (not a "fault"); would you advise to investigate the trend or the incidence?
Al Dyer
Re: Customer Satisfaction - Would you advise to investigate the trend or the incidenc
In any situation trend is the way to go. Individual complaints are overtly subjective and can lead to incorrect actions. Also, if there is any question about the cause's there is a problem with the process.
For what's it's worth
Al...
somashekar
A complaint due to perception perhaps has got to do something about user information or lack of it and it depends upon the type of product and maturity level of the customer. You need to investigate it and decide from that if any corrective action is necessary even perhaps like a demo of the product to a larger user group. No complaint must be ignored, but the level of action must be decided based upon the investigation.
However the perception part about customer in a customer satisfaction process has got to do more than just product quality or complaint. Its about the business and effective interaction and communication and benefits that are shared between the customer and supplier.
How often has the supplier increased the cost due to input costs going up Vs How often has the supplier reduced the cost due to costs saved by an internal improvement activity ... ? What is the customer's perception on this. Can you discuss a small cost reduction with your customer with some enhanced volumes or assured annual requirements ?
Customer requirement goes beyond product requirement and complaints. When you look at this perception of customer satisfaction, you need to look at trends.
The NOTE 1 and 2 is just making us aware of these ~~~
Al Dyer
I really would like to read more opinions about customer requirements and how we are "possibly motivated" to turning those into our own perceptions about what they "really want".
To me that smacks of giving customers what we think they need as opposed to what they technically ask for.
Thanks, Al...
P
pldey42
Some examples:
Trends indicated lots of mobile phones being returned to the manufacturer marked "wrong colour". Yet in many cases the phone colour was as it said on the box -- red, black, blue, whatever. Investigation of specific incidents revealed that customers, variously, didn't like the shade of red, blue, whatever; or had simply misread the box, or had assumed they were all black. A hole was added to the box so that the customer could see the colour of the phone inside, even the shade and texture of the case. The trend of returns due to "wrong colour" went down.
Return rates for electronic amplifiers were generally low. Trend analysis performed by the manufacturer revealed that one customer returned significantly more products marked "dead on arrival" than the others. The returned product was, indeed, dead. Analysis of incidents with the customer concerned revealed that he had discovered that, while the spec promised 20 watts output, many could be driven to produce 30 watts. He was testing them all on arrival and returning those that blew when he tried to make them produce 30 watts. The manufacturer put in an overdrive protection circuit. No longer would some produce more than the rated 20 watts. Returns went down -- and sales of the 30 watt product went up a little.
I go to the shop. "I want a toaster," I say. I take it home and it bursts into flames and burns the house down ... A while later, I take it back to the shop. "It met my verbal specification," I say, "But I thought you would know it must meet the requirements for electrical and fire safety. My perception of your product is -- it's supposed to toast bread, not houses."
I order a hotel room. Double bed, no smoking, says the specification. The room, while clean, is right next to the elevator shaft and noisy -- I can't sleep. My perception of my satisfaction is low. The room met the formal spec; the ability to sleep was an unstated, but obvious, requirement. The hotel won't understand (and maybe fix) my dissatisfaction from trend analysis, not unless they ask about the incident.
Investigate trend or incidents? Both, say I. (Maybe not all the incidents, but some, surely.) Use trend analysis to decide which incidents, or classes of incident, to investigate.
Yes, it's true that when we measure customer perception of quality there's a risk of giving them what we think they need instead of what they want. But if we define quality as simply "meeting the specification" there's a risk of losing business when the spec is wrong and we don't realize.
Also, customers don't always understand as much about our product space as do we, so we have to help them with the specification using our expertise -- that's why ISO 9001 says we should meet their unstated requirements as well as their stated ones.
Hope this helps,
Pat
E
Eloisa
Hello....I hope you experts could help me....
Is it possible to give me a guideline a methodology on how to perform risk analysis on customer returned part.
Ex : We receive 1 returned unit from customer, how will we know how many more are potentially affected. We have been able to come out with data and potential risk numbers for our returns. But we always ask...how do we start? Coud you shed light on this.
Thanks,
Eloisa
samsung
In my opinion, 'perception' may or may not generate actual 'complaints'. Percepts are accumulated over time through association, experience and learning whereas a 'complaint' is a direct reporting of problem/ grievance by the customer and can simply be an instantaneous reaction. e.g. a delayed delivery which the customer expected to be delivered a bit earlier, can be a cause of complaint but may not necessarily lead to formation of a poor/ negative perception of the supplier. Percepts can be about many things not forming part of the contract. e.g. perception about the capability of the organization. It can be positive, negative, right or wrong or misleading. If an organization doesn't communicate and inform it's existing and prospective customers properly, they might have/develop wrong perceptions of its capability and may switch over to another supplier without making any complaint of it.
Complaints are in one way better than negative or wrong perceptions because they directly come to you (whether you like them or not) without making any efforts whatsoever but unless you approach the customers in some way, you will never know what customers perceive about your organization, products or services. What if you don't ask or inform your customers, e.g. about your strengths, capabilities, future plans etc., no one will complain but will perhaps silently move away if they have some adverse perceptions.
mayank_thkkr
The customer requirements are generally categorized as below: Stated, Implied or Obligatory. Say for example If I am buying electronic equipment say for example Mobile, all the accessories which are necessary for the functioning of Mobile will be stated requirements (Legal) (Like Charger, Battery, Hands free etc) Implied are those things which you have to provide in order to achieve the functionality, which are not committed by in order to achieve function you have to provide it. (Example can be Universal plug for charging, Data card reader etc) the last one obligatory is the one which company provides to it's customer as part of customer satisfaction or delight.
Most of the time Stated requirements of Customer are fulfilled with all due care, the requirements pertaining to Implied and Obligatory makes difference as it differs from Company to Company, Place to Place.
harry
The Industrial market is quite different from consumer market. Industrial markets are characterized by technicalities - requirements are all stated or specified (you don't leave it to implications and you need to review customer requirements aka contract review). What could be implied are the supporting services.
R Customer Satisfaction importance in companies with Government/Public Administration as main customer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Customer Satisfaction through On-Time Delivery ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Have sites like Ebay and Amazon killed customer satisfaction/feedback? Customer Complaints 7
I ISO9001:2015 9.1.2 - Customer Satisfaction Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V AS9100 8.2.1 (C) or 9.1.2 (D) Customer Satisfaction - KPI's AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K How can I monitor customer satisfaction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
C Customer Satisfaction Process - Audit "Suggestion for Improvement" General Auditing Discussions 14
Ajit Basrur CDRH Customer Satisfaction Results at 87% US Food and Drug Administration (FDA) 1
R Why customer satisfaction is not appropriate regulatory objective in medical device? ISO 13485:2016 - Medical Device Quality Management Systems 8
G How to assess Customer Satisfaction without using surveys ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Customer Satisfaction Measurement When You Have Only 1 Customer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Conduct Customer Satisfaction Survey for every submitted Bid? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Looking for a Customer Satisfaction Survey Form Other Medical Device Related Standards 2
Z Customer Satisfaction Survey Analysis Quality Tools, Improvement and Analysis 2
E Marketing and Sales involvement in 8.2.1 Customer Satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Customer Satisfaction Survey - Poor Response ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Customer Satisfaction for Legal Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Need to prepare Internal Customer Satisfaction Survey form for QA department Misc. Quality Assurance and Business Systems Related Topics 5
M Customer Satisfaction Excel File Customer Complaints 3
C Customer Feedback, Satisfaction, Complaint Procedure and Measurement Customer Complaints 8
M 8.2.1.1 - Customer Satisfaction - How to satisfy the end requirement? IATF 16949 - Automotive Quality Systems Standard 1
M 8.2.1 ?NOTE- Is Monitoring of Internal Customer Satisfaction a requirement? IATF 16949 - Automotive Quality Systems Standard 1
E 8.2.1 Customer Satisfaction - Is Internal Customer Satisfaction Employee Satisfaction IATF 16949 - Automotive Quality Systems Standard 6
W Customer Satisfaction Surveys in Oil Industry Customer Complaints 8
M Customer Conversion and Retention / Satisfaction Measurement Index Benchmarking 4
B Increasing Customer Satisfaction While Decreasing Employee Workload Customer Complaints 4
R Supplier Satisfaction Survey about Working with us as a Customer Supplier Quality Assurance and other Supplier Issues 7
R Setting Targets (Objectives) for Customer Satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Customer Satisfaction Surveys - User Friendly & Online methods. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Customer Satisfaction Surveys - Response Rate, Analysis, Customer Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Minitab for Customer Satisfaction Analysis Using Minitab Software 1
J How to Increase Customer Satisfaction Rating? Customer Complaints 20
I Calculating the CSI (Customer Satisfaction Index) Misc. Quality Assurance and Business Systems Related Topics 17
K Definition Customer Satisfaction - ISO 9001 Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 16
R Analyzing Customer Satisfaction Indexes Quality Manager and Management Related Issues 1
Antonio Vieira Customer Satisfaction Survey Sample Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
F Customer Satisfaction Survey - Further actions needed for Customers Comments? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
E Customer Satisfaction - Customer Perception of Government Contract Officers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V Complaints Handling Responsibility - Customer Satisfaction - ISO 10002 Clause 5.3.2 Customer Complaints 9
Sidney Vianna ISO 10004:2012 - Customer satisfaction - Guidelines for monitoring and measuring Other ISO and International Standards and European Regulations 18
B Quality Policy - Need to include "Customer Satisfaction & Continual Improvement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Customer Satisfaction Reporting Responsibilities Career and Occupation Discussions 10
H Determining Customer Satisfaction in a Small Aerospace Job Shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Is it mandatory to monitor customer satisfaction for a non-regular product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C The "Perfect Order" as a Customer Satisfaction Measurement Customer Complaints 7
D Obtaining Customer Perception Information - Customer Satisfaction - Clause 8.2.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D 8.2.1 Monitoring & Measuring customer satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T How to monitor customer satisfaction without surveys? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
K Customer Focus with the aim of enhancing customer satisfaction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
