Cyclic Destructive Testing - Continuous vs. Segments
hogheavenfarm
Just a question to throw out there.
We have to do a function test on a product that requires testing operation to 100,000 cycles. We are a fairly small organization, and have determined that this test will take several days of continous running. Since we do not have personnel here 24 hours, we want to break the test up into 8 hour segments, so someone will be availble to observe the test at all times.
Does this compromise the integrity of the test?
Some more data if it would be helpful, we are testing for fatigue of a large spring, and bushing wear at a hinge point.
Re: cyclic destructive testing
Have you thought about sub contracting the test? Then you don't have to worry about personnel coverage or test integrity.......might even be cheaper!
Tim Folkerts
Unless the test procedure specifically calls for continuous testing, I don't see how it would be a problem to break the test up into several intervals.
There might be some small change in results. Electronics for instance often work better once they are warmed up, so they might well last a little longer in on continuous test rather than turning on & off multiple times during the testing. Other items can "recover" while not it use and might last a little longer by letting them "rest" overnight.
For a spring I don't expect it will make a big difference either way. (But I have no specific experience with springs to back that up).
Tim F
It depends on what you expect the testing to show you. Obviously, if you want to know whether the thing will withstand 100,000 cycles in continuous operation, you wouldn't want to break it up. If knowing that it can take 100,000 cycles in intermittent operation is enough, then it shouldn't be a problem.
hogheavenfarm
You are correct Jim, The point is mechanical failure, not necessarily a result of continuous action, just specifying a limit to the duration.
Something that's often done in these cases is allowing the testing to continue until failure does occur, even after 100,000 (or however many relevant cycles/acutations/whatever). I recall an instance of testing an automotive window regulator that went on continuously for about a year, and was ended when the motor that ran the apparatus failed (the test fixture failed before the assembly under test did).
U
Umang Vidyarthi
To the best of my knowledge and experience, continuous running till it gives way, is a pre-requisite for any 'Fatigue Test'. By permitting rest periods you are not permitting the 'Fatigue' to set in and in that case, the 'Fatigue test' becomes a misnomer. The definition of fatigue in engg. is "The rupture or break down of material subjected to series of stresses."
IMO your inference drawn from Jim's post is not his intended response, as is further clear from Jim's next post at #7. This happens when you are groping for an answer suitable to your convenience. My advise is that you should continuously run the test, if found not feasible then you may outsource the same, as Andy has suggested here.
Hope this helps.
Umang :D
hogheavenfarm
OK, it was the thought that was lurking in the back of my mind, and why I posted this question. It makes sense viewed in that light.
Tim Folkerts
I'm not a metallurgist (although I have known a few).
I'm not sure what you mean by "permitting the fatigue to set in". The article on fatigue at Wikipedia (I know - it is not always a reliable source) says in part:
  • The process starts with dislocation movements, eventually forming persistent slip bands that nucleate short cracks.
  • Fatigue is a stochastic process, often showing considerable scatter even in controlled environments.
  • The greater the applied stress, the shorter the life.
  • Fatigue life scatter tends to increase for longer fatigue lives.
  • Damage is cumulative. Materials do not recover when rested.
This last line indicates to me that continuous testing would not be required. If you do 50,000 cycles and then pause, the damage is done and the material should get neither better not worse the next day. So you should be able to continue the testing from there with little or no change in the final results.
AGAIN - I am not a professional metallurgist. If the answer to this question is critical, then I would strongly advise getting the opinion of a metallurgist, not the opinion of a quality engineer.
Tim F
I SPC on Cyclic Data Statistical Analysis Tools, Techniques and SPC 10
P Cyclic Effect Factoring in DOE (Design of Experiments) Quality Tools, Improvement and Analysis 1
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
N Is capability applicable for a destructive test? Capability, Accuracy and Stability - Processes, Machines, etc. 9
M Identifying Technologies for Non Destructive Examination of steel brazed joints Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Non-destructive testing methods are special processes? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S About NDT (Non-Destructive Testing) and ISO 17020 Other ISO and International Standards and European Regulations 4
V Sampling Plan for Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Magnetic Particle Inspection Non-Destructive Testing Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Sampling plan for destructive tests on small lots ISO 13485:2016 - Medical Device Quality Management Systems 20
S Destructive Gage RR - Using Crossed - want your thoughts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
T Destructive Tensile Test Sampling Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Gauge R&R for Destructive Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
R Destructive Non Reproducibility MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Critical Defect Destructive Testing Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Destructive Attribute MSA for Simple Water Leak Check in Trailers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Destructive Testing Failure Mode Sampling Plan Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Samples for a Destructive Test included in a Lot Size? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
E Destructive Pull Test Gage R&R advice needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A Destructive Test Sample Size Reduction Statistical Analysis Tools, Techniques and SPC 10
A Destructive Attribute (Crossed) Gage R&R - Need Help! Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Destructive Attribute Gage R&R without LSL/USL Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Looking for A Non-Destructive Crimp Test method to replace Pull Test Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
E Sequence of Operations - Non-Destructive Testing vs. Trim & Drill Manufacturing and Related Processes 2
C Prices for NDT (Non-Destructive Testing) Inspection for a Boeing 737-400 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B GR&R (Gage R&R) for Destructive Test - Question on how to? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
optomist1 MSA Gage R&R - Destructive Test with One Sided Specification and One Operator Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Gage R&R Destructive UTS Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Destructive Test Sample Size Determination Statistical Analysis Tools, Techniques and SPC 4
A Performance Qualification For Destructive Testing (Impact Testing) Qualification and Validation (including 21 CFR Part 11) 4
I Destructive Testing Measurement System Analysis (MSA) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
C "Destructive" Linearity Study Methodology Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M What Sample Size for Destructive Test and is 'T' Test applicable? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R MSA gage R&R (GR&R) for Destructive Test (Non-Replicable Data) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N Destructive/Non-Repeatable Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Batch Acceptance: Cpk requirements and Sample Size - Destructive Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Nested vs. Crossed Gage R&R Models for Destructive Tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Part Variation, Unilateral Tolerance, Destructive Testing - Gage R&R Experts pls help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Destructive Attribute MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
R Destructive Attribute Gage Studies - inserted/pressed in parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T Gage R&R studies for Destructive Test Devices (pull and push tests) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Project to Reduce Destructive Sampling in Crimping Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Y Destructive Gage R&R Spreadsheet - Old MSA formula (5.15s) vs New formula (6s) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
