Data Collection Procedure for -70 Freezer (Defrosting)
K
KeithM
Ok here we go with another.
Currently we have a department that has no PM program so the -70 freezers get a good thick build up of frost. I'm being told to have them empty the freezer before taking the "As Found" data. Then after it's defrosted and we do a "as Left" Calibration we find that the RTD Probe is reading over 3 degrees off from our Temp Standard. Our tolerance is +/- 1 degree C
So in effect we have changed the environment before the "As Found" and changed it even more by defrosting before the "As Calibrated". Of course only my boss says this is the correct way to do things. And that this calibration does not require an "Out of Calibration" report.
Does anyone agree with this? I haven't found but one person so far mentioned above. I'd love to here some replies.:mad:
Sturmkind
Depending on which specification is used, a time limit is normally applied of from 1-3 minutes at conditioned temperature during which the environment reading is verified and any further testing (like impact) is performed. If the freezers can be unloaded in such a time before taking the temperature reading, it is probably marginally significant. Otherwise, leave them loaded and take the reading directly since that would reflect closer to the temperature as experienced by the items within the freezer.
The frost buildup may be acting as a thermal 'insulator' from the optimum operation of the freezer, though, so a 3 degree difference may be 'real'.
K
KeithM
Exactly!
That's why I suggested for them to make sure the probe is clear of ice and frost as part of their monthly PM. I'd like to see them explain this to the FDA when they come in.
G
George Weiss
Cool heads get raises, and stay employed.
Your Freezer is expected to respond quickly to changes of the internal temperature.
The ice build-up is slowing this response time greatly.
If the Freezer was never opened, then this would not be an issue.
With a nice ice coating, 4-10 hours might be needed to achieve +/-1 deg.
I am sure someone might quickly indicate that de-icing PM was done, and then do a normal calibration afterwards.
Another person might do a corrective action.
A company minded person would collect the information, and give the responsible person(s) the options to take.
Most calibrations are performed after a device is normalized to a defined condition. I am sure the ice present would be removed, before a successful performance verification was to be attempted.
So was your freezer set for –15deg.C or 0deg.C.?
I am sure one would be more serious then the other.
bobdoering
Stop X-bar/R Madness!!
I guess I may be missing the point - are you calibrating the freezer or the sensor? Is the sensor removable, or built in? What is the temperature "standard" you are using - a calibrated second sensor?
Jason PCSwitches
[FONT=&quot]How is the temperature monitored regularly? As bobdoering pointed out is there a sensor?
If your calibrating the freezer itself by taking readings how can you demonstrate controlled conditions are adhered to between calibration cycles.
What if the power goes of during the weekend and the freezer shuts down, thus making the temperature rise above the required conditions?
If you have product that is required to be temperature controlled, having a calibrated freezer IMHO is not enough. You need to have a system in place to monitor the conditions and have the ability to identify any changes that would affect the product it contains.[/FONT]
G
George Weiss
An excellent point ! :applause:
Some form centralized of data-logger for your freezers would be great. There are wireless sensor terminals now. Monitor, and keep track of all your freezers from home. I mean your cubicle.:notme:
I am sure the cost would be a barrier.
This is a good time to point out how PM would be cheaper than a monitoring system to protect from no PM. :agree1:
K
KeithM
The RTD is connected to the Building Management System and is recording the "official" temperature of the unit. Since it is recording the official temperature we calibrate them in place at their working temperature.
I fully realize I need to chill out. Not only are we wasting man hours for Facilities personell responding in the middle of the night for freezer alarms. It just gets frustrating dealing with the same issue over and over again when the simple solution is to get a PM plan in place. -70 freezers are built for long term cold storage and if the equipment owners take just a little time to learn about their equipment it's a win win for everyone involved. Cleaning a little at a time it should have never been allowed to build up 4 or 5 inches of ice all over the inside of the unit. Working in a FDA regulated company it's like pulling teeth not only to get people to follow existing procedures but to add a new procedure when needed. 7 managers in 4 years doesn't help either.
We use a Hart Thermometer for our standard.
bobdoering
Just a curiosity - have you contacted the freezer company to see what their expertise suggests?
Big Jim
The facilities I call on that have -70 (and colder) freezers have monitors and alarms on them. They know exactly what the temperatures are all the time, and they are automatically logged. That is in addition to annual calibrations.
Q AMS 2750 E or F Continuous Furnace TUS Data Collection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
MrTetris GDPR - Purposes and duration of data collection Other ISO and International Standards and European Regulations 8
Q Mixed data collection (SPC) for different mold cavities Statistical Analysis Tools, Techniques and SPC 2
R USB power between Medical Device Data Collection Device Component IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Bench Marking Automated Data Collection Benchmarking 4
P Data Collection - R&D / Lab Notebooks Document Control Systems, Procedures, Forms and Templates 5
P Change the way you think about SPC - Automatic Data Collection Statistical Analysis Tools, Techniques and SPC 8
P SPC Data Collection and Control Chart Type question Statistical Analysis Tools, Techniques and SPC 4
H Gage R&R Data Collection Form w/ Appraisers Names, Number of Parts, Number of Trials Document Control Systems, Procedures, Forms and Templates 2
K In Process Data Collection and Cpk Calculation Manufacturing and Related Processes 13
K Measurement Equipment with Electronic Data Collection - What type to buy? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q Mitutoyo USB Cables for Variables Data Collection using a Dial Snap Gage Statistical Analysis Tools, Techniques and SPC 2
somashekar Too much data, Too little analysis - Manual Stages Assembly Shop Data Collection Quality Tools, Improvement and Analysis 2
R Accounting for (Symbols for) Data Collection Points in Process Maps Quality Assurance and Compliance Software Tools and Solutions 1
M Predictive Maintenance Data Collection IATF 16949 - Automotive Quality Systems Standard 11
W Software for Data Collection, Generation of Worksheets and Form 1's EASA and JAA Aviation Standards and Requirements 5
S Practical Data Collection Process Recommendations? Design and Development of Products and Processes 6
P Data Collection Tools - PC Board Assembly (5-20 pieces in a run) Quality Tools, Improvement and Analysis 0
S OEE Software - Automating the collection of Overall Equipment Efficiency data Statistical Analysis Tools, Techniques and SPC 8
E Does anyone have a P-chart template for operator data collection? Statistical Analysis Tools, Techniques and SPC 1
M Time frequency estimation for SPC data collection Statistical Analysis Tools, Techniques and SPC 9
B Production Data Collection Imported Legacy Blogs 0
E Lot Size vs. OC Curve (n,c) of a Continuous Data Collection Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D How to increase productivity in your plant? Real-Time Data Collection / Monitoring Benchmarking 2
A Defect Data Collection or FRACAS Presentation - Looking for presentations Quality Tools, Improvement and Analysis 6
J Seeking: Gage Calibration Data Collection sheet example General Measurement Device and Calibration Topics 3
L Categories for data collection - Designing a form for when errors occur Nonconformance and Corrective Action 6
L Beginning SPC data collection: Metal Stamping Company - Need some advice Statistical Analysis Tools, Techniques and SPC 14
C Seeking APQP project plan done in Microsoft Project / Poll on Web Data Collection APQP and PPAP 14
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Safety data sheets software REACH and RoHS Conversations 2
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
Steve Prevette Informational I am presenting a webinar Thursday - "Data Driven Decision Making" - 19 November 2020 Statistical Analysis Tools, Techniques and SPC 5
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
D Preservation of Electronic Data / Information Technology ISO 13485:2016 - Medical Device Quality Management Systems 5
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
Z Putting back excluded rows/data points in a control chart Using Minitab Software 0
F General Data Protection Regulation (GDRP) CE Marking (Conformité Européene) / CB Scheme 6
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
