P
We are trying to perform an experiment that may or may not have an external cyclic influence.
For example our process is to optimise vision through a lens, the lens must be clean to start the experiment but depending on the application the user may or may not clean the lens during the experiment.
It the initial experiment we could clean the lens between each experiment and this would be acceptable. We could NOT clean the lens at all and validate if there was an external effect.
But after the initial setup experiment we may have a process where we need to clean every 3 or 4 observations so we would need to perform a number of repetitions to ensure we had included the effect but how many times do we repeat the experiment.
e.g. if we are performing an L8 and need to clean the lens every 3 observations what should be out total experimental stratergy?
Thanks in advance.
Puiumeu.
Thanks in advance.
Puiumeu.
