Dbase or Excel file to keep track on our internal failures (Non conform products)
Mr.Happy
Hello dear colleagues,
We machine parts for automotive.
I’ am looking for a MS Access or MS Excel file to keep track on our (inside) failures (Non conform products). This to calculate our PPM rates, the internal Quality costs and it would be great if it could produce a Quality (non conformity) report for our customer if it’s concerned customer’s material.
Thanks in advance
Mr. Happy
Sartaj Bedi
Re: Dbase or Excelfile to keep track on our internal failures (Non conform products)
There is a software called cwworks. Its actually a mainetance software but can help you to tyract break down and do simple root cause analyos. Yoi can assighn defects. It give a comprehensive repprts and I would recommedn that you try the trial version and there is afree version too.alternatively sinday business suystem adv on this site is ghood.
But cw works can handle the entire gambit of breakdown, pirchase.hope this helps.
mguilbert
Here is one for calibration. You will need to have your macro security level set to medium and macros enabled to operate.
Mr.Happy
Hello Mguilbert,
Thank you for this file, it is not what I'm looking for, but it is a good file for calibration.
I'm looking for a MS Access or MS Excel file for writing down our internal machining nonconformities, it must calculate the PPM and keep track of the costs. It also would be great if it could produce a Non conformity report.
Thanks anyway.
Mr. Happy
F
fengineering
How can I add more categories to this spreadsheet?
I need to have as found, as left, ect.
smryan
Perspective.
Without seeing the actual spreadsheet you are asking about the first answer that comes to mind is "add columns".
If we are talking about an Excel spreadsheet, place cursor in the column to the immediate right of where you want the new column inserted. Press [ALT] I (the insert shortcut) follwed by C (for column).
If this isn't the help you are hoping for you might need to put more info into your question. ;)
F
fengineering
This is a spreadsheet where you open it. A menu appears with buttons:
Calibration Data
Calibration Entry Form
Directions
I can insert the columns I need. And create the buttons I need in the Entry Form. But with out the knowledge of macros, they do nothing.
So if I create a new category in the Entry Form, created the text box and everything, how do I make it actually input information to the Calibration Data sheet.
I have looked at the way the other working buttons and forms are, and can't tell what was done in order to make it work.
F
fengineering
I ended up opting out of forms and went with a simple spreadsheet approach. It does have automatic date when due and days till due with color coding which is formulas from the original sheet you uploaded to this thread. Thanks very much!
Here I have attached what I created.
EDIT: I will attach when I get to 10 posts.
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
S 95% UCL - Attaching an excel for recovery study Statistical Analysis Tools, Techniques and SPC 0
T EXCEL - How do I make the cell stay blank until a date is entered in N7? Excel .xls Spreadsheet Templates and Tools 6
Ed Panek Validating Excel (XLS) formulas 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
C Template for Excel Validation Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Issuing of CoC to Customer in a Word or Excel format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ajit Basrur Track audit findings on Excel tracker Excel .xls Spreadsheet Templates and Tools 9
J Does anyone have an excel IATF 16949 Internal Audit checklist I could use? IATF 16949 - Automotive Quality Systems Standard 7
S Anyone Familiar with "SPC for Excel" add-in? Lean in Manufacturing and Service Industries 4
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
I Cannot Export multiple sections from Excel to PDF without losing pagination Excel .xls Spreadsheet Templates and Tools 23
M Matching two matrices in Excel Excel .xls Spreadsheet Templates and Tools 5
J Level 3 KPI Excel Template Manufacturing and Related Processes 1
bobdoering Informational New AIAG PFMEA Process - Excel Template Attached FMEA and Control Plans 23
GreatNate Excel PPAP Tracking templates or tool wanted APQP and PPAP 1
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
J ISO 9001:2015 Excel Gap Analysis wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B AS9110 Audit Check Sheet wanted Excel or Word Document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G Excel report with pictures Excel .xls Spreadsheet Templates and Tools 5
A Query regarding MS Excel usage Excel .xls Spreadsheet Templates and Tools 2
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
D Asterix when pasting a column of values from Excel into Minitab (V17) Using Minitab Software 5
Y Excel Automation - Printing Word Documents from within Excel Excel .xls Spreadsheet Templates and Tools 0
S Help me build an Excel Spreadsheet for tracking training Training - Internal, External, Online and Distance Learning 14
P Template or example Excel list of ISO certificates issued to clients ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Medical Device Process validation, Validation of excel spreadsheets used for process Other Medical Device and Orthopedic Related Topics 4
C Excel date format from Denmark to USA Excel .xls Spreadsheet Templates and Tools 6
G ISO 9001:2015 - Is control possible with Excel adaptable measurement sheets? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
N Where I can find an Excel sample/template for recording Delivery Time and Cost Excel .xls Spreadsheet Templates and Tools 2
D How do I go about creating document logs and registers with the MS Excel Excel .xls Spreadsheet Templates and Tools 2
D Microsoft Excel database to Stand-alone software Calibration and Metrology Software and Hardware 3
Q Controlling Multi-Tab Microsoft Excel Forms Excel .xls Spreadsheet Templates and Tools 5
B Zeiss CMM Calypso output to Excel or CSV file Help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
N Gantt Chart / Time Tracker in Excel - Combining Tasks on the Same Line Excel .xls Spreadsheet Templates and Tools 2
M Preventive Maintenance Spreadsheet in Excel Quality Assurance and Compliance Software Tools and Solutions 2
1 KPI Dashboard Template in Excel Format wanted Excel .xls Spreadsheet Templates and Tools 9
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
D Gage Calibration Tracking in MS Excel Calibration and Metrology Software and Hardware 9
T Where can I get a PPAP workbook in Excel .xls with links? APQP and PPAP 1
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V Looking for advice on Pooled Standard Deviation between Minitab and MS Excel Statistical Analysis Tools, Techniques and SPC 1
P Recommendations on SPC Software or Excel SPC add-in(s) Quality Assurance and Compliance Software Tools and Solutions 6
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
R Is there any Excel .xls Spreadsheet available for DOE with 3 factors? Six Sigma 1
kedarg6500 Excel spreadsheet for Unilateral Tolerance Study wanted Excel .xls Spreadsheet Templates and Tools 2
kedarg6500 Excel Spreadsheet for AIAG Example wanted Excel .xls Spreadsheet Templates and Tools 3
M Excel Leadtime Analysis Graphic Tool with Macros Enabled Lean in Manufacturing and Service Industries 0
A Tracking Calibration and Qualification in an MS Excel Spreadsheet Calibration and Metrology Software and Hardware 5
