Data sheet from McMasterCarr enough for RoHS/REACH documentation?
zork_14
I'm gathering documentation for RoHS and REACH compliance for a product I'm planning to sell. Many of my components come from McMaster Carr (MM) and the data sheet states that they are REACH and RoHS compliant. Is making a .pdf or taking a screenshot of the datasheet good enough to build my technical file? Let's for example consider this simple screw 91290A117 from MM (I cannot post a link because I'm a new user).
I've read an excerpt from EN50581:2012 (the standard that says what documents are OK for the RoHS technical file) saying that you can use:
1. a certification of compliance (CoC) from the company (with name and signature): the MM page does not have a signature.
2. a data sheet: "1. The data sheet must be from the original manufacturer". Can MM be considered as the original manufacturer?
If not, would that mean that for every MM component I should send an email to MM asking either for a certification of compliance or for the product number and manufacturer and then get the datasheet or CoC from the original manufacturer? One reason I selected McMaster is that the RoHS/REACH is so easy to check in a few clicks. I hope I do not have to go back to original manufacturers to prove my RoHS/REACH compliance.
Thanks a lot for any help
Ninja
Looking for Reality
For many, the listing (even a screen shot of the MC website offering) would be enough...but be aware that if anything ever 'hits the fan', McMaster Carr will play the "we had every reason to believe it" card, and your company will bear the burden of proof.
The drawings for the black SHCS you reference are copyrighted to MC and they are selling it as their product...it would likely stand up as original manufacturer even though it is clearly outsourced.
At the end of the day...it'll be up to the lawyers.
zork_14
Thanks a lot for your answer @Ninja.
That makes sense, I agree. In this example I should then consider MM as the original manufacturer. I am not supposed to know whether MM is outsourcing its parts and their data sheet is very clear on the compliance (it's probably different for Digikey for example where you can see the original manufacturer, I'll make another post later).
But is this not simply a widespread card? Or you mean that if they had issued an unambiguous CoC it would be more difficult to play that card?
Is it not very unlikely that things would turn bad for simple mechanical components from MM? If I did not have documentation available upon request, then yes it would be an issue. But if I have legally OK documentation (datasheet from original manufacturer), I believe that whoever would go after my parts would first need to prove that the part is not compliant?
Ninja
Looking for Reality
Totally...and it works...that's why it is used so often.
You just called two things equal {datasheet = legally OK documentation} ...they may or may not be...and I'm not a lawyer. If it is of enough concern, I would contact counsel experienced in this area.
I would think it rather unlikely...but, funny thing is, no one ever calls me to ask what I think in cases like these...gotta make your own call there.
Ninja
Looking for Reality
BTW, I just noticed that these were your first two posts.
Welcome to the Cove! Glad to have you here.
R Material safety data sheet (MSDS) related clause in IATF 16949 manual IATF 16949 - Automotive Quality Systems Standard 17
F MSA - Measurement System Analysis Attribute Data Crosstab sheet APQP and PPAP 1
L Can I use Technical Data Sheet as Material Test Results in PPAP APQP and PPAP 6
smryan How to get data (column varies) from one sheet to another? Excel .xls Spreadsheet Templates and Tools 12
N MSDS (Material Safety Data Sheet) Management Services - Advice needed Miscellaneous Environmental Standards and EMS Related Discussions 1
E What are the main reasons to update data in MDS Sheet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
U Free Data Analysis Check Sheet & Calculator Quality Tools, Improvement and Analysis 7
T Status of Material Safety Data Sheet (OSHA Compliant) vs. 10993 Certificate US Food and Drug Administration (FDA) 5
M Gage R sheet - Can someone make sense of this data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Seeking: Gage Calibration Data Collection sheet example General Measurement Device and Calibration Topics 3
E How do I enter materials into IMDS (International Material Data Sheet)? RoHS, REACH, ELV, IMDS and Restricted Substances 10
B Customer Requirement Data Sheet - Samples? Document Control Systems, Procedures, Forms and Templates 3
L Material Safety Data Sheet - MSDS should specify how to make the material innocuous Miscellaneous Environmental Standards and EMS Related Discussions 10
C Primary data record ISO 17025 related Discussions 1
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 1
I Brazil clinical data/trial requirement Other Medical Device Regulations World-Wide 1
W Part 145 Maintenance Data Review EASA and JAA Aviation Standards and Requirements 1
E Electronic Data Management ISO 17025 related Discussions 1
D ISO 14001 Finding - Missing Safety Data Sheets ISO 14001:2015 Specific Discussions 2
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
K Before-After Data Analysis Statistical Analysis Tools, Techniques and SPC 1
D Gage type and data base maintainence Using GAGEpack Software 2
Dazzur Sharing Suppliers Performance Data with Supplier. Supplier Quality Assurance and other Supplier Issues 6
M Conducting a clinical investigation with clinical data from India EU Medical Device Regulations 3
T Data types vs Mathematical operations Six Sigma 4
T Gage R&R study - Ordinal data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
optomist1 Data Bias - Surveys Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Levels of actions and consequence to data integrity US Food and Drug Administration (FDA) 10
M ADME data- substances based MD EU Medical Device Regulations 0
B Can a software that receive data from a MD be classified as Class I?or is not a MD? EU Medical Device Regulations 5
T Process Potential estimation for binary data Capability, Accuracy and Stability - Processes, Machines, etc. 3
RoxaneB Data Storytelling Misc. Quality Assurance and Business Systems Related Topics 4
MaHoDie Summative Evaluation with Post-Market Data? Human Factors and Ergonomics in Engineering 2
J EU Data Act Medical Information Technology, Medical Software and Health Informatics 0
P Transferring medical data from a device (Sec 201(h)): regulatory implications US Medical Device Regulations 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
R FDA ECG Data Requirements Medical Information Technology, Medical Software and Health Informatics 3
T SQL Server 2019 - Master Data Services - Validation needed? ISO 13485:2016 - Medical Device Quality Management Systems 4
C Elaborating a control chart with skewed data Manufacturing and Related Processes 4
D Data normality versus capability Capability, Accuracy and Stability - Processes, Machines, etc. 11
I In-Process Inspection Raw Data ISO 13485:2016 - Medical Device Quality Management Systems 3
T Class III device and shelf life data requirements US Medical Device Regulations 7
S Discussion on OBL and OEM test data for submission as per new EUMDR EU Medical Device Regulations 0
C How to place software version for SaMD product in HIBC secondary data structure (UDI-PI)? Other US Medical Device Regulations 4
PQ Systems Better Data Visualization & Communication with Statistical Indices Using SQCpack Software 0
PQ Systems Data Entry Workflows with SQCpack Using SQCpack Software 2
PQ Systems Data Security in the Quality Industry Using GAGEpack Software 0
B Establishing a Data Analysis Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Fjalar ISO 20417:2021: Technical Data (6.6.4 c) Other Medical Device Related Standards 0
Z PMS Data collection for SAMD SaaS from clients EU Medical Device Regulations 3
