Cytotoxicity testing to ISO 10993-5 results - Is 1/ mild a pass or fail?
Dosumi
I sent a foam hand grip for cytotoxicity testing to ISO 10993-5.
After receiving the results reactivity graded as 1,1,1 noted as mild 50%?
I posed the question to the test house if 1/ mild is a pass or fail.
Their answer was “There is no specification for pass/fail per ISO-10993-5. We can only report the cytotoxicity score and the interpretation.
However, the USP requirement for a pass is that the "test sample does not induce a greater than "2" cytotoxicity score," which is equivalent to a mild reaction”
As I will need to justify my acceptance of this test to use this item on our CE marked products.
How would I do that, are the USP standards a pass/fail type test? Is the test similar enough to reference the ISO to the USP?
Or is their an ISO document or MDD I can use to compare the results.
Don
mknight
Hi Don,
We had to set our own internal pass/fail specifications based on the performance of our previoulsy validated cleaning process. I know of no specs on this and have been equally frustrated. In our specs less than 50% of cells showing a cytopathic response (2 out of 4 or less score) is a pass. Keep in mind this is only a pass if other tests for particulate count and TOC are passed concurrently. Again, this is based on old internal company data and not any external stadard. I am sorry I can't be of more help.
Michael Malis
Don
It depends...what is the use of your device or Clasification?
Is is a handle bar for the bike or part of the implantable device?
If this is Class 1 device, 1 is acceptable. However, if this is Class III it could be another story...
Dosumi
Thank you for the replies.
Item is for a class 1 medical device / wheelchair hand grip
How would I go about showing acceptance of the product?
If I purchased the USP standard, does that have a pass/fail reactivity grading system, I could use to compare the ISO test results and use that as my basis for acceptance?
Don
MIREGMGR
Under present FDA regulations, USP standards are wholly irrelevant to medical devices, and are only applicable to pharma and related packaging and pharma-regulated dispensing systems.
Michael Malis
Don
Just attached the results of ISO 10993 to your Technical File with conclusion of acceptance!
M ISO 10993-5:2009 vs. ISO 10993-5:2003 differences - Cytotoxicity Testing Other Medical Device Related Standards 7
M Types of Medical Device Cytotoxicity Testing - ISO 10993-5 Other Medical Device Related Standards 4
MrTetris Are GLP required for testing cytotoxicity and soil remaining after sterilization of MD? Other Medical Device Related Standards 8
A Cytotoxicity Testing - FDA doesn't like the Filtration step 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
L Cytotoxicity at the end of life-time Other Medical Device Related Standards 3
M ISO 10993 Labs which can test Cytotoxicity, Sensitizaton and Irritation Other Medical Device Related Standards 10
B Expert advice on in vitro cytotoxicity test ISO10993-5 Other Medical Device Related Standards 1
E 60601-1 - Tilt testing - Tensile safety factor IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
V Setup for testing against ISO14708 clause 16 (protection of the patient from herms caused by heat) Other Medical Device Related Standards 0
gramps What do you think about automated QA testing For software app industry? Misc. Quality Assurance and Business Systems Related Topics 5
B In house NIOSH pre Testing accepted by NIOSH? US Food and Drug Administration (FDA) 1
M Bacteriostasis/Fungistasis Testing Other Medical Device and Orthopedic Related Topics 6
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
D Essential performance and EMC immunity testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
Q Summative Usability Evaluation Testing: prior or during Clinical Investigation? Human Factors and Ergonomics in Engineering 6
B NIOSH Approval for Surgical N95 Respirators - Required testing US Food and Drug Administration (FDA) 2
M ECG lead leakage currents - How to specify ECG leads during electrical safety testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
D CFR Title 14: Aeronautics and Space PART 120—DRUG AND ALCOHOL TESTING PROGRAM Federal Aviation Administration (FAA) Standards and Requirements 3
lanley liao Purchase Acceptance Criteria - Tensile testing Oil and Gas Industry Standards and Regulations 2
M Device mounted at IV pole - what about mechanical stability testing? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A Outsourcing IEC 60601-1 Ed 3.2 Testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
J Cochlear Implant Testing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Class I (exempt) testing requirements Other Medical Device Related Standards 0
JoCam Electrical Testing for Japan, PSE or CB Scheme Other Medical Device Regulations World-Wide 0
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
P Testing cloud-based backups IT (Information Technology) Service Management 7
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
N Chemical Testing on Medical Devices - Solutions in a container closure system (bag) EU Medical Device Regulations 1
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
T Flammability testing Reliability Analysis - Predictions, Testing and Standards 0
E Manufacturers should develop a testing device for covid19 Service Industry Specific Topics 0
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
K IEC 62304 - Testing Independance IEC 62304 - Medical Device Software Life Cycle Processes 5
A ANSI/AAMI versions of 60601-1-2 and related testing requirements Other Medical Device Related Standards 3
C Surgical mask stability testing (CE mark) EU Medical Device Regulations 2
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
C One Time Service Supplier - Temperature and Humidity Testing Service ISO 13485:2016 - Medical Device Quality Management Systems 5
D IEC 60601-1 - Service life testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
P Flammability Testing of Aircraft Interior Materials Federal Aviation Administration (FAA) Standards and Requirements 0
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
E ASTM F2118 - Fatigue testing of bone cement - Changes between the 2003 and the 2014? Other Medical Device Related Standards 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
