Customer Supplied Product & Certifications - Drop Ship - FDA and ISO 13485
abrnidgrl
We have a customer that is purchasing product from another supplier and then they (the other supplier) drop ship directly to us. However all of the certificates and other documentation are going directly to the customer. From an FDA and ISO13485 standpoint, can we treat this as customer supplied product and use it as is?
Coury Ferguson
Moderator here to help
Fellow Cove members-do you have any suggestions or recommendations for this Cover?
Big Jim
I'm not familiar enough with ISO 13485 to respond specifically to that standard, however I think it would be a poor practice. I'll admit that my response is colored by the "anti wank" clauses of AS9100B which hold an organization responsible even if the customer specified a supplier.
No matter where it comes from, you really should screen everything that you use to build product. Just like anything else you consume in the build, the level of scrutiny needed varies with its impact on the final product.
At the very least ask your customer what they would like checked or what they would check before acceptance if they were receiving it.
What you want to avoid is building product that isn't suitable for your customer for any reason, even if it could be considered the "customer's fault".
MIREGMGR
From an FDA perspective:
I assume that you'll be doing further manufacturing on the product/material that your customer is having their supplier ship directly to you.
If your relationship with your customer is as a Contract Manufacturer, your contract with them should clearly state that status, and that they are either the Specifications Developer, or the Manufacturer if they do further operations on the product before it's marketable.
The Specifications Developer or Manufacturer has primary regulatory responsibility for the final product. A Contract Manufacturer nonetheless has co-responsibility for all aspects of the final product that are related to those elements of its production over which they have substantial control.
I would think that an FDA inspector under QSIT procedures readily would conclude that, if the supplier ships directly to you, you have full responsibility for Incoming Inspection and for verification of purchasing conformance, because you have substantial control over received goods and your customer is not physically present...unless they have personnel at your facility, or your contractural relationship calls for you to notify them to send such personnel, to perform those responsibilities whenever something arrives that they purchased.
As a Contract Manufacturer, it's your responsibility under Contract Review to ensure that your contract with your customer adequately defines all regulatory aspects of your relationship. Your customer is responsible for offering you a contract that adequately defines regulatory responsibilities, and for controlling your actions. They're really dropping the ball if their regulatory people aren't discussing with you what you have to do to make it possible for them to meet FDA requirements.
achorste
We are doing a similar thing with one of our sub-contractors - the raw material supplier is drop shipping to them, they do their processing & it's shipped on to us.
However as we do not see the product until it gets to us & it is not in it's original form I would expect our supplier to inspect to the required standard (in fact we are including that in the contractual agreements). We are supplying them with full inspection specifications.
In any case, as mentioned before) as the end customer is not seeing the product before you process it it would be risky not to perform your own inspection of the product. Although this situation is not called out directly in the applicable standards, it could be seen as an un-necessary risk for the business & as such merits some kind of control. Does the end customer have specifications / standards for the drop shipped product? Is it possible to get copies of the documentation delivered with the product?
Of course I do not know the products being supplied, and I may be completely off track but it's my tuppence worth :D
abrnidgrl
Thanks everyone. :thanx:
We do inspection of the product prior to assembling it and sending it on to the customer, but we do not get copies of the vendor's CofC, etc. I'm not sure if this changes the requirements or not, but we do verify that the assembly works prior to shipment. We have requested that the information be sent along with the product, however the vendor does not want to send us copies as well as our customer.
:frust:
brandomenon
It would probably be easiest for your company to develop a receiving inspection process with the help of the customer. Two options would be:
1) Have them notify you that they have reviewed the CoC and they accept the product for assembly.
2) Have the customer create the list of criteria to add to a receiving inspection form for inspecting incoming drop shipments (and maybe include it in a quality agreement you might already have)
Gman2 Coating Company, ALL customer supplied product? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Customer supplied product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R PPAP from Customer for Customer Supplied Product - Material to be machined APQP and PPAP 2
M Customer Supplied Product - When does it become that? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Customer Supplied Product and Traceability - No Customer Requirement - Toll Processor IATF 16949 - Automotive Quality Systems Standard 8
G Customer Supplied Product - Problem with who is responsible for what Document Control Systems, Procedures, Forms and Templates 9
J Design exclusion - Service company that processes only customer supplied product Design and Development of Products and Processes 2
D Customer Supplied Product - Machine Shop Misc. Quality Assurance and Business Systems Related Topics 1
E QS 4.7 control of customer supplied product QS-9000 - American Automotive Manufacturers Standard 10
D Element 4.7 Customer supplied product QS-9000 - American Automotive Manufacturers Standard 3
J Definition Customer Supplied Product - Definition (including returnable packaging containers) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
Marc 4.7 Customer Supplied Product vs 4.19 Servicing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
D Customer Supplied Product - Is a list of all customer supplied product sufficient? Document Control Systems, Procedures, Forms and Templates 2
Marc Humans as Customer Supplied Product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
JoeRandom11 Question about Customer Supplied Equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
R Customer supplied material - risk and policy advice needed Quality Manager and Management Related Issues 11
A Identification of Customer Property: Customer-Supplied Thumb Drives & Ext Hard Drives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R What objective evidence can/can't be supplied during a customer audit? General Auditing Discussions 3
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
I Implant Raw Material Supplied from Customer to Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 1
S How can I inventory labels supplied by customer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Procedure for Handling of Customer Supplied Material (AS9100 Requirements) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S ISO 9001 Section 7.6 - Customer has supplied torque specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R CAD Print Conflicts with the Customer Supplied Paper Drawing Manufacturing and Related Processes 19
N How to apply Incoming (Receiving) Inspection to Customer Supplied Material? IATF 16949 - Automotive Quality Systems Standard 18
H Can the documents supplied by the client categorised as customer property?? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Calibration through Gage Blocks/Test Fixtures/Customer Supplied ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
H What can be customer supplied properties (property) for the software industry? Software Quality Assurance 18
C Customer Changes to Customer Supplied Documents - Testing Instructions US Food and Drug Administration (FDA) 2
A Lot Number Assignment for Incoming Purchased Products and Customer Supplied Material Document Control Systems, Procedures, Forms and Templates 2
T Customer Supplied Material Procedure Document Control Systems, Procedures, Forms and Templates 10
T Control of Customer Supplied Material - Build to Print Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Customer Owned or Customer Supplied Properties - Do we need a procedure anyway? Document Control Systems, Procedures, Forms and Templates 11
T Best Method and Equipment for Measuring Porosity of Customer Supplied Castings Manufacturing and Related Processes 12
T PPAP supplied to our customer Direct from Heat Treater supplier Supplier Quality Assurance and other Supplier Issues 3
P Customer Supplied Property - System breakdowns at every level including sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Customer Rejections - Accepted minimum criteria for rejection of supplied parts? Nonconformance and Corrective Action 4
J New Gage R&R - Attribute gage supplied by my customer Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Customer supplied products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D Verification of Rev Level of Customer-Supplied Standards QS-9000 - American Automotive Manufacturers Standard 2
J CAD Files vs. Blueprints - How are people controlling customer supplied CAD files? Document Control Systems, Procedures, Forms and Templates 2
P Customer ISO13485 Audit - Changing Agenda ISO 13485:2016 - Medical Device Quality Management Systems 9
B Customer quality management system Reliability Analysis - Predictions, Testing and Standards 0
P Production location change by supplier without info to customer Benchmarking 16
Randy Oldest customer complaint known in the world Customer Complaints 5
S Customer Defective Part Return Process Process Maps, Process Mapping and Turtle Diagrams 2
M Voice of customer Manufacturing and Related Processes 5
Ashland78 IATF Process Control Plans not including customer name Manufacturing and Related Processes 13
T Reporting Adverse Events as Customer Complaints EU Medical Device Regulations 2
