Data Collection Procedure for -70 Freezer (Defrosting)
bobdoering
Stop X-bar/R Madness!!
#11
The facilities I call on that have -70 (and colder) freezers have monitors and alarms on them. They know exactly what the temperatures are all the time, and they are automatically logged. That is in addition to annual calibrations.
This issue is how do they prove the monitors are accurate (not do they know what the recorder says at all times), and what are their calibration procedures. Those are the issues we are trying to benchmark in this thread.
Is ice buildup an issue at those locations, or is that error (if significant) ignored?
BradM
#12
I think you need to have an expert come and look at the freezers. I bet you paid $10K for that freezer (or near it). There should be no frost buildup. Is it happening around the gasket? if so, then it may not be sealing up tight enough. Maybe (just maybe) some door adjustments can fix the issue.
I'm coming in the middle of this, so sorry if I'm off base. You have an independent RTD in the freezer, monitored somewhere else. You have issues with the freezer, so someone comes in and performs maintenance on the equipment, independent of this probe. I would think the probe is removed from the chamber and set to the side. When complete, they place the probe back into the chamber.
If that is the case, there is no need for calibration. There has been no activity at all that could affect the accuracy of that independent probe.
K
KeithM
#13
Just to clerify. The "as found data was taken after the material was removed along with a good percentage of the frost/ice. This in my opinion is not right. "As Found" data should be taken as is. The probe however was still pretty well packed in frost/ice and was within the +/- 1 degree tolerance. Once the unit was defrosted the probe is now reading 3 degrees off since it's now free from the Frost/ice pack. Keep in mind that even though these units are for long term storage they are frequently opened in real lab use and frost/ice is easly removed as it forms. Once it is left to build the unit is no longer cycling as normal because of the lack of air flow. As I see it the data shows that this unit was not tracking properly and an Out of Calibration report would be prudent.
bobdoering
#14
I agree, what you are describing is not what I would call a "calibration" - at least in terms of the sensor (or, to be fair, the controller if it depends on that sensor.) Conditions tested "as found" and "as left" should be identical, with the only difference between the two any adjustment (if required or possible) if you are calibrating the sensor.
If you are "calibrating" the freezer "system" (sensor, controller, and PM), then as found would be as it was found (iced up), and as left would be defrosted (as an "adjustment"), if that is how you left it. If your +/- 1 degree tolerance is for the system, and you find a 3 degree difference, then you need to correct the system (yes, out of calibration) - which (of course) is defrosting more often so that the sensor does not accumulate enough ice to become more than +/- 1 degree off.
Big Jim
#15
The log and how the readings compare to the calibration readings would be useful information, especially the before and after defrost log readings. I'm not claiming that it is a complete answer, but it would provide far more information than they have now.
Q AMS 2750 E or F Continuous Furnace TUS Data Collection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
MrTetris GDPR - Purposes and duration of data collection Other ISO and International Standards and European Regulations 8
Q Mixed data collection (SPC) for different mold cavities Statistical Analysis Tools, Techniques and SPC 2
R USB power between Medical Device Data Collection Device Component IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Bench Marking Automated Data Collection Benchmarking 4
P Data Collection - R&D / Lab Notebooks Document Control Systems, Procedures, Forms and Templates 5
P Change the way you think about SPC - Automatic Data Collection Statistical Analysis Tools, Techniques and SPC 8
P SPC Data Collection and Control Chart Type question Statistical Analysis Tools, Techniques and SPC 4
H Gage R&R Data Collection Form w/ Appraisers Names, Number of Parts, Number of Trials Document Control Systems, Procedures, Forms and Templates 2
K In Process Data Collection and Cpk Calculation Manufacturing and Related Processes 13
K Measurement Equipment with Electronic Data Collection - What type to buy? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q Mitutoyo USB Cables for Variables Data Collection using a Dial Snap Gage Statistical Analysis Tools, Techniques and SPC 2
somashekar Too much data, Too little analysis - Manual Stages Assembly Shop Data Collection Quality Tools, Improvement and Analysis 2
R Accounting for (Symbols for) Data Collection Points in Process Maps Quality Assurance and Compliance Software Tools and Solutions 1
M Predictive Maintenance Data Collection IATF 16949 - Automotive Quality Systems Standard 11
W Software for Data Collection, Generation of Worksheets and Form 1's EASA and JAA Aviation Standards and Requirements 5
S Practical Data Collection Process Recommendations? Design and Development of Products and Processes 6
P Data Collection Tools - PC Board Assembly (5-20 pieces in a run) Quality Tools, Improvement and Analysis 0
S OEE Software - Automating the collection of Overall Equipment Efficiency data Statistical Analysis Tools, Techniques and SPC 8
E Does anyone have a P-chart template for operator data collection? Statistical Analysis Tools, Techniques and SPC 1
M Time frequency estimation for SPC data collection Statistical Analysis Tools, Techniques and SPC 9
B Production Data Collection Imported Legacy Blogs 0
E Lot Size vs. OC Curve (n,c) of a Continuous Data Collection Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D How to increase productivity in your plant? Real-Time Data Collection / Monitoring Benchmarking 2
A Defect Data Collection or FRACAS Presentation - Looking for presentations Quality Tools, Improvement and Analysis 6
J Seeking: Gage Calibration Data Collection sheet example General Measurement Device and Calibration Topics 3
L Categories for data collection - Designing a form for when errors occur Nonconformance and Corrective Action 6
L Beginning SPC data collection: Metal Stamping Company - Need some advice Statistical Analysis Tools, Techniques and SPC 14
C Seeking APQP project plan done in Microsoft Project / Poll on Web Data Collection APQP and PPAP 14
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Safety data sheets software REACH and RoHS Conversations 2
M Data Protection and Privacy Policy - looking for a template/example EU Medical Device Regulations 1
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
M Disabling measurement data during fault conditions IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
C EU MDR - Annex II 6.1 Pre-clinical and clinical data EU Medical Device Regulations 4
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
lanley liao How to correctly understand the bullet list d) of 6.3 Analysis of Data for API Spec Q1 Oil and Gas Industry Standards and Regulations 7
Steve Prevette Informational I am presenting a webinar Thursday - "Data Driven Decision Making" - 19 November 2020 Statistical Analysis Tools, Techniques and SPC 5
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
D Preservation of Electronic Data / Information Technology ISO 13485:2016 - Medical Device Quality Management Systems 5
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
DuncanGibbons Technical Data Package vs Digital Product Definition APQP and PPAP 0
Z Putting back excluded rows/data points in a control chart Using Minitab Software 0
F General Data Protection Regulation (GDRP) CE Marking (Conformité Européene) / CB Scheme 6
Z Minitab - Updating Graph with specific data points Using Minitab Software 2
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
