Databasing specifications and tolerances for mechanical products
apestate
Hello everyone
Documenting specifications and tolerances is a monotonous task. Usually when a PPAP submission or Initial Sample Inspection Report is required by a customer, we have to label the specifications on the blueprint and list them on an ISIR form.
I have seen several spreadsheets that somewhat automate this task, nearly eliminating the waste of doing the data entry more than once. The Quality Manager would label the blueprint and enter the data into the spreadsheet. The data would link to the entire body of documentation needed for the part. The various sheets would be different tabs in the Microsoft Excel workbook.
The company I'm working for doesn't have such an elegant spreadsheet solution. We would like to create and utilize a solution like this.
There are a couple of issues that are unresolved with the basic spreadsheet PPAP/CP/FMEA/ISIR/Inspection Sheet package that I've seen people build. I think the majority of the difficulty rides on the array of specification and tolerance types that must be dealt with.
A "requirement" cell in one of these worksheets can have a lot of different types of data in it. Radius, angle, basic, linear dimension, range based on linear dimension, etc. This is not databasable, and that is the real goal.
I'm asking The Cove for help naming all the types of specifications and tolerances common to mechanical products.
I'll list them as I see it and attach a spreadsheet with the same.
Specifications:
Linear
Basic
Angle
Radius
Roughness
Standard
Custom
Tolerances:
Bilateral
Unilateral
Range
Minimum
Maximum
Geometric
Standard
Has anyone got ideas about how best to categorize, list, or otherwise handle the array of specifications and tolerances applied to mechanical product?
CarolX
atetsade said:
Specifications:
Linear
Basic
Angle
Radius
Roughness
Standard
Custom
Diameter
Depth (as in counterbore or countersink)
atetsade said:
Tolerances:
Bilateral
Unilateral
Range
Minimum
Maximum
Geometric
Standard
Block
Other (as in +.005/-.020)
Just a few off the top of my head.
apestate
Ah.
Thank you very much CarolX.
I think it would be helpful to add diameter, but in strict terms of data handling a numerical entry with appropriate tolerance would probably work.
This also applies to depth, but in this situation we come into another data handling problem. Chamfers, countersinks, and the like are often specified in strings of data.
It would be good to avoid splitting a chamfer into two requirements, for example:
"1" CHAM .1875 +.020/-.005 X 45 "2"
With data entry as follows:
cellA1 1 cellB1 .1875 cellC1 linear cellD1 bilateral cellE1 +.020 cellF1 -.005
cellA2 2 cellB2 45 cellC2 angle cellD2 bilateral cellE2 +.5 cellF2 -.5
It would be annoying to have to mark every single possible piece of data with a little circled number, because sometimes the specifications are strings of details. It's also a lot of data entry, but once it's there you have total power over it. The data entry could be finessed in many ways.
Let me ask, by Block do you mean tolerance block?
Let me also ask if you see where I'm going with this.
CarolX
This has always been an issue for me - so many features are not strickly numerical - what about drawing notes?
It would be annoying to have to mark every single possible piece of data with a little circled number, because sometimes the specifications are strings of details. It's also a lot of data entry, but once it's there you have total power over it. The data entry could be finessed in many ways..
Annoying is an understatement. But for your application - it might work. In mine - it would make me nuts - I average 10 first articles a week - and we work to customer drawings - and everyone seems to have a different way of creating their drawings.
Yep - block tolerances
You want to standardize your reporting form - and create a "master" from which to work from. Great idea!
Caster
An Early Cover
Marked Print?
atetsade said:
Hello everyone
I have seen several spreadsheets that somewhat automate this task, nearly eliminating the waste of doing the data entry more than once. The Quality Manager would label the blueprint and enter the data into the spreadsheet. .........Has anyone got ideas about how best to categorize, list, or otherwise handle the array of specifications and tolerances applied to mechanical product?
Atetsade
Years ago GM had the idea of a marked print, where we just neatly hand wrote the 5 measurements right on the print, with the bad ones in red.
There was a lot to be said for this, since it put the data right beside the reference. Saves going from a print out to the print, it's was all right there.
With Adobe pdf, I can imagine just adding a data layer to the print, could be very simple and effective to do.
Pretty sure the big 3 would never accept it though.
apestate
Great idea, Caster.
With PDF, the big three would never have to know. You could layer your inspection sheet right over the print and hand the operator a clear print and an inspection sheet print.
I wonder how this will be done in 25 years, since it'll take that long to sharpen a pencil in some of these businesses. wow I almost lost it there.
Imagine a tablet PC with a blueprint displayed. By "scrolling" you can three dimensionally go through inspection sheet, control plan, fmea; material status, schedule, production etc.; work instructions, photos, quality records, and even all the rest.
But in the present, I think a databasable document pack could be done pretty well within Microsoft Excel.
Carol, I think notes would have to be addressed in the Custom category, and perhaps leave the ability to have a large description of the requirement. Verifications of notes are generally pass/fail so the tolerance would most often be attribute.
There are so many possibilities once the computer is utilized. There are vastly more possibilities once the requirements can be organized and categorized into discrete data. Imagine recording data from runs. If the data is handled correctly from the outset, there would be very few roadblocks to electronically recording.
I almost lost it earlier because I was thinking about all of the leeched-solvent-from-the-air, soot-stained, never used, 30-year-old sharpened pencils I've seen amongst the epic junk piles over the years.
Does anyone believe there will be a franchise factory chain in any country, ever?
WES WHERE'S YOUR INPUT ON THE DATABASING DIMENSIONS!?! Has this ever been done or tried? Is this already available in software?
L Helix Zone Technologies - Anyone heard of it? Software for databasing FAI information Quality Assurance and Compliance Software Tools and Solutions 3
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
A Oven Controller Specifications - BAC5621 and AMS2750F AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
M MDR "Common Specifications" (CS) - If not standards, then what? EU Medical Device Regulations 5
G Engineering Specifications - APQP APQP and PPAP 5
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
DuncanGibbons OEM specifications such as AIPS spec from Airbus AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
C Taking exception to customer requirements or specifications & AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Software requirement and design specifications - Medical device contains both hardware and software IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational EU – Draft Functional specifications for the European Database on Medical Devices (Eudamed) – First release (High(1)) to be audited Medical Device and FDA Regulations and Standards News 0
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
D Raw Material chemical/Tensile Requirements Specifications (QQ-A-250/4, etc) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
2 ASTM or ISO Specifications on Prints Other US Medical Device Regulations 2
R Control of COTS (Commercial Off The Shelf) Specifications ISO 13485:2016 - Medical Device Quality Management Systems 2
I Procedures from recognized standards or specifications ISO 17025 related Discussions 3
S Test Specifications based on Vehicle Type Various Other Specifications, Standards, and related Requirements 0
P Help with 8.5.1 regarding Welding Procedure Specifications (WPS's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Technical Documentation - Manufacturing Specifications EU Medical Device Regulations 4
Z How to Contractually Agree on Specifications for Raw Material Purchases Supplier Quality Assurance and other Supplier Issues 15
J Change in Lot Release Specifications - Definition of "Substantial Change" EU Medical Device Regulations 14
T ISO 13485 Label Specifications and Artwork Control ISO 13485:2016 - Medical Device Quality Management Systems 3
alonFAI SMT machine specifications and performance meet the requirements for our production Manufacturing and Related Processes 2
N Subscription Service to Raw Material Specifications AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W Japanese Steel Specifications - A material called HNCM220M Manufacturing and Related Processes 1
A Procedure for Labeling Review and Approval and Specifications Matrix US Food and Drug Administration (FDA) 2
M Design Inputs - Final Medical Device Specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Q How to handle customer request for changing specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
O Functional Specifications - Tracability to requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
H Resistance Temperature Detectors (RTD) Manufacturer's Specifications General Measurement Device and Calibration Topics 3
K Thermocouples Hot Junction and Number of Uses Specifications AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K What is included in Raw Material and Component Specifications for Medical Devices? Other Medical Device Related Standards 3
A Are Software Requirements Specifications part of Design Input? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T How to keep Customer Engineering Specifications & CSRs Up to Date IATF 16949 - Automotive Quality Systems Standard 6
N Control of Documents Scope - Product Specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Specifications as requirements? Other US Medical Device Regulations 8
W Who in your company writes your policies, procedures, specifications etc. Document Control Systems, Procedures, Forms and Templates 10
M Thread Ring Gauge Specifications General Measurement Device and Calibration Topics 3
U Looking for Bolt Thread Specifications for Delrin & Aluminum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Standards or Specifications required for Garbage Truck Compressors Various Other Specifications, Standards, and related Requirements 1
V Where to get MS501 Chrysler Specifications APQP and PPAP 3
V Evaluation of Paint Specifications including such as GM 9984123 and GM 14671 APQP and PPAP 1
D M6X1 Thread Specifications Manufacturing and Related Processes 7
S ATA (Aerospace Testing Alliance) Specifications 100, 200 and 300 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Template for Product Specifications for Calcium Salt with the Chemical Composition Food Safety - ISO 22000, HACCP (21 CFR 120) 3
Z Control Plan & FMEA Specifications - Level of Details FMEA and Control Plans 4
D Use of Customer Specifications to calculate Cpk IATF 16949 - Automotive Quality Systems Standard 13
A Document Level for Drawings and Specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
