Deciding on when to go for Cp & Cpk or Pp & Ppk Study?
statdoug
Re: How to decide , when to go for Cp ,Cpk study or for Pp,Ppk Study?
The difference between the Cp indices and the Pp indices is the method in which the standard deviation is calculated. The Pp indices use the standard deviation from all of the data where the Cp indices use the pooled "instantanious" standard deviation from the subgroup ranges or standard deviations.
If a process is unstable, the standard deviation in the Pp indices will be inflated. Generally (if the range/sigma chart is in control), the standard deviation used in the Cp indices will not be inflated by process instability.
one way to look at these is that the Cp indices will give you an indication of what the process will produce if stable, the Pp indices "indicate" what it is actually producing. This should be taken with a grain of salt however, as different aspects of instability can over-inflate the standard deviation. You really can not estimate the process capability on an unstable process.
As an interesting side note, Shewhart proposed a ratio of these two estimates of standard deviation as one of his tests for instability (his test 2).
Doug
bobdoering
Stop X-bar/R Madness!!
...You really can not estimate the process capability on an unstable process.
Nor can you utilize these specific indices on a stable process that is not bilateral and from a normal distribution.
For all practical purposes, they should be considered estimates, anyway. Using one number to represent the behavior of a process over time is nearly as valid as using a winning lottery ticket to represent the value of all lottery tickets.
D Deciding whether or not pre-market clinical investigation is required for low risk device EU Medical Device Regulations 5
J Deciding between Professional Use or Lay Person IVD Test - Human fecal stool specimens Other Medical Device and Orthopedic Related Topics 1
R Deciding if a medical device shall be supplied sterile or not Other Medical Device and Orthopedic Related Topics 5
A Trimming the Inspection Report - Deciding which are the CTF dimensions Manufacturing and Related Processes 3
P Deciding whether or not a new 510k is needed Other US Medical Device Regulations 2
J Deciding what Raw Materials we should require CofCs for ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
shimonv Deciding When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
B Deciding when to submit a Special 510(k) US Food and Drug Administration (FDA) 10
R Deciding what Processes need Control and Monitoring - 820.70 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
V Is permission from Registrar needed for deciding on in-house calibration? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Deciding if Calibration is needed for Production Instruments General Measurement Device and Calibration Topics 8
A Process FMEA - Help in deciding "detection ranking" of a failure mode FMEA and Control Plans 5
Q Deciding HOw to Measure Alloy Hardness after Casting Various Other Specifications, Standards, and related Requirements 2
R Cpk demands from automotive customer Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Can I use Cpk to compare if one part is usable in another part? Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Capability in sewing processes CP,CPk,PP,PPk Capability, Accuracy and Stability - Processes, Machines, etc. 10
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
